How far have you gone after 0 miles to empty??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimmyboy123, Jan 17, 2016.
  1. Jan 22, 2016 at 9:13 PM
    #41
    Metalnut
    Metalnut It's a clown world
    Adam
    North Alabama
    2016 Tacoma DCLB 4x4 TRD OR
    BP-51s, UCAs, BAMF sliders, SCS Stealth 6, 285 Wildpeaks, HIDs, LEDs, custom grille, hard top.
    That is an incorrect generalization. For example, my 1190 Adventure has the fuel pump in the bottom of the tank.
  2. Jan 23, 2016 at 7:35 AM
    #42
    FOXY 367
    FOXY 367 " PAIN IS LIFE'S GREATEST TEACHER "
    2016 Tacoma DC Long Bed TRD Sport 4 X 4
    None
    It's not worth the gamble to find out how far you can go after low fuel light comes on. The fuel injectors are cooled by the fuel flowing in them as they operate running them dry on a hot engine can cause damage to them by distorting them due to running dry in the at temperature engine In addition the fuel pump can suffer damage as well by running the tank dry. Best insurance for long life on fule system components is to never let the low fule light come 1/8 to 1/4 tank refills are best
  3. Jan 23, 2016 at 7:43 AM
    #43
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    All of you guys must live in places where there is a gas station every 20 miles or less?
    Rusty66 likes this.
  4. Jan 23, 2016 at 7:51 AM
    #44
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    That's the most laughable reasoning for not running dry I've ever heard. Letting injectors run dry in a hot engine will warp them? What the hell do you think happens when you simply turn your engine off after a long drive? No more fuel flow, engine still hot...
    Jesse H, Tharris242 and nevadabugle like this.
  5. Jan 23, 2016 at 8:10 AM
    #45
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    How many toyota fuel pumps?
    Rusty66 and drvn like this.
  6. Jan 23, 2016 at 8:49 AM
    #46
    FOXY 367
    None
    When the engine is shut off the injectors are closed the fuel that is trapped in the injector acts as a heat sink to dissipate the heat evenlly at the injector valve face to the surrounding surfaces it prevents over heating of the injector tip. When the injector is run try those surfaces over heat and are subject to warping that results in uneven seating and a disruption in the spray / atomization of the fuel as it enters the combustion chamber resulting in reduced engine performance and eventual injector replacement ....at lease that's what I was taught at fuel injection and pump school. @ USMC Automotive Engine, Transmission and Clutches Training.
  7. Jan 23, 2016 at 9:01 AM
    #47
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Sorry, I'm not buying it. I've no doubt that's what you may have been taught in school but there is damn near zero fuel at the pintle end of an injector, not much heat sink benefit to be gained there.
  8. Jan 23, 2016 at 9:06 AM
    #48
    FOXY 367
    None
    Go ahead and run yours dry then its your truck.
  9. Jan 23, 2016 at 9:07 AM
    #49
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I won't be, but thanks for the permission.
  10. Jan 23, 2016 at 9:11 AM
    #50
    FOXY 367
    None
    You're welcome.
  11. Jan 23, 2016 at 9:21 AM
    #51
    Metalnut
    Adam
    North Alabama
    Simma down fellas :)
  12. Jan 23, 2016 at 9:23 AM
    #52
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Half a dozen
  13. Oct 20, 2020 at 3:47 PM
    #53
    A1000Leaves
    A1000Leaves Active Member
    PNW
    2018 White TRD PRO
    Stuff and Things
    Old thread... however the 3rd gen Taco has a reserve of 2 gallons after reading zero. If you don’t believe me ask your dealer. The CPU reads zero after 19 gal has been used. This was explained to me by a head mechanic/foreman at Toyota when I asked. I’ve also confirmed with my own tests.
    TreeFortRichard, drvn and Rick111 like this.
  14. Nov 29, 2022 at 1:40 PM
    #54
    Justacos
    Justacos New Member
    17 offroad tacoma magnetic gray
    I just went 23 miles after "0miles." I didn't run out of gas. 75% of that was highway. Mostly flat/smaller hills in Florida. Other than a 3inch lifts, my truck is stock. I weigh 220lbs and have about 300lbs of tools/materials in my truck. Hope this helps.
    Tacospike likes this.
  15. Nov 29, 2022 at 1:44 PM
    #55
    Tacospike
    Two Trucks
    There are a few gallons after 0 miles to empty. 3 or 4?
    my tundra is about 6 after 0 to empty
  16. Nov 30, 2022 at 5:00 PM
    #56
    Snowie Taco
    Snowie Taco Well-Known Member
    2022 White Tacoma TRD OR
    King 2.5 w/ Remote Reservoir Dirt King Upper Control Arms Method Bronze Wheels 285/70R17 Toyo A/T Xpel PPF Full Truck
    I’ve filled up about 20.2 gallons and went about 40ish miles after e
  17. Nov 30, 2022 at 5:10 PM
    #57
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Have any of y'all even changed a fuel pump and noted it's not always completely submerged? Same argument about concerns of sediment being at the bottom of the tank. Every time you refuel, it disturbs sediment (if any) which will get sloshed around and mixed into the tank. This sediment, if any, gets taken care of by the fuel filter. There's also filters at the gas station pump.
    It's a fuel pump, not a piston.
  18. Nov 30, 2022 at 5:17 PM
    #58
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Don’t forget the fuel running through the pump is cooling it as well. While it probably runs warmer it’s not hurting it, the sediment is probably worse depending on how many microns the sock filter is.
  19. Nov 30, 2022 at 5:28 PM
    #59
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    53 miles. Near as I can tell there were three gallons left. I put 21.2 gal in that bitch.
  20. Nov 30, 2022 at 8:38 PM
    #60
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    my '06 shadow 1100 has a pump and carbs
