How hard is a transmission oil change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JohnnyUtah, Feb 26, 2011.
  1. Feb 26, 2011 at 2:19 PM
    JohnnyUtah
    JohnnyUtah [OP] New Member
    Los Angeles, CA
    01 V6 PreRunner
    Hey everyone, I used to do all my own maintenance on my old classic car but since getting my Tacoma I haven't really done anything. I need my transmission oil changed and wanted to see if it was manageable. Would really appreciate the advice. Thanks.
  2. Feb 26, 2011 at 2:30 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    cant be anything like the gen2.....thats like rocket science
  3. Feb 26, 2011 at 8:09 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
    x2 on this question...
    but more in the line of how hard is it to do the flush? drop pan etc...
    what about the rear dif?
  4. Feb 26, 2011 at 9:01 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
  5. Feb 26, 2011 at 9:15 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    to much like work. its worth payin to have it done
  6. Feb 26, 2011 at 9:43 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    dang...haha that was blunt.
    I guess I'll be droppin' 200+ for the stealership to flush the trans and dif :(
  7. Feb 26, 2011 at 9:53 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    its too easy to change fluids..nobody should have to have a stealership do that. there is a lot of how tos on here for fluid changes... check em out
  8. Feb 26, 2011 at 9:53 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    didnt mean to be blunt but its the truth
  9. Feb 26, 2011 at 9:56 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    I read several write ups on the trans fluid...it seems easy to do, but easy to mess up also...
    if I buy the fluid and filter I might see if I can get some help from a tech that works at my gf's family ford stealership...they lemme use their lifts sometimes!!
  10. Feb 26, 2011 at 9:58 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    its worth a shot
  11. Feb 26, 2011 at 9:59 PM
    jcremeans11
    jcremeans11 Well-Known Member
    Jon
    Ohio
    01 Tacoma SR5
    Spectre Cold Air Intake, Michelin XLT's (265/70/16), Escort Solo S3, Grounded Throttle body
    tranny isn't that hard, it's just getting the right amount of fluid in. my manual was about half a quart or so lower than what the dipstick read, which lead to me stopping and the transmission basically shutting down a couple times, so just make sure you're dipstick reading is correct, whether it be hot or cold.
  12. Feb 26, 2011 at 9:59 PM
    CraigTRD
    CraigTRD Canadian in the South
    Craig
    London, Ontario, Canada
    Tacoma
    6" FabTech Lift, Custom rear leaf packs, RedLine gas hood props :D, Hockey Stick Canadian Flag Mod. 2012 Front
    Ok, I'm in Fresno for the week, anyone that wants me to change their auto tranny fluid, come to Fresno and I'll do it in the parking lot of the hotel.
    It's that easy.
    I brought my tools with me, I'm here for work.
  13. Feb 26, 2011 at 10:00 PM
    CraigTRD
    Craig
    Tacoma
    If you know how to check the dip stick, this isn't an issue.
  14. Feb 26, 2011 at 10:00 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    worst case scenario I straight out pay one of the techs under the table to walk over and do it for me...just easier to deal with a toyota dealership that I can be more upfront with whereas the family dealership is helping me out so I can't really make any demands ya know!
  15. Feb 26, 2011 at 10:18 PM
    gjbonner
    Guy
    Northern Idaho
    if youve changed engine oil then you can do this...add and check dip stick, add some more and check dip stick. you'll be fine :)
    Once you do this stuff you'll wonder why you ever paid someone.
  16. Feb 26, 2011 at 10:21 PM
    DCtaco05
    DCtaco05 Well-Known Member
    dustin
    petaluma
    05 tacoma trd
    bone stock.. not for long
    the rear diff is super easy. there is a drain and fill plug. its a 24mm size plug pull both of them and fill it back up.
    the tranny is pretty easy too. you dont have to change the filter on it, however it would be smart to. there is a drain plug on the transmission pan as well.
    if it is a manual trans its the same thing as the rear diff
  17. Feb 27, 2011 at 6:50 AM
    mike sacc
    mike sacc Well-Known Member
    r.i.
    2001 tacoma reg cab, 2009 tacoma dble cab shb
    just changed all the driveline fluids yesterday. the front diff took longer than all the rest together. had to take down the skid plates and there wasnt much room for the squeeze bottle. had to tuck the bottle up inside the fan shrowd with a piece of hose on it.buy a quart or 2 extra its almost impossible to get all the oil out of the bottle.
  18. Feb 27, 2011 at 7:03 AM
    CraigTRD
    Craig
    Tacoma
    You can get a little push-pull pump from your local auto parts supplier to pump the fluid out of that bottle, into the rear diff.
  19. Feb 27, 2011 at 7:03 AM
    dustinclm
    dustinclm Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    rear diff - you need 24mm socket. first remove the FILL PLUG then drain plug and let drain. re-install drain plug and add fluid until it overflows and let it flow throught the diff and then add some more until it overflows again then install fill plug and then you are done. get lsd additive if you need it. all info i found on this site.
    transmission - drain and fill to proper level on dip stick - some may say to clean the screen also- there could be more to this but i dont think there is
  20. Feb 27, 2011 at 7:05 AM
    CraigTRD
    Craig
    Tacoma
    ...and then check it after rotating the wheels....I'd check the rear diff after a drive. That fluid is pretty thick.
