how hard is it to remove
Discussion in '1st Gen. Tacomas (1995-2004)' started by kmrofka, Nov 21, 2008.
  1. Nov 21, 2008 at 10:43 PM
    kmrofka
    kmrofka [OP] Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    how hard is it to remove the front bumper and skids
  2. Nov 22, 2008 at 1:25 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    its not
    simple metric sockets will get the job done
  3. Nov 23, 2008 at 3:28 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    what bolts do i need to remove to take off the bumper i removed the skids already
  4. Nov 23, 2008 at 3:46 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Go look.
  5. Nov 23, 2008 at 3:48 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    It's really not hard. Suckers are on TIGHT though, soak them in PB Blaster overnight. I'd also pull the negative cable off the battery and wait a few minutes (book says minimum two) so you don't accidentally set off the airbags.
  6. Nov 23, 2008 at 3:59 PM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    After you get the plastic skirt bumper off........you should be looking at a square tube about 2 1/2 feet long. There is holes in the tube that you need to slide the socket into it to get to the bolt head IIRC. Same thing with the air bag cans if your takin them off too.
  7. Nov 24, 2008 at 2:07 AM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    well i took alook and all i can see is two bolts on each side of the bumper that go to the frame if i remove those is that it?
  8. Nov 24, 2008 at 6:43 AM
    Cobra69
    NO, there are a couple more hiden by the bumper......start looking for circular holes in the bumper or mount brackerts I believe there are 3 bolts per side.
  9. Nov 24, 2008 at 8:45 AM
    JimBeam
    JB
    2015 Tundra
    x2
    its been awhile since i took mine off so i cant say for sure where they are or how many...
    best thing to do is get up under there and start looking
  10. Nov 24, 2008 at 8:52 AM
    Cobra69
    there are 2 per side that bolt into the bottom of the frame rail, the other one per side i believe is on the front of the can INSIDE the can its self. There should be ahole in front of the can to fit a socket.
  11. Apr 6, 2010 at 8:39 PM
    ywen
    ywen Well-Known Member
    When removing the front bumper, are you at risk of damaging the airbag sensors?
    Also, how heavy is the front bumper when sliding it off?
  12. Apr 7, 2010 at 4:36 AM
    JimBeam
    JB
    2015 Tundra
    the front bumper weighs like 15 lbs or so...its light as all get out
    i doubt you run the risk of bothering the airbag sensors
  13. Apr 7, 2010 at 2:36 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    holy crap i forgot about this thread
  14. Apr 7, 2010 at 6:41 PM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    lol :rolleyes:
