How hard is it to replace front shocks without a spring compressor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, Aug 27, 2025.
  1. Aug 27, 2025 at 7:54 PM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    Looking to replace front and rear shocks work Bilstein 4600's. I've watched the Team Oil Drop YouTube video on changing the front and it looks pretty easy but the comment section is filled with horror stories. Any tips before I get in there?
    Pretty decent mechanic skills but I've never done shocks. On other cars I've done control arms, sway bar links, replaced components like radiators, alternators, and AC systems, etc. I'm in a 2017 SR5 V6 2WD.
  2. Aug 27, 2025 at 7:56 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Get a set of spring compressors from your local autozone/napa/advance auto, read the instructions and be careful using them. You'll need some method to compress the spring for reassembly.
    bassmusic likes this.
  3. Aug 27, 2025 at 7:59 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Not hard at all. Loosen the lca bolts to allow for more droop. Place the frame on jack stands. Place a jack under the lca. Remove the top center bolt from the shock and lower the jack holding the lca. Reassemble using the jack to lift the lca. I've done it several times with zero issues. There's no where for anything to fly.
  4. Aug 27, 2025 at 8:06 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    bkhlrTaco's and wilcam47 like this.
  5. Aug 27, 2025 at 8:07 PM
    999 Well-Known Member
    Texas
    As above, I think it’s easier without a spring compressor.
    or atleast than with a cheap spring compressor.
    Rock Lobster and wilcam47 like this.
  6. Aug 27, 2025 at 8:08 PM
    Texas
    And buy or borrow a 18mm ratcheting wrench for the top shock nuts, they are the devil…
    wilcam47 likes this.
  7. Aug 27, 2025 at 8:13 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Did mine with a floor jack and jack stands.Much easier than I expected it to be and don't see any advantage to using a spring compressor.
    Sparky 97Runner and Kolohe07 like this.
  8. Aug 28, 2025 at 11:13 PM
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    The rears are easy. do those first . Why not 5100s?
    I replaced my front shocks a few months back. It's not that hard. Hit all the nuts and bolts with PB blaster a few days before.
    Use Team oil drip video.
    Take a photo of the tools needed, and keep your iPad in the garage to refer back to during the job. I slowed mine down to 3/4 speed.
    Do the first side , have lunch, come back do the other side, then torque it all down.
    You will be glad you did it yourself.
    You can dooo it :thumbsup:
  9. Aug 29, 2025 at 2:28 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    If you are trying to compress the spring, there is the method of using the weight of the truck to compress it.
    You will need some clearance, so disconnect the lca from the rotor/spindle and the sway bar. Raise a floor jack under the lca's knuckle to load the suspension. While loaded you release the nut that keeps the assembly together then slowly jack up the truck, the spring would then decompress without much effort.
    Swap new spring and compress it by doing the reverse. Imo the easiest, safest and fastest way to swap springs.
  10. Aug 29, 2025 at 5:31 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Advantage is safety. If your jack slips off that LCA, heaven help you.
    Chew, Toy_Runner and TS4x4 like this.
  11. Aug 29, 2025 at 5:42 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I've done it before removing stock shocks and installing OME Nitrochargers, fairly easy and drama-free with a hydraulic jack that can be lowered slowly. See video:
    The only limitation with this method is with much stiffer/longer springs, where the truck begins to lift up before the spring is compressed sufficiently for you to install the center shaft nut.
    Sparky 97Runner likes this.
  12. Aug 29, 2025 at 5:58 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Not likely to happen. It's a stable 100+ lb jack with 4000-6000lb capacity vs the forces of a single spring. The swivel plate is concave, acting on a convex feature of the LCA end forging. No riskier than using the jack for any other work on the vehicle.
    Even if it does happen, the shock is still bolted to the LCA on the bottom. At the top end, the shock and spring are constrained by the UCA and knuckle, so the spring can't fly out.
  13. Aug 29, 2025 at 6:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Yes but I’d still find a way to hurt myself.
    Chew, Toy_Runner and b_r_o like this.
  14. Aug 29, 2025 at 6:34 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Aftermath of installing OME 887 coils without a spring compressor - 3 damn mosquito bites on my forearm!
  15. Aug 29, 2025 at 7:55 AM
    Sungod
    St Augustine
    You are right. People waste money on spring compressors. A jack is solid. No chance of it slipping out. And I mean that spring? It is only designed to support several thousand lbs. It would never take someone's face off if it got loose. Safety is for cowards.
    TS4x4 likes this.
  16. Aug 29, 2025 at 8:00 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    This x100
    just because 10 people did it “safely” with floor jacks doesn’t mean person 11 isn’t going to end up a statistic. Springs are no joke and one little slip of a jack can send you to the ER/great gig in the sky.
    kinda shocking to see YouTubers encouraging using the shock mount and LCA as a spring compressor and calling it safe. Idk what their actual liability would be but I feel like they’re opening themselves up to potential lawsuits. Even if Joe YouTuber did it safely doesn’t mean the mouth breathers watching the video can. Sure some bad advice can simply lead to benign outcomes. But here? People can literally die if the jack slips and the spring goes flying, truck rolls, etc.
    Also I think there’s two conversations happening in this thread. One is about swapping springs and the other is people chiming in about swapping the entire coil assembly pre configured. Two very different things.
    Chew likes this.
  17. Aug 29, 2025 at 8:19 AM
    Fish Taco 4x4
    Fish Taco 4x4 Well-Known Member
    NC
    2013 TRD OR
    265/70/17s
    I felt way more comfortable using the weight of the truck to compress the springs than using the rental spring compressor that you get from an auto parts store, I’ve done both. There’s an inherent risk you take anytime you lift a car off the ground but I’m having trouble seeing how the “spring goes flying” when the lower shock bolt is secured and the spring is caged in by the UCA and shock tower. Anything is possible though!
  18. Aug 29, 2025 at 8:24 AM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    why are you underneath the truck lmao ive done the method of using the trucks weight more then i can count on my hands! it works every single time without issues.
  19. Aug 29, 2025 at 8:41 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'd rather do the jack-to-LCA method over the cheap compressors any day. I just use redundant stands to hold the front of the truck and a good 3-ton jack to hold the control arm. The proper wall-mounted compressors are safest, but the LCA method is a solid alternative. Those hand-tool compressors are a time bomb waiting to kill someone.
  20. Aug 29, 2025 at 8:50 AM
    Calamity_taco
    Jacob
    yuuup i borrowed one recently do adjust the fox 2.0s for my f150 (not easy to do the lca method) and low and behond the stupid washers that help hold broke as i was tighting it down and it fell off... had to go return it back and get a different one to fix the mess up from that one
