How Easy Is It To Change the Headlight Bulbs?
Discussion in 'Lighting' started by dpak, May 23, 2011.
  1. May 23, 2011 at 3:52 PM
    dpak
    dpak [OP] Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    So, I need to replace my stock headlight bulbs and I have never done it before. Not on the Tacoma nor on any other vehicle I've owned. It looks easy according to the manual but most things look easy on paper. So is it really that easy? Is there enough room to change it or do I need to remove the washer fluid tank and battery? Or should I remove the entire headlight to do it? Any tips for changing the bulbs?
  2. May 23, 2011 at 7:17 PM
    CCCSOCOP
    CCCSOCOP Active Member
    RON
    CALIFORNIA
    06 TACOMA X-RUNNER
    XENON HEADLIGHTS, TINTED WINDOWS, BILLIT GRILL, TRAILER HITCH
    Hi DPak,
    I changed both headlights on my 06 x-runner recently and it was fairly easy. Just had to remove protective rubber boot and then unclip the metal spring holding in the bulb............not to complicated but is a tight fit for large wrist or hands.
    Good Luck
  3. May 24, 2011 at 6:00 PM
    dpak
    Richmond, VA
    thanks for confirming that it is actually easy. it gives me a boost of confidence.
