How does the 3.5 VVT really work?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pablo8, Oct 8, 2019.
  1. Oct 8, 2019 at 7:42 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I am unsure how the Toyota (variable valve timing) VVT-iW and VVT-i work and what the differences are.
    VALVE MECHANISM
    1. General
    A high-expansion cycle (Atkinson cycle) is used to improve heat efficiency.
    On the intake side, Variable Valve Timing-intelligent Wide (VVT-iW), which is provided with an
    intermediate lock mechanism that optimally controls the intake camshaft (camshaft) to the valve timings according to driving conditions, is used.
    On the exhaust side, Variable Valve Timing-intelligent (VVT-i), which optimally controls the exhaust camshaft (No. 2 camshaft) to the valve timings according to driving conditions, is used."
    I ask - how is it controlled and activated?
    Junkhead and specter208 like this.
  2. Oct 8, 2019 at 8:11 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Read and enjoy.
  3. Oct 8, 2019 at 8:25 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    I may have missed it. I did not see that level of detail. Thanks
  4. Oct 8, 2019 at 8:38 PM
    TacoMamba35
    PNW
    Page 82 of the PDF is what you're looking for.
  5. Oct 9, 2019 at 3:23 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    That is marketing speak...........how does is really work? How does the lock work? How is it controlled? No details.
    Page 82:
    VALVE MECHANISM
    1. General
    Some Basics here: https://en.wikipedia.org/wiki/VVT-i
    There are some You Boob videos as well.
    MOC221_ likes this.
  6. Oct 9, 2019 at 3:27 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    As far as asking how VVTi(W) is controlled, you could ask Mat (OVtune). He has had his head in the ECM programming for more than 2 years.
    Pablo8[QUOTED][OP] likes this.
  7. Oct 9, 2019 at 4:32 AM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
  8. Oct 9, 2019 at 4:53 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yeah usually there's solenoids that control oil flow which locks / unlocks pins or advances (rotates) the cam.
    Junkhead likes this.
  9. Oct 9, 2019 at 4:57 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Posted the same wiki above. You can see that it uses oil pressure or rather pressurized oil. I assume controlled by ECU commands. The W or wide on the exhaust cam is what controls or more correctly switches in/out of quasi Atkinson.
    MOC221_ likes this.
  10. Oct 9, 2019 at 5:19 AM
    MOC221_
    Frank
    Did you mean the intake cams?
    Leaving the intake valve open after BDC when the piston is coming up on the compression stroke is how the 2GR-FKS "fakes" Atkinson cycle. Some of the charge air is pushed back out of the cylinder. Intake cam is retarded by some value to accomplish this.
    Pablo8[QUOTED][OP] and tonered like this.
  11. Oct 9, 2019 at 5:30 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    You are correct. What's the W on INTAKE Cam all about? Must be Atkinson.
    Edit. Brain gas this AM.
    MOC221_[QUOTED] likes this.
  12. Oct 9, 2019 at 5:53 AM
    MOC221_
    Frank
    Not a clue.
    According to OVtune, Atkinson does not necessarily turn on/off like a switch on the 2GR-FKS. He has posted several times that it is closer to being variable across a range of VVT angles.
    What I'm trying to say is this system is not like early VTEC.
    tonered and Pablo8[QUOTED][OP] like this.
  13. Oct 9, 2019 at 6:00 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    My work buddy said nearly the exact thing about VTEC.
  14. Oct 9, 2019 at 6:10 AM
    MOC221_
    Frank
    I forgot to mention, the "W" in VVTiW means "wide" as it states in the document you referenced. This refers to a "wide" arc of possible intake cam retard/advance angles. It's in that write-up.
    Note that this is only for the intake side, as it's necessary for the intake valves to hang open a few degrees on the compression stroke = quasi-Atkinson.
    On the Exhaust side, it's VVTi, no "wide". I'm sure the exhaust angles are tuned for Atkinson as well, but not to the degree the intake is.
    Pablo8[OP] likes this.
  15. Oct 9, 2019 at 6:18 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Yeah sorry. Brain ferts galore this AM. Dopey. Need coffee!
  16. Oct 9, 2019 at 8:35 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Yes, mine works and the truck accelerates the seat against my back at 3800rpms and takes off!
    Junkhead and Pablo8[OP] like this.
  17. Oct 10, 2019 at 1:59 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Keep reading the PDF. Page 151 lays out the actual operation. Interesting reading.
  18. Oct 10, 2019 at 2:39 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Also like three and five valve heads, the intake gets the extra valve because there's a limit to vacuum. Four valves typically, like ours, have much larger intake valves for this reason. So, on the exhaust side you don't need as much timing or area to get the job done as much as you do on the intake side.
  19. Jan 22, 2023 at 11:39 AM
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    Does anyone know where these VVT valves are located. I’ve heard it called oil control valve.
    trying to check mine but can only find info for the 4.0 engine.
  20. Jan 22, 2023 at 1:18 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Page 127 of the pdf in post #2. And then page 152+.
    Skydvrr and Junkhead like this.
