How hard is it to change a prerunner to 4X4
Discussion in 'Technical Chat' started by Keith13, Dec 16, 2009.
  1. Dec 16, 2009 at 9:35 PM
    Keith13
    Keith13 [OP] New Member
    Phoenix, Arizona
    02 3.4L Prerunner
    Is it first of all possible to change over and is it worth all of the hassel to do? It looks like I will be keeping this truck for a while and I do a fair amount of off roading, but need the 4X4. Getting stuck usually in the sand is a drag. Could any one out there help? Thanks
  2. Dec 16, 2009 at 9:43 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Trade in your prerunner and buy a 4x4...
  3. Dec 17, 2009 at 2:31 PM
    The Parts Whore
    The Parts Whore Slinging parts since '03
    Its not hard doing the swap, just hard and time consuming sourcing out all the necessary parts.
    I'd also recommend selling the Prerunner and buy a 4x4.
  4. Dec 17, 2009 at 2:34 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    Huy is right...in and of itself the swap is not hard
    the problem is sourcing all of these parts
    1. 4x4 tranny w/t-case and shifter
    2. front diff w/ front mount & mounting brackets
    3. spindles/hubs
    4. cv axles
    5. front d-shaft
    6. 4X4 Rear D-shaft (it's about 11 inches shorter than the 2WD)
    7. Transmission Mount on crossmember (2WD is different)
    8. Floor shifter plate (you can try to cut yours but I found it easier to just get a 4WD one)
    9. 4WD shifter boots (one is rubber that goes under the truck and the other is fabric for the interior)
    10. Interior plastics
    11. Speed sensor (some 4WD trannys dont come with one)
  5. Dec 17, 2009 at 2:36 PM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    Don't listen to them.. It's Super Easy.. for $100 Ill sell you my Mudflaps off of my 4x4.. you install them on your truck.. and Poof to the untrained eye you have a 4x4... also removing the PreRunner Eblem off of the back
  6. Dec 17, 2009 at 2:36 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    how much do you think this would cost?
  7. Dec 17, 2009 at 2:37 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    your 4x4 flaps wont fit
    a couple of grand...depending on how much you spend on the parts
  8. Dec 17, 2009 at 2:42 PM
    AFButters
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    oh yeah.. we can make them fit
  9. Dec 17, 2009 at 2:49 PM
    kinkrider101
    santa barbara
    wheels and tires
    i want to do this but its alot of work
  10. Dec 17, 2009 at 2:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you're someone who's mechanically inclined and very familiar with vehicles and how they work, PLUS having garage space and bookoo amounts of tools available at your fingertips....it's something you could do.
    But chances are....
    If you gotta ask "How hard is it?" - then you're probably biting off more than you can chew.
    If you don't have any idea on HOW do to it....then sell the prerunner and buy a 4X4 or start doing research on LOCKERS.
  11. Dec 17, 2009 at 2:54 PM
    rd263
    rd263 Banana Republic
    Southeast of Disorder
    2006 SW SR5 4X4 AC
    Billy 5100's front,5% tint rear,20% sides,35% full front,Kenwood head unit,DRL mod,AFE CAI,Thule rack system,TSB rear leaf upgrade,Hella headlamps,Vent visors,Led brake lamps,Led backup lamps,clutch squeak TSB,TO bearing fixed,Debaged,100 watt fog lights ,Popnlock,shorty antenna,door sill protectors.
    Just buy a 4x4 like you should have done in the first place :D
  12. Dec 17, 2009 at 3:02 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Real Easy actually... go to the dealer... find a salesmen and say this exactly. "I'm made a huge mistake... I thought a Prerunner would have worked for me but now I regret my stupid decision, I'd like to trade this in for a 4WD."
    It will save you money and time by just trading it in
  13. Dec 17, 2009 at 3:03 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    sometimes its not easy for people to just up and change their vehicle
    be it credit...or add-ons...or whatever...
    and janster...id disagree about if you have to ask then its not for you
    Hillbilly did his in his driveway with...for the most part...basic tools...you might need to buy a jack and have a buddy...but its not extremely difficult mechanically
  14. Dec 17, 2009 at 4:25 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I guess... probably should have thought that thru when he bought the prerunner. Honestly its more a pain in the ass then most would guess, I personally reccommend trading it in, otherwise, its going to be more expensive (unless of course you can do all the labor yourself).
    4WD ftw...
  15. Dec 18, 2009 at 4:11 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    his needs or finances may not have supported buying a 4x4 at the time...or maybe he was given the truck
    and on an 02...its not necessarily going to be "cheaper" to trade it in and get stuck in another car note for 3/4/5 years
    $2000 to get 4wd...with possibly manual hubs...and the satisfaction of doing something yourself vs. $30K for a new truck and having to go thru the mod process again
    +1 for attempting the swap yourself
    OP...there are several threads on ttora concerning these conversions and the info is pretty readily avail when youre ready to do the swap
  16. Dec 18, 2009 at 5:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. DIY. Its not too hard, just time consuming.
  17. Dec 18, 2009 at 6:18 AM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    I did exactly this
  18. Dec 18, 2009 at 2:40 PM
    Tdup
    Tdup Well-Known Member
    Trey
    Columbia, SC
    2.5 in. Ready Lift, 265/75/16 Cooper STTs, 18% tint, USA Spec iPod interface, Wet Okole seat covers, Husky mats, Rear Suspension TSB, Black Cam-Locker toolbox, Secondary air filter removed-AFE prodryS, 55w 5000K HID Headlights, 35w 4500K HID Foglights, Int. Wiper Mod.
  19. Dec 18, 2009 at 2:41 PM
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    the swap is pretty straight-forward, its pretty much plug-n-play. i think KaleCoAuto makes a kit.
  20. Dec 18, 2009 at 6:14 PM
    Tdup
    Trey
    Columbia, SC
    the swap is not "plug and play" you are better off just selling your truck and buying a 4x4, don't mess up a perfectly good truck by trying to swap it over, sell it while you can get some $$ for it and buy you a 4x4. THIS IS NOT AN EASY SWAP!!
