How far can I go with low gas light?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by omegaman2, Dec 31, 2020.
  1. Jan 2, 2021 at 9:40 PM
    Novatoy1
    Novatoy1 Well-Known Member
    Jeff
    Pittsburgh
    2017 Tacoma CCOR
    It depends are what type of driving conditions.
    In my 04 6 cylinder Tacoma . I got 32 miles after the light came on going up and down hills on PA turnpike. I ran out of gas about 600 yards short of one of the gas rest stops.
    VirusCage likes this.
  2. Jan 3, 2021 at 1:30 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    My, and all 2nd gen Tacomas have an 80litre tank ( whatever in US gal.)
    I've hit the red light, and gassed up @ 65 ltrs = 15ltrs left in tank.
    I avg, +/- 15ltrs/100km Hwy. Something we all should be familiar with.
    But of course, don't make it a habit of running low to the point the red light comes on, eh?
    TacoEspecial, Key-Rei and Naveronski like this.
  3. Jan 3, 2021 at 2:09 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I have litterally had my gas light come on as I pulled up to the pump at a gas station and put 17.5 gallons in the 18 gallon tank.
    I have also driven with the light on so long (stuck in traffic due to an accident) and it was starting to idle rough (sucking up air) and coasted into a station then put 18.5 gallons in the 18 gallon tank.
    Pretty sure my light comes on with only about 3/4 a gallon left.
  4. Jan 3, 2021 at 2:21 AM
    Marc70
    Marc70
    Northern Ontario
    Well there you go. We should all know the limits of our OWN truck, not those of strangers on the internet. They may have been made the same, but things change.
    69 Jim and Key-Rei[QUOTED] like this.
  5. Jan 3, 2021 at 2:29 AM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    With freeway driving I consistently get 60 miles after the light goes on and pump 20-21 gallons when refueling. Most I’ve gone was 80 miles, never again. With city driving I ran out of gas after doing 30 miles.
    Same thing with my 1994 Acura Integra RS. I consistently get 60 miles after the light goes on and have about a gallon left. Most I’ve gone was about 80 miles.
    I don’t push it til empty anymore since it’s not a good practice like Marshall R said.
  6. Jan 3, 2021 at 2:50 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    All you Experts here's one for y'all:turtleride:
    Ok guys I'm gonna throw a wrench in this whole thing.
    I drive a Tractor Trailer on the Fuel Tank it says " Capacity 75 Gallons". Right under that is says 71 USABLE GALLONS.
    Soooo the question I am asking how many USABLE GALLONS in a Tacoma tank if it holds 21.0 galons.
  7. Jan 3, 2021 at 2:51 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I've gone 60 miles or so with the light on, nervous driving for sure, middle of the Everglades, 40 miles back to pavement after a fuel can failure.
  8. Jan 3, 2021 at 3:23 AM
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
    Did he make it? :popcorn:
    TacoEspecial likes this.
  9. Jan 3, 2021 at 3:56 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Be sure to not acutally run out when 'proving it to here', or it will get far more less 'peaceful'.
    verynearlypure likes this.
  10. Jan 3, 2021 at 3:59 AM
    TuffRuffDangerous
    San Diego, CA
    21 gallons.
  11. Jan 3, 2021 at 5:53 AM
    Tiedie
    David
    WFOY
    Just for fun.
    There is no gas left in the tank when empty before removal?
  12. Jan 3, 2021 at 6:57 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Unless something on your truck has been changed, you should have a 21 gallon tank.
    TireFire likes this.
  13. Jan 3, 2021 at 7:02 AM
    Key-Rei
    Key
    Florida
    Nope, stock gas tank, but even the one time I did run it out of fuel (mostly just to see how far running on the light would get me) it only takes 18 gallons. I think that one time it took 18.75. I put 19 in it after running it down past empty and that started the occasional cold weather evap code cycle, obviously over filled.
    :notsure:
  14. Jan 3, 2021 at 7:10 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Typically, I will drive about 360+/- miles before fill up, then I'll take on about 19 gallons.
    So, roughly I have about 2 +/- gallons remaining.
    The light is just a reminder to get my a55 to the pump.
  15. Jan 3, 2021 at 7:12 AM
    #35
    Key-Rei
    Key
    Florida
    360 per tank!? :eek:
  16. Jan 3, 2021 at 7:17 AM
    #36
    Knute
    Pretty consistent. Average MPG over the last 6 months is 19.1 mpg. Its been falling since Winter has gripped us and winter blend fuel hit in October. Now, I'm getting about 18 mpg.
    I may recover some of the MPG when I replace the U-joints and serp belt system. They are both getting questionable.
  17. Jan 3, 2021 at 7:56 AM
    #37
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    I put just over 20 in mine the other night...
  18. Jan 3, 2021 at 11:07 AM
    #38
    TuffRuffDangerous
    San Diego, CA
    Do any of you use an app or spreadsheet to track your MPGs?
  19. Jan 3, 2021 at 11:40 AM
    #39
    AustinMada
    WA.
    19 DCSB OR
    So......what happened?
  20. Jan 3, 2021 at 11:43 AM
    #40
    AustinMada
    WA.
    19 DCSB OR
    Haha saw this just now :rofl: got lost in all the back and forth on how many gallons this and that. Good shit man :thumbsup:
    omegaman2[QUOTED][OP] likes this.
