How heavy a horse trailer can I safely tow?
Discussion in 'Towing' started by judyc135, Apr 29, 2012.
  1. Apr 29, 2012 at 11:49 PM
    judyc135
    judyc135 [OP] New Member
    I have a 2010 Access Cab, 4WD, 6 cyl with tow package which I bought specifically to tow a horse trailer...I love driving the truck but couldn't justify the purchase of the Tacoma just for fun.
    I recently bought a trailer that weighs 1900lbs and the two horses weigh about 1800lbs...problem is my horse is claustrophobic in this type of trailer and I'm thinking of selling it and getting a different style that is also slightly bigger. I know the truck is rated to tow 6,500lbs.
    How high in weight for a new trailer do you think I can safely go, I'm feeling pretty cautious about this decision? Thanks!
  2. Apr 29, 2012 at 11:53 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    these trucks will tow 6500 but getting up there is not fun, acceleration braking and handling all deteriorate going up in weight. IMO if your going bigger you may want to consider a full size -- if it was me a diesel.
  3. May 1, 2012 at 6:13 PM
    judyc135
    Thanks for your responses. I was thinking of going no higher than 2,500 lbs in weight with a new trailer. What do you think?
    Yes, a bigger truck would open up all kinds of trailer options but I don't want to drive anything larger because of the size and I'm already in shock at the gas pumps after driving a Corolla for 19 years.
  4. May 1, 2012 at 6:35 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I towed my 4Runner a month or so ago, which was almost the max tounge weight and tow capacity with the upgraded tow package, and the truck did just fine up/down steep grades. I was actually pretty impressed. 300 mile trip and the only thing I can complain about was the 15mpg (which wasn't even that bad!) I was being very safe and driving the 55mph speed limit cause it was my first tow with the 2012.
  5. May 2, 2012 at 11:52 PM
    judyc135
    I can find out the tongue weight from the trailer manufacturers but I'm not sure how that figures in to the safety calculations with respect to the truck?
    My horse and his buddy are not very big, together they only weight about 1,800 lbs.
    By the way, so far the people I've talk to at the Toyota dealership are not too well informed on this topic!
  6. May 3, 2012 at 12:07 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    75% of tow rating to be safe and comfortable.
  7. May 3, 2012 at 12:54 AM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    I used to pull what i believe to be a 3,000lb trailer (2horse, steel) with two 1,000lb horses in it. I have a 2006 V6 with towing package. I also used a weight distributing system on my truck and trailer to help well, distribute the weight so it is not all directly on the tongue. I did not use electronic breaks (like i did with my 4runner) but was just careful to break early and did not encounter any problems.
    yes my trailer was fugly but it was functional :)
  8. Dec 26, 2013 at 6:33 PM
    dARWiN
    dARWiN n00b
    Taos, New Mexico
    2008 TRD Off-Road extended cab 4.0L V-6
    Does whether it has single or double axel come into factor here?
    I have an '08 V-6 with tow package and have two options:
    a 3500lb-4000lb aluminum 3-horse slant-load horse trailer (with electronic braking system) loaded with only one 900-lb horse and 400-lbs of hay, gear, etc,
    -OR-
    a single-axel 2000-lb(ish) steel 2-horse straight-load trailer, same loading of 900-lb horse and 400lbs of hay, gear, etc.
    for some longer-distance trips, would most people agree with me that the lighter option (the smaller steel trailer) is the better option?
  9. Dec 26, 2013 at 6:40 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Too small a truck for towing horses IMHO. Time for a Tundra.
  10. Jun 25, 2016 at 10:28 PM
    Gazelle
    Gazelle New Member
    2013 taco
    Done and done. Pulled a 2 horse trailer with a LARGE warmblood today with no problem through some greasy backroads and some Hwy driving. Aftermarket tow package and a few other extras but definitely doable for short trips.
  11. Jun 25, 2016 at 10:37 PM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    re: tongue weight, if the trailer is loaded properly, 10-15% of the trailer total weight is on the tongue, you must subtract this tongue weight from your vehicles payload capacity (1200 lbs). so if a 4500 lb loaded trailer is a little nose heavy at 600 lbs, you've only got 600 lbs left INCLUDING DRIVER AND PASSENGER(S)
    now, if you have good LT tires, and airbags or spring helpers, you probably can go a little past this, but don't quote me. a WDH is a must, too, for a heavy trailer on a tacoma..
  12. Jun 25, 2016 at 11:24 PM
    Ariyan
    Ariyan Well-Known Member
    NM
    4x4 TRD Sport
    SAS, 40s, and some armor.
    I towed our 2 horse trailer(~2,500lbs) and one of our drafts(~2,000lbs) who does not like trailers at all. It did just fine but I wasn't very comfortable at first because that was shortly after moving to the Tacoma from a Duramax so every time she would shift her weight or step I could feeling it where as the old truck I couldn't feel it behind me.
  13. Aug 4, 2016 at 5:17 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Wow that looks familiar!
    A 16.2 warm blood and a 15.2 paint all set to go!
    2008 with 285,000 miles and going!
    Weight dist. hitch with sway control.
