How does this frame rust look? Would you buy or stay away?
Discussion in '1st Gen. Tacomas (1995-2004)' started by aestheticbrah, Mar 16, 2016.
  1. Mar 16, 2016 at 2:26 PM
    ne_dan
    ne_dan Well-Known Member
    New England
    If you're in New England take a look at this truck. The frame was replaced on the Feb 29th. I drive by it on the way to my daughters day care everyday, looks to be in pretty good shape and only a little more then the one you're looking at.
  2. Mar 16, 2016 at 2:30 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    For the right price do it but personally I wouldn't spend over 8k just for the hassle. How many miles are on it, and I would do weekly treatments of saltwater to get a new frame before 2018. The frame is crap, my 81 didn't look half that bad and it was was from Colorado
  3. Mar 16, 2016 at 2:39 PM
    NeedmoreTaco
    NeedmoreTaco Garage full of white Toys...
    Eric
    Travelers Rest, SC
    2012 Super White DCSB Prerunner
    LEDs and stuff
    My opinion is any amount of rust is bad but I also live in the south. I would also be concerned with that nice shiny piece of pipe on the exhaust in front of the cat, what is that about? Oh and the moisture on the rear differential.
  4. Mar 16, 2016 at 2:43 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Guys, get over the rust. Under the Toyota warranty, the frame will be replaced for free if it fails the rust test and OP has until 2018 until it expires.
  5. Mar 16, 2016 at 2:45 PM
    NeedmoreTaco
    Eric
    Travelers Rest, SC
    LEDs and stuff
  6. Mar 16, 2016 at 2:46 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    If it DOESNT fail, then its good and just needs to be repainted. Not sure what you are getting at :notsure:
  7. Mar 17, 2016 at 7:29 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    You guys shouldn't move to the east coast of Canada, or northern Maine. It's hard to tell by pictures, but that frame looks solid to me. Ya it has rust, but a good soaking of rust chek or krown undercoating and it'll last years. The 2004 I just bought looked worse than that, but beating it with a hammer in various spots showed it was solid. A little rust flake off is normal for a 12 year old truck where I live.
    bottom line though, I payed 6k Canadian for mine, so I can live with a little rust on the frame.
    He has frame warrenty until 2018, so if it's toast like you all think he'll get everything replaced for free.
  8. Mar 18, 2016 at 1:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The only way to know for sure is the ball peen hammer or screw driver test .
    My truck looks like that after the first spraying of the liquid brine even having fresh paint every spring.
    The frame is the least of my concerns it would be the brake and fuel lines that would be more of a pain to me.
    Myself I think $12.000.00 is way to much
    Then I don`t need any more Toyota 4x4`s
  9. Mar 18, 2016 at 7:23 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    At this point in time until Totoya proves that they have fixed the frame rust problem I would stay away from any Tacoma regardless of the year and regardless of whether Toyota was willing to replace the frame. We are really letting them off much too easy. That said the frame doesn't look any worse than mine so if you really want it make sure you get it for a good price and oil the crap out of it and make sure you get inside that foolish boxed in section.
  10. Mar 18, 2016 at 9:37 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Then people should not buy Tacoma`s till around 2030 to see if the 2016 frames hold up as well as the one in my 2000 that went 14 winters.
    Then if no one buys them they won`t get driven so you would need to put it off another 15 years
    I wonder My tires showed some dry rot after 20 years out in the Sun New tires for all !!!
  11. Mar 18, 2016 at 1:41 PM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    That shiny piece looks like a patch on the exhaust pipe that is part of the cat. Mine is exactly the same. Cat still works (no codes) but the pipe rusted through at that same point. The rest of the pipe is solid. I wrapped some 18 gauge around it, welded the F out of it, and 2 years later its holding strong.
  12. Mar 27, 2016 at 7:17 PM
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    Definitely try the ball peen hammer test, usually the frame is thin on the inner passenger side just forward of the front leaf spring hanger.
    If it perforates the frame easily then Toyota will replace the frame for you especially since it had the inspection and undercoating in 2010.
    That is probably top dollar for a Tacoma with a new frame though.
  13. Mar 27, 2016 at 8:00 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Ive seen 2012s with more rust then that truck here. A 1st gen tacoma is a pretty rare vehicle here probably because most have rotted away.
  14. Mar 27, 2016 at 8:18 PM
    NrF
    NrF Well-Known Member
    SF East Bay
    Basic
    Ha!
    A frame like that for $12k--or 11.5 or even 11--no way. The whole thing smells, and reminds me of another dealer scheme I saw here a while ago. Why bother?
  15. Mar 27, 2016 at 8:38 PM
    #35
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Hey OP - how did this turn out? What was your decision? I'm from a small town in central Ontario where we get a lot of snow and use a lot of salt and sand. Any 5 year old truck where I live would look like the photos. I didn't see any perforation, scaling or degradation. Since Toyota has inspected the frame and has it in their program, I wouldn't worry about it, personally. I'd bet that if you swung a hammer at anything in the photos it would sound like solid steel. IMHO.
    It would look better if it was pressure washed and unpainted. I don't know why dudes think that by changing the colour of rusty metal with a coat of cheap paint, that they are somehow slowing down the oxidative process.
  16. Mar 27, 2016 at 8:43 PM
    #36
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    If you have to ask.... stay away
