How Effective Are Performance Tunes on Tacos?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacobro11, Apr 28, 2017.
  1. Apr 28, 2017 at 9:14 AM
    tacobro11
    tacobro11 [OP] Active Member
    Brooks
    2010 Tacoma V6 4.0 L
    3" lift, nerf bars, Method "The Standard" Wheels, BFGoodrich KO2 Tires, Tonneau Cover, and much more to come.
    Thinking about investing in a performance tune... don't want to make the purchase unless it'll help my truck's performance a good amount. I'd rather not go to all of the trouble to install and uninstall every time I get it serviced if it doesn't yield good performance boosts. Anyone have a performance tune that they like? I have a 2010 V6 4.0 L (Access Cab).
  2. Apr 28, 2017 at 9:27 AM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    a question i have also. lets see what people say
  3. Apr 28, 2017 at 9:28 AM
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
  4. Apr 28, 2017 at 11:12 AM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    There is no current plug and play option really for 09+. Unless you want to have someone custom wire in an ECU for $$$$. Even then you'll probably see only 5-10hp. Like Spoon93 said, that section will give you tons of information.
  5. Apr 28, 2017 at 12:07 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Waste of $
  6. Apr 28, 2017 at 1:13 PM
    Spoon93
    Rogue valley
    06 DCSB SR5
    I wish I knew where it went but there was a thread in that section that went in depth, way beyond my level of understanding, on why "tuners" are pointless and showed the stats behind. Exhaust, and intake are about the only things you can do and even then the gains are minimal and hotly disputed.
    @tacobro11 a super charger is probably then only way to really get power out of your truck.
    taco2010trd likes this.
  7. Apr 28, 2017 at 2:18 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Most newer engines (mid-2000+) are in a pretty high state of tune from the factory--certainly not "balls and all", but not so shabby that simply remapping the fueling tables, bumping the timing, and maybe tweaking the MAF transfer function (common stuff on earlier EFI systems) are going to do much--that's how Toyota got 236/266 HP/lb·ft from the 4.0 (at the crankshaft--59 HP/litre). In comparison the 4.6 SOHC V8 in the '99 to '04 Mustang GTs was rated at just 260/302 HP/lb·ft; 56.5 HP/l at the crankshaft--this was 220 to 225 HP maybe at the rear wheels.
    The GT's 4.6 l tune could be tweaked as described above, and with modest bolt ons (aftermarket TB, upper plenum, exhaust and larger injectors) could actually deliver 260/299 HP/lb·ft to the rear wheels--assuming an 85% MT drive train efficiency this is 305/351 HP/lb·ft (66 HP/l) at the crankshaft--here's the last dyno run I did with my '03 GT (10/31/2012--Halloween!):
    Fortunately we do not have emissions testing here in Florida as I doubt the modifications and my tune would have passed-look at that AFR.
    The bottom line is that peak efficiency (think mpg) happens when the engine is operating optimally, and Toyota has no motivation to not tune for peak efficiency--so while there may be a few HP here and there there isn't much in the way of bolt-ons that's going to have a big pay-off...
  8. Apr 28, 2017 at 3:08 PM
    WOODEX M.E.
    Corey
    Maine
    You are right, just a tuner is basically pointless on a stock truck. The engine is already well sorted out for what it is. There is only a few hp to be had by the tuner itself. Once you do a bunch of suporting modifications it starts to make more sense.
