How does TRD sport compare off road to a pre-tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elk assassin, Aug 6, 2012.
  1. Aug 15, 2012 at 11:50 PM
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    It's great offroad too
  2. Aug 16, 2012 at 5:02 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Heck, my weakly little SR5 rides like a Cadillac in comparison to my '05 Ranger (which even had a longer wheelbase). These things ride like cars compared to other trucks I've owned. I can't speak to the Sport or its offroad ability, though.
  3. Aug 16, 2012 at 5:34 AM
    Ragin Devildoc
    Ragin Devildoc MOLON LABE
    Doc
    Grunt Life
    12 Prerunner DCSB SR5
    16x8.5 level 8 guardian w/ hankook dynapro atm rf10, aFe pro dry s, flowmaster dbx exhaust, debadged, 2nd air filter removal
    Another option I would suggest if you are interested would be a prerunner SR5. It comes with the same leaf system as the sport and LSD, just doesn't cost as much and you can add mods as you wish.
  4. Aug 16, 2012 at 9:38 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    ummmmm. . . . its so you can power brake and burn both wheels instead of one. jk, well, thats what it does. go to howstuffworks and learn about differentials. that "pumpkin" between your driven wheels has stuff inside that allows it to allow the driven wheels to be turned at different speeds. for turns, and stuff
    in an open differential, power, as a side affect of the design is sent to the wheel that is easiest to turn. you're off-road, have one tire on a rock the other in a hole, the one in the hole, with no traction will spin while the other sits dead.
    oh wait you bought an off road edition, push the button and you climb out.
    like a quad, you ever tried to turn a non irs quad on the street? its hard, because both back tires spin together, same speed through two different length arcs, (both back tires follow their own path, the longer path being outside tire). cars and newer ranch/ utility quads solve this problem with differentials. then they solve the off-road traction problem with a "locker" feature, to lock driven wheels together so that "one wheel peel" thing goes away.
    my 4x4 truck, in situations where one front and one rear tire get light contact with the trail, is basically 2 wheel drive, sending power to both wheels that arent even touching the ground. if i had lockers front and rear, it would be a true 4 wheel drive.
    check howstuffworks or somewhere to see the real explanation, mine is pretty basic
  5. Aug 16, 2012 at 10:06 PM
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    You has it(if you have trd or). I suggest looking through your owner's manual and reading over the how stuff works as previously suggested. Without proper knowledge of you locker much damage may result with use.
    Edit: OP the Sport will do well off road. I had a 90 4runner previously and my TRD OR does as good/ better
  6. Aug 16, 2012 at 11:09 PM
    LocoTaco
    LocoTaco Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    My 09 TRD Sport rides great and handles off road very nicely, it is a well rounded truck.
    I would recommend a Sport to anyone.
  7. Aug 16, 2012 at 11:29 PM
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    not if your going to crawl over any big rocks:cool:. open diffs suck for that
  8. Aug 16, 2012 at 11:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Does anyone read the OP's anymore ?
    He said he got by fine in a non locked truck for everything he does offroad
  9. Aug 16, 2012 at 11:58 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    pre tacoma toyota pick up mini truck is the actual tsb title.
  10. Aug 17, 2012 at 5:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    Apparently not.
    This thread reminds me, I need to do some work to 88 pre-pre-taco.
  11. Aug 17, 2012 at 5:11 AM
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2022 DCLB TRD Sport Premium 4x4 Ice Cap
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - LED Map Lights - LED License Plate Bulbs - TRD License Plate Brackets - Front Recovery Shackle - Toyota Bed Mat -OEM Mudflaps -OEM Black emblem overlays - Removed front air dam - Goodyear Duratracs 265/75/16 - TRD Pro wheels
    wow, really?
    coming in here like you own the place with your 5 posts. valued member here.
    :amen:
    :locked:
