How easy is it to add a 4-wire plug to the factory towing harness?
Discussion in 'Towing' started by Ray, May 26, 2013.
  1. May 26, 2013 at 6:52 PM
    Ray
    Ray [OP] Well-Known Member
    San Diego
    09 Pre-Runner
    I have an '09 TRD with the OEM tow package. I would like to add a flat 4-wire plug to the harness so that I can use a receiver mounted brake lamp. There are aftermarket systems available that require some type of in-line module but can I just identify the proper wires and splice into them to power the flat 4-plug?
    Thanks,
    Ray
  2. May 26, 2013 at 7:05 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    gotta redo this , too big of a link..... they make adapters, sells anywhere like home depot , auto shops or boating shops.
  3. May 26, 2013 at 7:13 PM
    Ray
    San Diego
    09 Pre-Runner
    I have an adapter.....but there are times that I need to hook up to both the 7-pin and would like to have a flat 4-wire also.
    Ray
  4. May 26, 2013 at 7:15 PM
    Tacoyota
    08 4wd
  5. May 27, 2013 at 7:32 AM
    Ray
    San Diego
    09 Pre-Runner
  6. Nov 20, 2015 at 9:58 PM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out Emblems OME 887s - Dakars - LR UCAs FJ Trail Team SE wheels 285/75R16 BFG TA KO2
    Old thread, I know... But I'm in the same boat and saw this same harness earlier. Did you ever buy it? Did it work?
    I've left 2 of those 7 round to 4 flat adapters on the bumper... Looking for something more permanent for my boat trailers with the 4 flat plugs.
  7. Mar 26, 2016 at 10:22 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Oklahoma
    2015 DCSB TRD Off Road
    Did the OP ever figure out what works? The Hopkins 7/4 that was linked is supposedly only for the Tundra?
    I'm trying to get the same result as OP - an independent 4 pin connection somewhere off the rear bumper that can power a hitch mounted brake light. I'm tired of tailgaters and late brakers and want something to get their attention.
