How does the 5speed transmission get overfilled?
Discussion in '1st Gen. Tacomas (1995-2004)' started by eon_blue, Oct 3, 2016.
  1. Oct 3, 2016 at 3:35 PM
    eon_blue
    eon_blue [OP] If I would, could you
    Azusa, CA
    Just a straightforward question I guess. I checked my transmission fluid the other day after getting it serviced and when I took the fill plug off (not the drain plug, trust me), about 1/4 quart of fluid poured out of it.
    My understanding is that the transmission takes 2.6 quarts of gear oil according to the owner's manual (I'll double check that number later when I can get to the manual), which is the equivalent of filling it up until the gear oil starts to drip out of the fill port.
    So how does an extra 1/3 quart of fluid end up coming out of the fill port if it was filled up to that point?
    FWIW I checked it when it was cool, not operating temp. I decided to check it because my transmission was feeling more notchy than usual after being serviced. I was more expecting it to be under-filled and was a little surprised at it being the other way around.
  2. Oct 3, 2016 at 3:37 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Filled on uneven ground.
    Bxnanaz likes this.
  3. Oct 3, 2016 at 3:37 PM
    eon_blue
    Azusa, CA
    That reminds me, I should mention that I checked it on even ground lol.
    Seems odd that Toyota would fill it on an uneven surface (or unevenly lifted) but I guess that's one likely explanation. Just wanted to be sure I wasn't missing something because with that much extra fluid it makes you wonder if it was intentional or not.
  4. Oct 3, 2016 at 6:06 PM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    Did you check the transfer case oil level. If the seal between t-case and Trans were bad could dump gear oil into trans.
    eon_blue[OP] likes this.
  5. Oct 3, 2016 at 7:10 PM
    eon_blue
    Azusa, CA
    I have not, I'll do that...thanks for the suggestion. Wouldn't it be likely to be leaking on the outside too if the seal was compromised that badly?
    I'll check it tomorrow when it's light out since its easy enough to do just to rule it out if nothing else
  6. Oct 3, 2016 at 8:37 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Its easy to to do if you using a pumper and stuff the end of the line into the fill hole and quickly put in the plug when its full.
  7. Oct 4, 2016 at 1:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just where did you have it done ??
    Most places the mechanic wanna bees get tasked with doing the service work
    Air operated gear oil pump if the gun end was set to high the tech just pumped the gear oil in to it quit .
    Quite easy to get extra in and not allow it to all drain out .
  8. Oct 4, 2016 at 7:36 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah its real easy to get extra oil in there, certainly nothing to worry about....
    Bxnanaz likes this.
  9. Oct 4, 2016 at 8:01 AM
    Wulf
    rock raisin
    The dealer will remove the shifter and fill through there. IIRC it's recommended to run 1/4 to 1/3 quart over to help with smoother shifting.
  10. Oct 4, 2016 at 9:42 AM
    eon_blue
    Azusa, CA
    Had it done at Toyota. Normally I would do it myself as it's an easy enough DIY thing to do, but I was getting other service done and figured I'd have them do that since they were under there anyway.
    huh, interesting. I didn't know that was even possible lol.
  11. Oct 4, 2016 at 3:44 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Why would they take the time to remove the shifter to put gear oil in??
    Unless they bill a hour labor to fill your gear oil and a hour to drain it ??
    Maybe it is the fill it to the top and call it good.
