How fast can i drive in 4Hi?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RyansTaco311, Jul 11, 2019.
  1. Jul 11, 2019 at 2:56 PM
    RyansTaco311
    RyansTaco311 [OP] Member
    2018 Tacoma OR
  2. Jul 11, 2019 at 2:57 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
  3. Jul 11, 2019 at 2:58 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    Push the gas pedal all the way down and find out.
    edit: kidding. I've gotten mine going pretty damn fast on dirt trails (<50mph anyhow). I wouldn't go that fast on pavement because of binding issues but...
    I'm sure the manual has a number though... I'm way too lazy to check.
  4. Jul 11, 2019 at 3:06 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Usually been around 60mph is the top reccommended speed to shift the truck into 4hi from Toyota, but you can go as fast as the truck will normally go once in 4hi.
    Tight turns on pavement with 4wd engaged is not recommended as binding may occur.
    Personally, if you can drive 40mph+ safely, you shouldn’t need to engage 4wd at all
  5. Jul 11, 2019 at 3:20 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    You can drive as fast as you want in 4HI but you have to be under 60mph to engage/disengage it. Once in 4hi there's no set limit. People do crazy speeds offroad in the desert in 4hi.
    Although in most cases being in 4wd means you aren't driving in ideal conditions for higher speeds so that's something to consider.
  6. Jul 11, 2019 at 3:30 PM
    Desert Honda Squid
    Desert Honda Squid Fixer of stuff I broke
    Fredo
    New Jersey
    08 Silver TRD OFF ROAD 6MT
    Just to give you an example, for 2nd gen 6s speed MT 5th is the highest gear you can be in 4H. The fastest you can go in 2H/4H 5th gear is 127mph.
    The owners manual has a section about shifting and what max speed is in 2H, 4H and 4L. Read it to see what your 3rd gen limits are.
    musicisevil and eon_blue like this.
  7. May 8, 2022 at 12:59 PM
    Tacogeorge17
    Tacogeorge17 Well-Known Member
    George
    Socal
    2017 black Tacoma TRD OR manual
    I've done 80 in 4hi on the freeway I've got a 2017 TRD 4x4 OR 6spd manual
    Ngneer likes this.
  8. May 8, 2022 at 1:10 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    how fast do you want to go? do you have a sweet ramp to jump?
  9. May 8, 2022 at 1:24 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Driving in 4hi at freeway speeds is quite common in snow country.
  10. May 8, 2022 at 1:27 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    :burnrubber::mudding::oldglory:
    wilcam47 likes this.
  11. May 8, 2022 at 1:29 PM
    Tacoma Mike
    Southern Maine
    Vinny C, HisDad, Finn-2187 and 4 others like this.
  12. May 8, 2022 at 1:29 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I run at 50-55 max in winter, if it’s safe to go faster, I don’t need 4WD
  13. May 8, 2022 at 1:32 PM
    gudujarlson
    Minnesota
    Wut I thought 4wd helped me stop faster?
    TacoManOne, gillies66, Chew and 2 others like this.
  14. May 8, 2022 at 1:33 PM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    :thumbsup:
  15. May 8, 2022 at 1:34 PM
    gudujarlson
    Minnesota
    Read the manual again.
  16. May 8, 2022 at 1:34 PM
    eon_blue
    Azusa, CA
    That's the max speed to engage 4hi. Once engaged you can go faster than that.
  17. May 8, 2022 at 1:35 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It does, marginally, in some situations.
  18. May 8, 2022 at 1:40 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Just because you CAN do something doesn't make it a good idea. You're not supposed to be driving on pavement in 4X4 at any speed. If it is safe to drive over 25-30 mph you don't need 4X4. Even on wet or snow-covered roads 4X4 is doing more harm than good at those speeds. If you want to do that buy something with AWD.
  19. May 8, 2022 at 1:41 PM
    gudujarlson
    Minnesota
    You must not live in snow country.
    IrishRed, ghardy, LunarTeal and 9 others like this.
  20. May 8, 2022 at 2:03 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    ghardy likes this.
