How does your Tacoma perform in snow?
Discussion in '4 Cylinder' started by wags, Feb 6, 2014.
  1. Feb 14, 2014 at 6:54 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    My 2wd 5 lug A/C has only got stuck once, about 40 ft from my driveway in a 4 ft drift.. the past two winters have had lots of snow, and have had no problems other than the 4 ft drift.
  2. Feb 14, 2014 at 7:01 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    we just had 6 inches of snow 1 inch of ice then freezing rain I have nitto tera grapplers and this thing goes like a tank no issues [​IMG]
  3. Feb 14, 2014 at 9:01 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Mine has yet to get stuck in snow, but then again, it hasn't met a 4-foot snow drift before. :D
  4. Feb 15, 2014 at 1:05 AM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Awesome in snow as long as you know the capabilities. It is a light truck in the back, so you should add weight. The stock tires will work in 4x4, until it gets deep enough to drag the under side.
    If the snow stays fluffy and you are on tar it does not matter how deep it gets, but once it starts setting up you need decent tires and/or weight in the back. Honestly on road it is no better than any other 4x4. Mostly it comes down to how much traction you can get, which means tire selection.
    Off road it will be better due to shorter wheel base/narrow stance. If you don't know how a short wheel base and narrow stance will help then you should spend more time off road, but a shorter wheel base will cause the back end to come around faster. So you need to be ready for that. They are awesome little trucks, but do have limitations. Plan ahead because they are not unstoppable no matter how you FEEL.
    Keep a shovel in the truck. Chainsaw/handsaw or something to cut trees. A tow strap and some good long lengths of rope with you. Invest in a good come-along or winch and you will be fine. Chains are not a bad idea either, but keep in mind they will only work on the rear (mostly).
    Fresh snow is a whole different animal than end of season snow.
  5. Feb 15, 2014 at 2:59 AM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    Mine loves the snow. I work in the hospital and have to get to work no matter what. My tacoma just handled the last 20" storm beautifully, and I am still running the stock sr5 tires
  6. Feb 15, 2014 at 3:30 AM
    BlueBomber
    BlueBomber Well-Known Member
    Luke
    Upstate, NY
    09 Taco SR5 4x4
    Magnaflow 14"
    I've got BFGoodrich A/Ts on my 4 banger, and has been a total blast so far in the snow.
    First proper storm hit since I picked her up. Probably 8-10 inches of slippy wet snow. I let it pile on for two days, then went out with the old shop broom and cleaned off the truck while it warmed up.
    Ended up plowing right through my un-shoveled driveway like it wasn't even there. Had to use 4hi to get traction after I reversed to turn around, but it caught and took me out, up and over the top of the bank left by Mr. Snowplow from earlier.
    I live 10-12 miles out of town, so I got to test the truck out on back roads and highways with only minor coverage. Handled really confidently the whole time on the highway. If I got a little exuberant with the throttle in a low gear it would kick out the rear slightly, but the TCS reigned it back in.
    Got to kick it into 4lo on my return to the house in my own driveway. My dad's big Hemi Ram was parked right in the middle because he got it stuck earlier, so when I crossed out into the yard trying to get around the back tires dug in. Just flipped it over into 4lo and it bulled through it like a champ.
    I don't think my Taco is equipped with the fancy a-trac that I've seen mentioned on here either, so I have to credit all of that handling to just the base stability control gizmos.
  7. Feb 15, 2014 at 10:50 AM
    dubveeyota
    dubveeyota Member
    Tony
    West By Gawd Virginia
    07 4x4 access cab base
    Mine is dangerous as all hell, but that's because I'm running some mastercrap courser ATs with barely any tread left. Despite that, it's still handling it well. I was hoping to get some duratracs on it before this last snow hit, but that didn't quite work out.
  8. Feb 15, 2014 at 6:25 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  9. Feb 16, 2014 at 12:07 PM
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    how do you guys get anywhere with the stock tires? i removed them at 600 miles, and haven't been happier.
  10. Feb 16, 2014 at 12:37 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My regular cab 4x4 loves the snow. I was good with the stock tires but I didn't like them and had some toyos with good tread so when one of the stock tires got a fatal nail I put the toyos on. Now it's great.
    I was fooling around and got stuck in a ditch in a foot of snow, had to use 4 LO and look out the window to be sure my front wheels were pointed in the right direction and we got out.
