how fast can i go with the real locked?(4x2)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by derekAV, Dec 4, 2009.
  1. Dec 4, 2009 at 2:21 PM
    derekAV
    derekAV [OP] Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    it says in the manual to only go ~15?..is that just a safety issue of will it damage anything?..i know its hard to drive with them locked...pushes the front end like crazy.
    and when i put it in neutral, hold the traction control for about 5 secs...what does that do? (LSD on or off?) when i do this, the beeping from the TC doesnt beep anymore..but it does make some squeaking noises..is this bad?..i tryed to read as much as i can but cant seem to find the info i need
    any info would be great help:D
  2. Dec 4, 2009 at 2:23 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    I assume you mean the rear.
    You can go as fast as you want - just don't try to turn. At all. The speed alone won't damage anything, but handling becomes risky and damage is possible with turning.
    Since (IIRC) the locker only engages in 4lo, your speed is going to be RPM limited more than anything else.
  3. Dec 4, 2009 at 2:25 PM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    thanks! i was just curious:eek:
  4. Dec 4, 2009 at 2:32 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    He's a prerunner, so speed won't really be limited. To the OP: don't use it unless your stuck. There's really no need for it, specially when your mobbing dirt and turning. Use it when one wheel may lose traction and you need the other to spin, such as when crawling.
  5. Dec 4, 2009 at 2:37 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I'm not condoning it or anything...... but......
    I've done about 80mph, rear locked, in desert washes... with turns. And it was fun. :D
    Also, the locker is still fine...
  6. Dec 4, 2009 at 2:40 PM
    jandrews
    Turning on sand I agree likely wouldn't be a problem. I still wouldn't make a habit of turns with the rear locked.
    True. Good catch. Missed that.
  7. Dec 4, 2009 at 2:41 PM
    jonny
    jonny Betty White Edition Heep ZJ
    same here.
    was in ocotillo wells last weekend, got into some soft stuff, engaged the locker...kept it on. hauled ass to the next hill.
    since you are a prerunner, you have to be going slow to engage it....but no real speed limit after engaged.
    -I abide all toyota restricions and guidelines though :p
  8. Dec 4, 2009 at 2:43 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Yes, only engage less than 3mph. Myself, I never turn the button on unless I'm full stop. Go only about 3mph or less until it locks (light will stop flashing, and you'll probably hear/feel it engage though it gets smoother over time).
    When I'm out in the desert in some rough stuff I usually just leave it on instead of constantly engage/disengage. It's not the best for it but... I'm lazy like that I guess.
  9. Dec 4, 2009 at 2:44 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    Pretty much keep it off on grippy surfaces. Sand, soft dirt, mud, loose gravel/dirt...it's all fine
    I used to keep it on full time when offroading cuz I hated turning it on and off with every entrance/exit of a technical spot but haven't done that lately.
  10. Dec 4, 2009 at 5:03 PM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    yea i was just in some thick ass mud the other day and wammed to mobb throug it fast lol
  11. Dec 4, 2009 at 5:06 PM
    BSPDX
    BSPDX Well-Known Member
    unless you grey wire... :)
  12. Dec 4, 2009 at 5:08 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    alot of jeep guys run locked rear diffs. Totally locked all the time. toyota is playing it safe but it wont hurt to run it even on the streets. Itll just rip up your tires.
  13. Dec 4, 2009 at 5:09 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Can't grey wire a second gen. It requires a lot more than snipping one wire.
  14. Dec 4, 2009 at 5:10 PM
    BSPDX
    That sucks... another reason for me not to trade up!:D
  15. Dec 4, 2009 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I bet the silver wire mod would work.......
  16. Dec 4, 2009 at 5:14 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Well, you can. It just requires a lot more than snipping one wire. (edited previous post)
  17. Dec 4, 2009 at 5:14 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    you again!
    :quickdraw:
  18. Dec 4, 2009 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :D
  19. Dec 4, 2009 at 5:27 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :eek:
  20. Dec 4, 2009 at 5:41 PM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    Those damn smileys make me laugh!!!
