How far below E can you go?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by danakinskyrocker, Jun 10, 2021.
  1. Jun 11, 2021 at 7:14 PM
    #81
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I rarely go under 1/2 a tank, and have never gone lower than 1/4.
    jetfishn likes this.
  2. Jun 11, 2021 at 7:57 PM
    #82
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Care-full you might start to get so corrosion on the lower part of the sending unit and not work proper and give you a inaccurate reading when you really need it.
    o_O
    don't worry the truck will NOT blow up if you go near zero a few times a year.
    been doing that for over 40 years and haven't died yet.
    :taco:
  3. Jun 11, 2021 at 8:43 PM
    #83
    eurowner
    eurowner Duke Sky
    Scoty
    When smoke exits the filler door is when I refill.
    jerkwithkeyboard likes this.
  4. Jun 11, 2021 at 9:15 PM
    #84
    JackSmith
    JackSmith Well-Known Member
    Tony
    SJC, CA
    '16 TRD OR DCSB 4x4 Manual
    I am often taking my chances with 30 miles below empty with ~13-14 mpg.
    So far no problems.l
  5. Jun 12, 2021 at 7:09 AM
    #85
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    About 21 more letters.
  6. Jun 12, 2021 at 7:21 AM
    #86
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    This truck seems to be quite conservative as far as fuel gauges go. 0 miles to empty in my experience is about 2 gallons left. ~19gal fuel up. As others stated there are some downsides to running it too low, but as long as there are at least 1-2 gallons in there it should be fine.
  7. Jun 12, 2021 at 7:32 AM
    #87
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Most I've filled was 19 gallons in the Tacoma. I've never been able to drive on an empty tank.
    My ol' '71 Buick Electra 225 took a fill of 27 gallons on a trip down I-35 thru KS.
    David K likes this.
  8. Jun 12, 2021 at 7:37 AM
    #88
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You win!
    Dennis Hopper put that fuel line in that holds an extra gallon.
  9. Jun 12, 2021 at 7:45 AM
    #89
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    E (Empty line on gauge) is where there is ~ 2.5-3.0 gallons left.
    I think the '0 point' is the "miles remaining" computer readout...? So, if there is actually 1 gallon at that point, depending on the model and load, most of us V-6 4x4 owners can go 15-20 miles with that one gallon.
  10. Jun 12, 2021 at 3:18 PM
    #90
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Wow. Sounds like u like to live dangerously. Lol
  11. Jun 15, 2021 at 2:40 PM
    #91
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Mystery solved…
    When it went from:
    to:
    I promptly pulled into the gas station (a stretch where they are on every corner…).
    I filled up and fist time it clicked and stopped, I let it go one more time:
    So, there is your answer… @tonered
    Bleep100, elmontemike and tonered like this.
  12. Jun 15, 2021 at 2:46 PM
    #92
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice work! Some more confirmation of that 18gal used when the light comes on and 19gal at DTE = 0mi.
    Now, you need to do that same experiment until it putters out and then coast on in. With someone reporting 21.4gal earlier, I'm wondering if the actual usable fuel isn't actually more than 21.1gal? Just to stave off the tank users / abusers like me.
  13. Jun 15, 2021 at 2:54 PM
    #93
    Fohu
    Fohu Well-Known Member
    Glade park Colorado
    2019 trd or access cab
    To all the fellas saying they never go below A half tank.
    Loosen up and live a little.
    not a better feeling in the world pressing your luck
    And rolling into that gas station sputtering on fumes.
    probably would have been smart to get off on the first exit when the light came on but no. You have a feeling in your heart that you can make it to that one gas station you like 34 miles away.
    But I’m a gambler so take it as you will.
    DustyQuikTaco likes this.
  14. Jun 15, 2021 at 2:56 PM
    #94
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    I wait until it says Distance to empty: please refuel, then go a distance equal to my (tank mpg * 2) more miles. (Usually 28 miles). I almost always fill up 19.3 gallons.
    I used to nail 20 gallons everytime with my second gen , but I’m a little more conservative with my supercharged 3rd gen. Don’t want to go too lean:)
    I have only ran out of gas once doing this (on my second gen.) I was doing worse than the 12.5mpg average that guzzler typically got. I managed to die uphill of the gas station and coast into the fuel stall to fill up 21.2 gallons
  15. Jun 15, 2021 at 3:00 PM
    #95
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I should say, this wasn’t a planned experiment, but one that just happened upon me. I was traveling out where there are no gas stations and the light popped on. Knowing that I was safe as I was already not too far from my destination, I figured fill up on the return. Having seen sub $2.50 gas, figured I’d wait for one. Once I saw where things were headed… decided to “find out” and document.
    tonered likes this.
  16. Jun 15, 2021 at 3:02 PM
    #96
    elmontemike
    elmontemike Well-Known Member
    Yikes. I never seen “please refuel”
    This is my lowest level.
  17. Jun 15, 2021 at 5:17 PM
    #97
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    I've been Tuning my guitars in B for 20+ years now, i think thats about a 4th lower than E?
  18. Jun 15, 2021 at 5:26 PM
    #98
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    I've driven probably like 10 miles after the range hit 0. Even when it hits 0 you still have ways to go.
  19. Jun 15, 2021 at 5:43 PM
    #99
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Those are the best kind of experiments. Ones that are convenient.
  20. Jun 15, 2021 at 5:56 PM
    #100
    tacopeter
    tacopeter My truck isn't modded. It's well optioned.
    Peter
    Washington State
    21 DCLB TRD OR
    OEM+
    I never let the truck get below the -F mark. :rofl: JK. I don’t drive my truck enough.