  11. Feb 16, 2014 at 12:47 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Love my Tacoma in the snow .. I'm on Hankook AT's now. Not the best in deep snow but they are great in ice. Here's a video from yesterday pulling a 3500 Chevy out. It took several tugs and a few re-positions. The snow was about 6-8" and really icy underneath. My truck navigated it fine, never once thought .. uh-oh. Lots of other people even in 4WD were having issues.
    http://www.youtube.com/watch?v=5ztRjYvOjFs&list=UUnjaRUs0UbJ6u3V1DadJi0A
    http://www.youtube.com/watch?v=JqY1iFxiIUY&list=UUnjaRUs0UbJ6u3V1DadJi0A
  12. Feb 16, 2014 at 1:19 PM
    sdc09taco
    sdc09taco Well-Known Member
    dave
    central ma
    09 access sr5 trd off road
    not yet
    same here :popcorn:
    got Goodyear wrangler rt/s with empty bed
  13. Feb 19, 2014 at 4:54 PM
    M0untainman22
    M0untainman22 New Member
    Newport News VA
    Handles like a champ in 4x4.
  14. Feb 19, 2014 at 5:14 PM
    1911
    1911 Well-Known Member
    Jerry
    Virginia
    2012 Silver 4x4 lifted with 32"s
    3" lift With rear leveling kit 32"s mounted on 16" F5s 20" and 30" Rigid LEDs Rigid LED backup lights Nerf bars (to be replaced with rock sliders) CB Custom grill
    12 DCSB 4x4 with Duratracs
    Went anywhere I wanted to go, in fact in the big snow last week I did not even put in 4x4 on the road at all, no need.
    The only time I used 4x4 was going around some other trucks in a field while taking the kids to ride their sleds.
    Very pleased with the truck, not to mention the Duratracs
  15. Feb 19, 2014 at 5:54 PM
    #35
    124x4tacoma
    124x4tacoma Member
    Margate, New Jersey
    12 4x4 access cab
    Tint Adjustable Shocks 1.75 Rear Leaf 1.5
    Truck handles great, very surprised with what this 4cyl can do. Here are some latest pictures from the latest storm in the mountain. 4x4 with Hankook dynapro AT
  16. Feb 19, 2014 at 6:00 PM
    #36
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Smart driving and tires make a huge difference. I've been driving for 30+ years, so I have lots of experience in the white stuff. I also have 2 extra steelies with Firestone WinterForce snows mounted on them. They really calm the back of the truck down and bite really well. I've had no issues at all in my 2wd....and that's with no extra weight in the bed.
  17. Feb 19, 2014 at 6:18 PM
    #37
    TacoMaine
    TacoMaine Well-Known Member
    Zack
    Richmond Maine
    2012 TRD Sport
    As stated earlier the rear end is light and it spins very easy in 2wd which = going nowhere.
    Other than that up HEAH in Maine we just got 10" a few days ago 6-8 last night so the roads were pretty covered and in 4x4 the truck is a tank. Goes anywhere you steer it "within reason" and really performs well overall even with the stock tires on it. Driving in snow is a technique not all grasp to well. Even the ones who live it every year seem to forget how and that's evident on the first snowfall each year with the amount of cars in the ditch.
    Bottom line is the truck goes great in snow no matter what tires are on it and given you had a little common sense.
  18. Feb 19, 2014 at 6:25 PM
    #38
    12TRDTacoma
    Rob
    Concordia
    Boosted
    BFG A/T KO's... this truck is a monster in the snow with the tires.
    That child in the background sounds adorable.
  19. Mar 6, 2014 at 3:55 PM
    #39
    AllTerrainMonster
    AllTerrainMonster Well-Known Member
    South Korea
    2006 2.7L Base 2WD
    '06 4-banger stock to the bone is fun to play in on ice and snow, but driving to and from work with only RWD is no bueno... but hey, who needs 4x4?
  20. Mar 6, 2014 at 7:05 PM
    #40
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Mines stock with Cooper Discoverer A/Ts. Last year we got stuck in a storm in PA/MD/VA and we drove about 150 miles in 4-6 inches of snow. The truck never left me feeling like we were going to get stuck, just took it slow and easy. We must have passed 50 cars, trucks, and SUVs in ditches and on the side of the highways (all okay, no one hurt).
