how hard can u drive with e-locker on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dellosa89, May 7, 2009.
  1. May 7, 2009 at 11:45 AM
    Dellosa89
    Dellosa89 [OP] Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    I have a 07 TRD Off Road taco and i was wondering when im out messing around at the desert i need the e-locker on but is it bad that im driving it over the 5 mph recommendation my average speed is around 15 to 30 mph.
  2. May 7, 2009 at 11:50 AM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    go hard or go home!!!!! :burnrubber:
  3. May 7, 2009 at 1:02 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    That speed should be fine. Just use your brain and don't drive it balls to the wall.
    Also, don't make sharp turns on immovable surfaces. Try to make them in sand, loose rock, dirt, etc.
  4. May 7, 2009 at 3:11 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    The most critical time is in transition from unlocked to locked.
    looking at the drawings, it seems to be engineered pretty well in the locked configuration.
    I'll drive minimum maintenance roads 30-40Mph with it locked and I haven't had problems.
    But true engineering tests for longevity is in-service use no matter what the computer models say!
  5. May 7, 2009 at 3:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i had my prerunner.....as well as the locker in my 4x4 now......i drove on pastures and such up to 40 mph without a problem. just dont use the locker on pavement, and be sensible with it.
  6. May 7, 2009 at 3:48 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I accidently drove 75mph on highway for 30 miles with it engaged...:eek::eek::rolleyes: Still going strong.
  7. May 7, 2009 at 5:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have been locked going much faster than 40 mph on hard packed dirt. Only thing I have heard of that will destroy the locker is by useing the E-brake to initiate a slide on asfault, then spinning donuts. If your on dirt or such, your fine.
  8. May 8, 2009 at 6:24 PM
    Dellosa89
    Brian
    Murrieta CA
    ok yea i only use the locker when im in loose dirt, sand, mud, etc so thanks for the feed back
  9. May 8, 2009 at 6:29 PM
    ComaTosin
    ComaTosin The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    ha ha ha. Me too. i am glad to hear that someone else did this. i was driving back from the dealership when i bought it new and the freaking locker button is right beside the fog lights. So being unfamilar with the set up i pressed the locker button, got on the highway and drive 17 miles home. I noticed once i got into my nieghborhood what i had done.
    Still going strong 3.5yrs and 30k miles later.
  10. May 8, 2009 at 8:22 PM
    Packman73
    2007 TRD Off Road
    Yeah, pretty embarrassing.
  11. May 8, 2009 at 9:23 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I think that it won't engage/lock unless you are going under 5 or 15mph, but once it's locked you can go as fast as you want... however, it will only engage in 4Lo on the TRD-OR (unless you modify the wiring/switch), and in my opinion if you need to drive faster than 15mph you probably don't need to be in 4Lo or have it locked. The PreRunners with lockers are 2wheeldrive and can be used/driven differently than the 4x4TRD
