how freq'ly do you check your PCV valve and throttle body?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undermoneyed, May 6, 2012.
  1. May 6, 2012 at 3:30 PM
    undermoneyed
    undermoneyed [OP] aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Haven't found anything in Haynes Repair Manual regarding PCV valve and throttle body regarding scheduled maintenance :confused:. Any info on this would be much appreciated? Thanks in advance.
    Mark
  2. May 24, 2012 at 11:01 PM
    toyotaT32
    toyotaT32 Well-Known Member
    Thomas
    Palmer, Alaska
    3 inch revtek in coil spacer, all pro bumper, smittybuilt 8000 winch, 265/75/17 BFG AT, cookie monster stuffed animal in bumper... UPDATE 10/17/12.... OME886 Coil lift with spacer. UPDATE 9/6/13..... Plasti dipped 17inch eagle alloy wheels. 285/70/17 Goodyear Duratracs, 6 bulb rigid industries LED D2 lights
    Idk honestly man, but since you brought it up I should probably look into it.. Haven't found a Haynes Manuel for a 2nd gen taco. Just a chilton.
    Do you know anything on a throttle body spacer from toytec?
  3. May 25, 2012 at 2:19 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island--->Oahu, Hawaii
    10 AC TRD OR 4x4 BSP; 08 Reg Cab 5 spd 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Smoked Eagle Eyes Ebay LED Tails | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    I think it'd be a good practice to pull the PCV and take a look at it's condition every 30k miles, given "normal" driving conditions.
  4. May 25, 2012 at 2:24 AM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    05 AC Prerunner 6-speed
    k&n air filter, weathertech digital fit, TRD 6-speed gray knob, undercover bed cover, flowmaster american thunder dual exhaust, URD short shifter, 5100's set at .85, Grillcraft, black surround grille(with SJ stripe)
    Under Normal, I think this would be accurate, but under more intense conditions I'd say every 10k
  5. May 30, 2012 at 7:31 PM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Can't help you with the throttle body spacer Thomas.
    Thanks for the input guys.
    Mark
  6. May 30, 2012 at 7:34 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Dealer says replace pcv valve every 30k... where and what is it?
  7. May 30, 2012 at 7:40 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Good question, in for answer :)
  8. May 30, 2012 at 9:09 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Never
  9. May 30, 2012 at 9:11 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    I just clean off my MAF and TB every 15,000 miles. It's surprising how dirty they get.
  10. Jun 1, 2012 at 10:14 PM
    808TRDTaco10
    Justin
    It's located on the valve cover. From what I understand, the PCV valve regulates the flow of unburned fuel vapors and combustion byproducts back into the intake manifold to be reburned.
    The PCV valve is important, since if it gets clogged, the engine may stall, be sluggish, or have a hard time starting. Also, the trapped byproducts won't have a way to escape, causing sludge problems. I know this first hand since my father's T100 had issues with stalling. It turned out to be a clogged PCV valve. Unfortunately for his truck, the engine is already pretty sludged up because the PCV was clogged for some time. :(
