How fast in 4WD High with no REAR driveshaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hualampeter, Jan 23, 2019.
  1. Jan 23, 2019 at 3:03 PM
    hualampeter
    hualampeter [OP] Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    Im curious, how fast can one go without a rear driveshaft with only front wheel drive on 4HI. I kept it under 55 seems fine.
    Alexely999 likes this.
  2. Jan 23, 2019 at 3:08 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    :mudding:6 mph tops, you go 7mph plus and your tranny will grenade.
  3. Jan 23, 2019 at 3:10 PM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    Uh no... Drove my 2005 Tacoma 55mph for a month on 4HI with no rear driveshaft.
  4. Jan 24, 2019 at 6:03 AM
    96carboard
    96carboard Well-Known Member
    He thinks he's making jokes.
    They aren't funny and just make him sound stupid.
    In any case, I'm not sure if you really mean "can", or if you actually mean "should".
    CAN: it CAN go just as fast in FWD as in RWD.
    SHOULD: it CAN go just as fast in FWD as in RWD.
    (pay attention: I didn't actually answer the "should" question.)
  5. Jan 24, 2019 at 7:21 AM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    Right but, the front diff are strong, no slip yoke on the front drive shaft. It's likely it could go faster than the 65 limit per interpretation of the manual. My RPM's were all normal, and didn't have any hiccups driving without a rear drive shaft.
  6. Jan 24, 2019 at 7:23 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    That 55-65 mph limit really only applies to shifting into 4HI, not necessarily how fast you can go after already being in 4HI
    That said, I would think if you're in 4WD, conditions are such that you shouldn't really even be going more than ~60...
    hualampeter[OP] likes this.
  7. Jan 24, 2019 at 7:57 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    I woudn't think the issue of speed would be with your front diff. I think the issue is going to be buring up your transfer case if you try to push it too hard to achieve really high speeds.
  8. Jan 24, 2019 at 8:02 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    hp / torque needed for cruising freeway speeds is minimal compared to the loads the diff will see off road.
    OP you should be fine to drive at just about any normal speed necessary in a FWD mode. I did it for a bit while doing some work on my rear shaft without issue for a weekend. Now i wouldnt make it a full time or very long distance thing but yeah you are fine to cruise at speed.
    Now id make sure to shift the transfer into 4hi while the trans is in park, you dont want to spin the trans up (even in neutral it will spin the output slightly just due to internal friction) and have the transfer case slam into gear. Shift to 4hi in park, then if the tcase isnt going in, shift the truck into reverse or drive and it will spin it enough to clunk in.
  9. Jan 24, 2019 at 8:04 AM
    Fuelman
    Fuelman Well-Known Member
    Winchester VA
    2014 Taco DCLB Sr5 4x4
    Ultraguage
    You can go as fast as you want at your own risk. The front half of the drivetrain is not designed to carry the full load of the truck. I’d be taking it easy no hauling/towing/ hard acceleration.
  10. Jan 24, 2019 at 8:07 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  11. Jan 24, 2019 at 8:08 AM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    It make sense that the front diff can handle normal highway speed without issue since 65 and lower is the max mph for engaging the 4 high. Sweet thanks y'all.
  12. Jan 24, 2019 at 8:08 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    I'll bite, WTF happened to the rear driveshaft?
  13. Jan 24, 2019 at 8:08 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Save the retard comments for your third gen threads. No need to shitpost when someone is asking a genuine question.
  14. Jan 24, 2019 at 8:10 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    OP I drove my truck for months in front wheel drive. It ain’t gonna care as long as it’s street driving.
  15. Jan 24, 2019 at 8:15 AM
    hualampeter
    Peter
    Chester, MD
    TRD Off Road
    The previous Drive Shaft had issues. Vibration, knocking, moving away from the spline. I had a billet aluminum CB, had crazy vibration at 58 mph and above. I got a new drive shaft built with a double cardan behind the Carrier Bearing to double my angles.
  16. Jan 24, 2019 at 8:37 AM
    AS73
    AS73 Active Member
    Tim
    Huntington Beach
    2012 Tacoma 4x4 TRD
    If you have a open front diff... It shouldn't be a problem doing the speed limit!
    I've driven like this after busting my rear drive shaft on a trail. Over 100 miles to home.
  17. Jan 24, 2019 at 8:55 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Why oh why in the hell would anyone do this or want to do this???? I could see doing so for a short distance if the rear driveshaft broke or was disconnected but no way would I do it daily or on a regular basis. If the drive shaft needed replacement I’d sideline the truck until I could get it replaced. There’s potential for damage here.
    I may be wrong but after a certain speed doesn’t it electronically disconnect the 4wd and thus the front transfer case?
    I still don’t get why anyone would do this other than temporarily in an emergency.
  18. Jan 24, 2019 at 8:57 AM
    coopcooper
    alberta canada
    what lol, ive been up to 90mph in 4wd, why would it automatically disengage its not a chevy
  19. Jan 24, 2019 at 9:04 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You could not be more wrong.
    MolonLabeTaco likes this.
  20. Jan 24, 2019 at 9:04 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You are wrong.
