How far after fuel light comes on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calltrex, Mar 1, 2013.
  1. Apr 19, 2024 at 2:01 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    21 gallon tank, mine takes about 18 gallons when the light comes on.
    I usually never go below a quarter of a tank before I refill. My oldest brother likes to run on fumes and has replaced more fuel pumps than anyone I know.
    jwctaco likes this.
  2. Apr 20, 2024 at 12:33 AM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    I hit the trip, assume 2 gallons are left and stay under 40 miles. (but typically find a station sooner)
    MarX and jwctaco like this.
  3. Apr 20, 2024 at 2:37 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Just keep going, it’s a challenge :eek:
    That warning light is for chickens, keep going
    MarX, sublimaze, winkel and 2 others like this.
  4. Apr 20, 2024 at 2:51 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    The “Dude” would do it.:rasta: That dash light was put there by “The Man “, dude
    winkel likes this.
  5. Apr 20, 2024 at 4:24 AM
    545
    545 Well-Known Member
    2015 Access Cab
    you just randomly decided to ask for clarification on a question asked 10 years ago?
  6. Apr 20, 2024 at 4:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    11. This is 2024. :p
  7. Apr 20, 2024 at 10:26 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've never seen the low fuel light. If I ever do that means I have 2-3 gallons in the tank. It isn't a good idea to try to drive with it that low except in an extreme emergency. I'd stop at the 1st fuel stop. The truck may keep running on level ground, but with that little fuel it will all shift to either the front, or rear of the tank if you have to drive up, or down, an incline and the fuel pump may not be able to pick up fuel.
    I don't wait until I'm much below 1/4 tank and often fill up closer to 1/2 tank. I buy fuel when it is the most convenient for me and where I get good prices instead of buying it when I have to have it.
  8. Apr 20, 2024 at 10:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Gas Buddy is a good app to have to check fuel prices around you. Being crowd sourced data it's not perfect, but I find it correct more often than not.
  9. Apr 20, 2024 at 11:37 AM
    sublimaze
    sublimaze Well-Known Member
    Pro tip: When traveling in the desert southwest (or anywhere with few gas stations), never let your gas fall below 1/3 tank. I was driving a 4Runner in west Texas and wasn’t paying attention to the fuel gauge, and the light came on. I turned off the A/C and slowed down to 40 mph or so, trying to conserve gas. The engine died as I rolled into the next gas station. While I was refueling, another guy walked inside, came out with a portable fuel can, and used the pump next to me.
  10. Apr 20, 2024 at 11:56 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Overland tip: carry a full jerry can
    Common sense if you're gonna try to stretch your needle too
  11. Apr 20, 2024 at 5:40 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  12. Apr 20, 2024 at 5:42 PM
    TacoTuesday1
    SD CA
    why keep the tank half full at all times minimum so you are ready for anything that comes your way
    when you can run it empty stranded on the side of the road and burn out an expensive and hard to access fuel pump
    when I shared my dads car to get to school as a kid, it was not explicitly stated
    “If you are lazy run it to E and make me late to work in the morning having to get gas I will slap the shit out of you”
    If it was stated, it would be understandable
  13. Apr 20, 2024 at 5:44 PM
    Aaron O.
    Aaron O. Well-Known Member
    Aaron
    Denver, CO
    2023 Tacoma Off Road DCLB
    OffroadToy[QUOTED] likes this.
  14. Apr 20, 2024 at 6:37 PM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Can confirm about 4 gallons left when light comes on. I've filled up just after the light lit, usually about 17gal.
    One time on a long trip, I made a string of dumb decisions (i.e. not carrying a jerrycan, passing up gas stations before driving through BFE with a heavy trailer, etc).
    Ended up with a low fuel light shortly before the fuel stop I **planned** on stopping at was closed down.
    My butthole puckered harder with every mile ticked off, grannying this 5500lb trailer along, praying to see some lights on the horizon.
    Finally rolled into another rest stop 40ish miles up the interstate
    ....and pumped 20.5 gallons into the tank. Never again
  15. Apr 20, 2024 at 6:48 PM
    #35
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It’s definitely not good for the pump to go that low. I used to make fuel pump control modules and the pump is definitely cooled by the fuel it sits in. You’ll shorten fuel pump life regularly driving around with the light on. I tend to stay above 1/4 tank.
    Over voltage testing was interesting as it would make the varistor red hot but don’t worry, there’s not enough O2 for an explosion. :eek:
    risethewake likes this.
