How does your real MPG compare to the cluster display?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by quartdeli, Oct 21, 2024.
  1. Oct 21, 2024 at 8:05 AM
    quartdeli
    quartdeli [OP] Member
    2021 Army Green TRD OR
    No funny business here coasting on a long downhill or following a semi super close, as I’ve seen some posts with a short trip and super high MPG readout. Not knocking it, it’s fun to cook the books sometimes! It’s entertaining to see those. We just drove from home in Detroit up to the Blue Mountains area in Ontario for the week for an anniversary trip. Pretty windy and plenty of hilly driving, plenty of miles on county roads around 60mph. Filled up once we got here and the tank took 7.95 gallons after driving 206 miles from my last fill up. Took a pic before pumping gas, displayed tank MPG is 24.6 but my actual MPG would have been about 25.9 according to my distance driven and gas consumed between fill ups. This has me curious; how big of a discrepancy are y’all getting between actual calculated fuel economy and the built in display?
  2. Oct 21, 2024 at 8:13 AM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    Mine is not really close either. My distance to empty always reads around 340 and I always am getting over 400 per tank. I've learned to just run it and fill it when it's empty
    quartdeli[OP] likes this.
  3. Oct 21, 2024 at 9:13 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    My 'per tank' MPGs calculated by the truck are sometimes very close to the calculated and other times really off.
    The only important gauge is the one at the lower right. The only accurate MPG calculation is the manual one done by dividing the miles between the last fill-up and the current one by the gallons required by the current fill-up.
    Instantaneous MPG calculations done by the truck are really only useful to judge your driving style and how it affect overall MPGs.
  4. Oct 21, 2024 at 9:52 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    About 0.5mpg.
    Note that real MPGs will vary by tire size. That would not be accounted for in comparison calculations to the display, but to know your real world MPGs, you would have to correct for tire size. And, that can vary by about 3% for new versus min tread.
    cwdog, BC Hunter and Chew like this.
  5. Oct 21, 2024 at 9:56 AM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    When I bought the truck new, it was a 175 mile drive back home.
    65 mph on the freeway.
    Indicated 26.2 mpg, which was awfully close to when I filled it up after the drive home.
  6. Oct 21, 2024 at 9:57 AM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    I clearly don't like doing math as much as you guys.
    23MGM, BC Hunter and boston23 like this.
  7. Oct 21, 2024 at 10:01 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Lol yeah I’ve never calculated it
    My actual mpg? Less than i’d like…
    Taco_Craig[QUOTED] likes this.
  8. Oct 21, 2024 at 10:01 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    It just can't be that simple. Are you certain this method works, or is it gonna get me in trouble if I just roll the dice and go for it?
    Edit: Never mind, that's crazy talk.
  9. Oct 21, 2024 at 10:11 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    With my tire size it's generally out by 1.5 L/100km fairly consistently after manually calculating it.
  10. Oct 21, 2024 at 10:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It depends how much you like to roll the dice? I haven't looked in a while, but my average fill up used to be over 18.5gal. Caught fumes a couple times.
    Now that my work schedule changed and I can't hit the station first thing in the morning, I am got going as deep as I used to.
    jmneill[QUOTED] likes this.
  11. Oct 21, 2024 at 10:16 AM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    At home on flat roads I see an average of 15.5 indicated, which is usually within .5 of hand calc'd. 90% of my driving is 65-70mph. Keep it under 65 and it gets better.
    I get quite a bit better mpg's when in mountains or hilly areas. I'll see 17+ in the mountains, even at freeway speeds. As soon as I'm back to flat lands my mpgs drop.
  12. Oct 21, 2024 at 10:32 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Dashboard is estimates. Gas-added-after is real. Use the "instant MPG" to try to keep the estimate closer to 30, slowing down below 75-80, coasting into red lights instead of accelerating, etc.
  13. Oct 21, 2024 at 1:20 PM
    MK Ranch
    MK Ranch Active Member
    Josh
    Covington, Louisiana
    2023 Tacoma TRD Off Road 4x4 Lunar Rock
    I live in southern Louisiana. Really flat, hot and humid. Don't know those last two things matter, but there ya go. I never manually calculated to know the accuracy, but when I fill all the way up, my screen tells me I have about 310-320mi in the tank. Most of my driving is road, street and highway with some interstate here and there. It varies from trip to trip, but I'd say I'm averaging around 18.5mpg. That's in my 23 TRDOF with the V6
  14. Oct 21, 2024 at 1:28 PM
    BigEasy
    BigEasy Well-Known Member
    Rob
    PNW
    2020 Tacoma TRD/OR DCLB
    Nada
    ~3200 miles round trip from PNW to SW US and back...
    Used actual mileage and gallons pump over pump fill up data... 2020 TRD OR, total stock, with tannaeu cover: 24.xx mpg round trip, never worried about it since
  15. Oct 21, 2024 at 1:51 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Mine reads about .5 MPG optimistic.
  16. Oct 21, 2024 at 2:12 PM
    unclewede
    unclewede Well-Known Member
    'Nard
    23 TRD Sport 4x4 Lunar
    How do you confirm your odo reading is correct to do the manual calculations? Fill until it overflows, or just til the nozzle clicks off?
  17. Oct 21, 2024 at 2:40 PM
    RockBunny
    RockBunny Well-Known Member
    Northern NH
    22 LunarTRD DCLB Sport
    I do the math every tank. I also have a ScanGuage going. Trucks computer is very accurate so far.
    Most roads are 40 mph, a few areas of 50. When I take longer trips the MPG goes up but then I kill it moving trailers or driving on the dirt road I live on.
    Overall average of all that, so far, 23 MPG says the computer And my math.
    BigEasy likes this.
  18. Oct 21, 2024 at 9:00 PM
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    How is the truck calculating MPG?
    Is it calculating off stock size tires and revolutions to give it a revolutions per mile equation?
    Let's say, as most of us are rocking larger tires than stock, wouldn't we actually be getting slightly better mileage than what's on the display?
    I might be missing something pretty basic as I don't know how the truck estimates this number. I never seem to drive till empty to get the manual numbers crunching. Luckily, I'm not planning a trip to the moon or anything, so I don't have to have any exact real-world MPG, but it's just something I think about on longer, boring drives.
    quartdeli[OP] and Northerntaco69 like this.
  19. Oct 22, 2024 at 3:08 AM
    Northerntaco69
    I think it calculates with stock tires in mind. Bigger tires weigh more. They make the truck " struggle" a bit more cause the mpg to drop
    Road Bull[QUOTED] likes this.
  20. Oct 22, 2024 at 4:44 AM
    SnoopisTDI
    SnoopisTDI Member
    2017 Tacoma TRD-OR
    C4Fab bumpers, Fox shocks, Ovrlnd camper, 5.29
    My mpg is pretty close, probably within 0.5mpg, but it probably helps that I have larger tires. I had a recent tank that said 8.7mpg (Tucumcari to Amarillo, IYKYK) but hand calculated was almost 10mpg.
    The "miles to empty" is wildly optimistic though. It can say I have 120mi to go, and 30mi later it says I have 60mi to go.
    It's not too hard to find calculators for tire size and correct your miles by 7% or 10% or whatever is appropriate.
    I think as long as you're consistent, it probably doesn't make much difference how you fill it up. When I had a diesel, I would fill it up until it was almost overflowing, let the foam settle, fill, let the foam settle, fill, until it couldn't take another drop- but on most cars that will damage your vapor recovery system, so now I just fill until the first shut-off, count to five, and click it on one more time until it shuts off.
