How far can you drive with the front axle only?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RecklessTLS, Oct 31, 2017.
  1. Oct 31, 2017 at 9:11 PM
    Pigpen
    Dan
    Northwest Montana
    You sir, are doing it right :hattip:
  2. Oct 31, 2017 at 9:13 PM
    Pigpen
    Dan
    Northwest Montana
    I drive highway speeds in 4x4 all the time in winter. You'll be fine in front wheel drive.
    Taco Tacoma likes this.
  3. Oct 31, 2017 at 9:46 PM
    Grindstone
    Grindstone Requires Adult Supervision
    Wasn't a Taco, but I drove a 4WD S10 all day on the front wheels after the front u-joint busted.
    Toyko Joe likes this.
  4. Oct 31, 2017 at 10:47 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    A few days ago, @Sub-Zero broke his driveshaft wheeling at Moab, Utah and drove home to Colorado. 6 hours across the Rockies on 35's.
    raco.the.taco likes this.
  5. Nov 1, 2017 at 10:36 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    SOOOOOO MUCH MISINFORMATION.
    Jezus fuck people.
    1. You can shift into 4high on the fly up to 60mph. Its right there clear as day in the manual (hell might even be on the placard card on the back of the driver sun visor)
    2. Stock front diff is an open diff, not a spool, driving on the freeway in 4hi with the rear driveshaft removed is 100% perfectly OK and poses no safety risk.
    OP You will be fine. Just dont be a dick driving around flooring it everywhere and you will be fine. Its going to drive a bit different and pull the steering a little weird but beyond that, its going to drive the same and poses no risk for the short term. I went 3 or 4 days without a rear shaft as i let some silicone dry in the stock CB with the shaft out of the truck.
  6. Nov 1, 2017 at 10:38 AM
    la0d0g
    running for the hills
    For crawling not hauling
    :thumbsup:
    So I was off by 5 mph :p :luvya:
    Subway4X4 and BassAckwards like this.
  7. Nov 1, 2017 at 10:39 AM
    nd4spdbh
    SoCal
    :drunk:
    la0d0g[QUOTED] likes this.
  8. Nov 1, 2017 at 10:42 AM
    SRQ_TACO16
    SRQ_TACO16 Well-Known Member
    David
    Sarasota, FL
    2008 Tacoma
    3rd gen SR5 wheels
    This was a while back in a mid 90s GMC, but my brother snapped his rear drive shaft and drove around for a few months in 4H till he traded the truck in. Never seemed to be an issue.
  9. Nov 1, 2017 at 10:44 AM
    Taco Tacoma
    Taco Tacoma Well-Known Member
    Dylan
    Napa CA
    '21 Cement SR5 4x4 DCLB
    '21 Nothing so far, I just bought the friggin thing!! '09 Silver SR5 Prerunner DCSB (sold) Dick Cepek rims, 33” Cooper AT 3’s, 24 in light bar, custom-made hitch step, sport headlights (on SR5 taco), Gator tonneau cover (looking for Best Top soft camper shell), real tree seat covers, weather tech floor liners, 6’ bed mat cut to 5’ (because the 6’ ones were the only ones available, alpine touch screen head unit, alpine 1100w amp powering 2 10” subs, upgraded door speakers (forgotten the brand), Magnaflow exhaust
    If you had actually read everything you would have see that he said he wasn’t driving a taco. So get your facts straight before saying some one is wrong
    Toyko Joe and Subway4X4 like this.
  10. Nov 1, 2017 at 10:47 AM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    Drive as far as you want, just be wary of increased axle wrap in the rear, and a rather different steering feel under acceleration. "Torque Steer" is the correct term I believe. I did it for 3 days when I was waiting on a replacement front yoke without any issues, just the above changes in drive feel.
  11. Nov 1, 2017 at 10:48 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Drove from alabama to charlotte, then charlotte to ECGS this way. No problemo
    Masshole_And_His_Taco likes this.
  12. Nov 1, 2017 at 11:02 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    This was in a jeep I drove to / from the trails and just to to get you more excited it did have a spool in the rear also
    I had no choice and had to drive it home and luckily my friends were the one who came up with using the high lift jack handle for the front driveshaft repair
  13. Nov 1, 2017 at 11:32 AM
    Subway4X4
    Lloyd
    NY/NJ
    Jeezuz fuck Matt. :boink:
    You were off by 6.99 MPH.
    My manual says below 62 MPH.
    Clear. As. Day.
    stickyTaco likes this.
  14. Nov 1, 2017 at 11:33 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Learn something new everyday. I thought you had to be stopped to shift into 4H, good to know!
  15. Nov 1, 2017 at 11:37 AM
    #35
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Might be a 2012+ thing. Mine will go in up to 60. And I've done 80+ in 4H, not gonna hurt anything
    cruxofthebisquit likes this.
  16. Nov 1, 2017 at 11:37 AM
    #36
    la0d0g
    I had to walk out to my truck just now and check the visor :D
    Subway4X4[QUOTED] and TACOVRD like this.
  17. Nov 1, 2017 at 11:38 AM
    #37
    la0d0g
    Amazing things happen when you read the manual.
    Subway4X4 likes this.
  18. Nov 1, 2017 at 11:46 AM
    #38
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    1st gens say 50mph and below to shift into 4H
  19. Nov 1, 2017 at 11:52 AM
    #39
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Come on, who does that?!?
  20. Nov 1, 2017 at 1:24 PM
    #40
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
