HOW DOES THIS FLOOR JACK WORK?!?!
Discussion in 'Product Reviews' started by cgilbane, Nov 11, 2010.
  1. Nov 11, 2010 at 10:16 AM
    cgilbane
    cgilbane [OP] Well-Known Member
    Avon, CO
    07 Tacoma dbl cab
    remote reservoir fox shocks front and rear
    how do you use this jack?
    http://www.torinjacks.com/ProductDetail.aspx?ProductID=13
    ive never used a floor jack PERIOD (laugh all ya want, its my first truck)
    I cant figure out how to get the damn jack to work!!
    Anyone who has used it let me know.
    (And make fun too if ya want...);)
    EDIT: YOU GUYS ARE GREAT I FOUND IT THANKS!!!!
  2. Nov 11, 2010 at 10:19 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If it operates like a regular hydraulic floor jack, you need to use the end of the rod to tighten a nut that holds the pressure in. Then you can jack it up. To let it down, loosen the nut.
  3. Nov 11, 2010 at 10:22 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    i figured that, i cant find the nut though.
  4. Nov 11, 2010 at 10:23 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You put the metal rod into the pump and pump away. There's a pressure release (should be a bolt around where the pump portion is located) that the end of the jack rod fits over like a wrench. Tighten this bolt otherwise you won't be able gain pressure and lift the jack. If that doesn't work you have a defective jack.
  5. Nov 11, 2010 at 10:25 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    X2!
    That nut should be right near the pump area. Bottom right is where mine is located.
  6. Nov 11, 2010 at 10:27 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    found it, thanks
  7. Nov 11, 2010 at 10:28 AM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Some jacks... You twist the handle clockwise then pump it up and counter clockwise to let the pressure out to lower it.
  8. Nov 11, 2010 at 10:42 AM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    :( Awww, damn....
    I Google'd & made you this diagram.
  9. Nov 11, 2010 at 10:46 AM
    BeardedTaco
    BeardedTaco Well-Known Member
    SoCal
    09 PreRunner TRD Sport
    Banks Cat-Back Exhaust, K&N Drop In Filter
    That's what she said :D....But on a serious note you can usually find it right below the neck where you slide the handle in order to operate the jack. It's usually not a nut but threaded stud with a slot at the end.
    If you look down the end of the removable handle it has a bar that goes across it. You take the bar and put it over the stud with the slot and turn it to release or hold the jack pressure. You can control how fast or how slow to lower the car based on how fast you turn the handle. So yield on the side of caution until you get used to the new jack.
    Hope I understood your question and it helps you out.
  10. Nov 11, 2010 at 10:47 AM
    BeardedTaco
    SoCal
    Haha. I had to go into a meeting and all of you beat me to it :mad:
  11. Nov 11, 2010 at 10:59 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    hahaha thanks man thats great
  12. Nov 11, 2010 at 11:00 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    hahaha that is what she said.
