how does the rubber bed mat hold up to UV?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NiceGuyEddie, Apr 15, 2010.
  1. Apr 15, 2010 at 7:39 PM
    NiceGuyEddie
    NiceGuyEddie [OP] Well-Known Member
    Chino, SoCal
    none yet
    i kept my last vehicle 20 years, imagine i'll have the Tacoma a long, long time. the sun is strong here in SoCal and i wonder if i should keep the mat rolled up in the garage and only use it when i need it.
    i only haul stuff 1% of the time, even then, it's usually not something that will slide around easily.
    10 years down the road, will this thing be all dry, chewed up, and useless? they look expensive to replace.
  2. Apr 15, 2010 at 7:49 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I dunno I have a undercover so it's hard to say... but if it took 10 years to rott out, less than 10 bucks a year for a mat is a pretty good deal imo.
  3. Apr 15, 2010 at 7:52 PM
    Dra6ula
    Dra6ula Well-Known Member
    Arizona
    TRD sport, prerunner...
    I've had mine a little over five years in the Az hotter than he77 sun and its still like new.
  4. Apr 15, 2010 at 7:59 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    My dad has had one for about five years also. It's in pretty good shape. I wouldn't be surprised if it lasted another five years.
  5. Apr 15, 2010 at 8:42 PM
    FuzzyTaco
    FuzzyTaco Certified Smartass
    Utah
    07 Prerunner TRD OR
    If the AZ sun doesn't eat it up (had mine about 2 years) then it'll probably last a good, long time.
  6. Apr 16, 2010 at 1:58 AM
    JKD
    JKD Well-Known Member
    Bed mats aren't that expensive anyway. Even if it only lasts ten years you aren't going to have to buy more than one or two more.
  7. Apr 16, 2010 at 3:11 AM
    cjh
    cjh Well-Known Member
    10 doublecab
    I have been using the same mat in the last 4 trucks. It is 15 years old and still looks O.K. I think it is a kenco or something.
  8. Apr 16, 2010 at 4:44 AM
    396tears
    396tears Well-Known Member
    When I bought my 2006 Prerunner in March 2006
    I also bought a Toyota bed mat.
    The bed mat is now in my 2010 I bought in March 2010.
    It still looks the same and has no wear showing.
    Of course I mostly just haul my golf clubs.
  9. Apr 16, 2010 at 4:47 AM
    911-3.2 Well-Known Member
    CT
    Sold - 2010 Access Cab 4x4 I4 SR5
    Curt Receiver Hitch, Access Literider Tonneau
    I had one similar to the DeeZee one a lot of people get on here and it still looked fine after 12 years in back of my F-250. It was a bit faded but by no means about to fall apart. I can't see how the Toyota one would be any different.
  10. Apr 16, 2010 at 5:24 AM
    LEEP
    LEEP Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    My bed mat is 20 years old + use it every day i have a cap on bed of truck
  11. Apr 16, 2010 at 5:31 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Believe me, everything slides in the bed. It's great when loading heavy stuff like ovens because I just put it in and give it a little push and it slides right in. This is not always a good thing. I'd recommend getting a bed mat.
  12. Apr 16, 2010 at 6:17 AM
    jassco
    jassco Well-Known Member
    Boston
    2010 Access Cab 2.7L SR5 5spd, 4x4
    5100 set to .85 w/ rear TSB, 2012 Rear-view Mirror, Grillecraft, Team Trails FJ Wheels, TPMS canister, Rear headrest delete, Rear console delete, Valley Hitch, Frame undercoat, $2.99 Tailgate hose clamp lock, Avid light bar, 4x4 lighted switch ala Biceman.
    Got one through a vendor on here for half the price of the dealer one...it's thick and heavy as hell. The one time you need to put something in the bed you'll want one. If i have to spend $60 on a mat every 5 years I would in a heartbeat, but this thing will probably last much longer.
  13. Apr 16, 2010 at 8:50 AM
    jonny
    jonny Betty White Edition Heep ZJ
    mine is holding up well.
    even has a burn out mark across it from when i used it in a desperate attempt to get traction in deep sand :laugh:
  14. Apr 16, 2010 at 11:17 AM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Hmmm, I wonder what that blazing sun will do to the composite bed...
    The mat will likely outlast the truck. Especially as you never intend to use it. Took me about 1 time putting something in the back of my truck without a mat to realize, shit really slides around in that bed without some rubber to hold it in place. Use the mat. Thats what you bought it for.
  15. Apr 16, 2010 at 1:15 PM
    NiceGuyEddie
    Chino, SoCal
    none yet
    WOW i am very surprised at this, i would have guess that since it's black, it would attract heat and dry up.
    and the price i looked at was the price from the Toyota website.
    thanks for the responses
  16. Apr 16, 2010 at 1:33 PM
    tuckr2
    There's lots of other sites to get the bed mat from as well. Save a few bucks if you don't need the Toyota logo.
  17. Apr 16, 2010 at 1:46 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    I had concerns as to how the mat would hold up in the sun as well. But hearing the responses in this thread is very reassuring. UV light is generally bad for all petroleum products. The vulcanized rubber of which the bed mat appears to constructed from is apparently very durable.
    I really enjoy my bed mat and I secured it to my composite bed using the bed mat bolt mod. :)
