How does S mode work?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zeagle50, Jun 15, 2017.
  1. Jun 15, 2017 at 9:03 PM
    #41
    Taco_Tues_3rdGEN
    Taco_Tues_3rdGEN Well-Known Member
    Josh
    2017 Grey Tacoma TRD Sport
    TRD Pro Front Grille Pop&Lock Cali Raised Slim LED Light Bar TRD CAI
    I see. My sister has a new Subaru Forester XT, and that car is a blast in sport mode. I was surprised that it came with paddle shifters. However, after I drive that and get back into my truck, I feel like a slug.
    bshammer0[QUOTED] likes this.
  2. Mar 28, 2018 at 8:35 AM
    #42
    WATacoTaco
    WATacoTaco Well-Known Member
    2017 Inferno Taco Off Road
    Has anyone experience S mode not working? It use to work but I can't seem to use the S mode again. Damn truck has already been in the shop for a month and a half for a separate issue. Any ideas?
  3. Mar 28, 2018 at 9:09 AM
    #43
    Arianna
    Arianna Well-Known Member
    Arianna
    Oregon, Washington
    2017 Magnetic Grey Tacoma SR5 Crew Cab
    Try those as well as turn off traction control and ABS and you're ready to go do some badass donuts in the mud.
  4. Mar 28, 2018 at 10:27 AM
    #44
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    Not working? What is it not doing?
  5. Mar 28, 2018 at 10:41 AM
    #45
    WATacoTaco
    Not shifting at all. I put it in S mode and the display does not show what gear the vehicle is in. Thought it did before.
  6. Mar 28, 2018 at 10:46 AM
    #46
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    I beleive it only shows what gear you have it limited to. When you go to S mode it should default to 4, then you bump up or down and the number should change. So, if you go to S mode does your truck go through the gears, or does it just stay in 1st?
    AxisCab likes this.
  7. Mar 28, 2018 at 11:06 AM
    #47
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    S stands for Sequential. Unlike most other cars selecting gears in S mode doesn't actually mean you're selecting that gear (unless you set it to 1). It just limits it to that gear, but it will eventually change gears depending on speed etc. Really doesn't change the throttle mapping or shift points like it would in a typical sport mode in other cars. That's why Toyota can't call it Sport mode.
    GimmeATaco and Doggman like this.
  8. Mar 28, 2018 at 11:36 AM
    #48
    WATacoTaco
    So I tried that on the freeway and shifted to S mode and nothing.
  9. Mar 28, 2018 at 12:11 PM
    #49
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You selected S mode while on the freeway...?????:eek::eek::eek: Hope you were not going faster than a normal 4th gear.... If you WERE going too fast for 4th, the tranny would NOT shift down to 4th to save your tranny..... DO not shift to S mode over about 50 MPH....
    AxisCab likes this.
  10. Mar 28, 2018 at 12:28 PM
    #50
    greengs
    AB, Canada
    Max speed in 4th gear is 107 mph as per owners manual.
    trabo, Riding Dirty and Doggman like this.
  11. Mar 28, 2018 at 12:38 PM
    #51
    WATacoTaco
    Ive tried it at a stand still, on normal streets where the speed limit is 40 and in the freeway. Nothing.
  12. Mar 28, 2018 at 12:49 PM
    #52
    over60
    Muskoka, Ontario
    I don't like down shifting to 4th above 50 MPH.... don't want to rev the shit outta her by going to 6,000 RPM
  13. Mar 28, 2018 at 12:49 PM
    #53
    over60
    Muskoka, Ontario
    Time for the dealer...??
  14. Mar 28, 2018 at 1:44 PM
    #54
    WATacoTaco
    Yup. Just got an appointment for tomorrow. Man this truck. Love it but hate it at the same time.
  15. Mar 28, 2018 at 2:10 PM
    #55
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    ....this is overly cautious and unnecessary. 4th is perfectly fine at highway speeds. Preferable in a number of scenarios.
  16. Mar 28, 2018 at 4:33 PM
    #56
    over60
    Muskoka, Ontario
    It may be over cautious.... I'm always cautious with my little "Punkin".....!!:D
    AxisCab likes this.
  17. Mar 31, 2018 at 4:47 PM
    #57
    WATacoTaco
    Well... it's fixed. Dealership had my truck for over a month for a separate issue and FORGOT to plug the connector. Yup, my luck.:annoyed:
    AxisCab likes this.
  18. Apr 25, 2018 at 12:06 PM
    #58
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello folks,
    Has anyone driven in S-Mode, gear #5 on the highway at 70 MPH? If so what are the RPM's like at that speed? In my '08 PreRunner 4.0 Automatic with 285/70r17's I am at 2000 RPM's at 70 MPH in "D" mode. My speedometer is calibrated using a Hypertech calibrator so I assume the RPM's are accurate. My truck does not hunt for gears at all unless I tow my father-in-laws 4600lb boat. That's my reminder to put in 4th gear.
  19. Aug 2, 2018 at 9:37 AM
    #59
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    About a year ago I did the Mseo-Mod for the ECT always on. I did the Pac TR7 module prototype. Recently I also moved to S-mode for long trips . S-Mode by the manual is a gear limiter. So in 4th it shifts 1st through 4th until I decide to shift to 5th or 6th.
    I shift down on hills for engine braking and cruise in 6th gear. I also shift to S-mode 4th to get up to highway speeds then shift to 6th to cruise. Iv'e noticed improved performance and better gas millage. Also, it is much more fun to drive. Below are the gear ratios.
    My only question is there different shift threshold for ECT/S-mode and Drive/S-Mode?
    davidstacoma and Laser2000 like this.
  20. Aug 2, 2018 at 9:47 AM
    #60
    Tacomattt
    Tacomattt Well-Known Member
    No, The number represents the highest gear you would like to allow. It does not shift on command unless the rpms are high enough that it would have shifted anyway. So if it is in 2nd and 4000rpms and you bump it into 3rd it will shift into 3rd. If you are in 2nd at 1000rpms and bump it into 3rd it will not switch to 3rd until proper rpm for shift is achieved.
    CusterFan and TAC1 like this.
