How hard is 3800 RPM at extended distance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1776Taco, Sep 29, 2020.
  1. Sep 29, 2020 at 12:54 PM
    #41
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    My motorcycle turns 4500 rpm at 80 mph for hours on end. If you maintain your truck according to the Toyota recommendations, that 3800 rpm should be fine.
    1776Taco[OP] likes this.
  2. Sep 29, 2020 at 12:56 PM
    #42
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    The trailer in question is equipped with brakes, right? I tow regularly as well, generally in my Silverado which is the Tow Rig of my fleet. I rarely go faster then 70. Life’s too short to end-up in a ditch on the side of the road.
    Boghog1, Junkhead and Thatbassguy like this.
  3. Sep 29, 2020 at 12:56 PM
    #43
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    We are ass holes that don't want to see anyone die on the highway. Whether that is you or the innocent person that you hit.
    "Toyota recommends that the vehicle-trailer speed limit is 65 mph(104 km/h) on a flat, straight, dry road. Do not exceed this limit, theposted towing speed limit or the speed limit for your trailer as setforth in your trailer owner’s manual, whichever is lowest. Instabilityof the towing vehicle-trailer combination (trailer sway) increases asspeed increases. Exceeding speed limits may cause loss of control."
    also to note your original question... "If you tow a trailer, your vehicle will require more frequent maintenance dueto the additional load. (See “Owner’s Warranty Information Booklet” or“Scheduled Maintenance Guide”/“Owner’s Manual Supplement”.)"
    Carry on...
  4. Sep 29, 2020 at 1:04 PM
    #44
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    OP, can you fold the gate down forward? If you're not already doing that, it will help. Pulling those little utility trailers with the gate up is like pulling a parachute behind you.
  5. Sep 29, 2020 at 1:12 PM
    #45
    Glamisman
    Glamisman Well-Known Member
  6. Sep 29, 2020 at 1:17 PM
    #46
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    Who the F'k drives 80mph with a trailer in tow?!!!
  7. Sep 29, 2020 at 1:52 PM
    #47
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The only thing better then a rust thread is a towing thread.
    OP I’m surprised that you find constant 3800 rpm less annoying than occasional shifting to get up hills, pass cars, etc, but I have a 6MT so I might enjoy shifting more than you. :)
  8. Sep 29, 2020 at 1:56 PM
    #48
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Slow down...
    RedWings44 and Junkhead like this.
  9. Sep 29, 2020 at 4:31 PM
    #49
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Michiganders lol
    OP:
    Just because you can, doesn't mean you should. Especially when the manual suggests not to. Equipment wise, I only imagine you will just need to change fluids a little sooner unless you're running into overheating issues, and it sounds like you aren't.
  10. Sep 29, 2020 at 5:03 PM
    #50
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I can tell you my v6 likes S5 ECT as long as your on fairly level grades when towing. It'll run 65-70 mph fairly comfortably. I think it'd be a different story pulling the same load through the northway of the adirondacks in upstate ny.
    Boghog1 likes this.
  11. Sep 29, 2020 at 6:49 PM
    #51
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    As others have said, it's your trans and fluid that probably took more of a beating. In the hills of NC this past weekend, not going fast uphill, not towing, granted with OR with oem cooler, I see torque Temps going up to 212-219f. Pan Temps were in 190 range. They didn't stay there long but the more you stay at that load, the hotter things get.
    So at that speed and lower gear, you're putting more strain on trans and drivetrain than the engine. Change fluid more often along with diff and have a beer.
