How high can you go before you need a diff drop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nad, Aug 5, 2009.
  1. Aug 5, 2009 at 7:40 AM
    nad
    nad [OP] mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I searched around and couldnt find the answer I was looking for. My plan is to have 5100's installed all around, set at 2.5 in the front. I am also getting an extra leaf added by a custom leaf spring shop that makes them to fit your vehicle. This aal should add about 1.5 inch's as well I believe that the rear 5100's raise the truck an inch, so this will be roughly 2.5 in the rear as well. My question is, am I going to need a rear diff drop? how high can you lift the rear before requiring one?
  2. Aug 5, 2009 at 7:42 AM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    the diff drop is for the front diff, ur rear diff is part of a solid axle. and u dont NEED it.
  3. Aug 5, 2009 at 7:54 AM
    nad
    Jordan
    Canada
    hmm ok I was wrong with what I was thinking I guess, so should I get the front diff drop then to take some of the angle of the cv axles and boots?
  4. Aug 5, 2009 at 7:57 AM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    thats the idea behind it but so far it seems that most people on here dont think its really necessary plus it takes away from your ground clearance. i just put a 3" OME lift on and i bought the diff drop kit but havent put it on and im not sure if i ever will.
  5. Aug 5, 2009 at 8:14 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I had a front diff drop for about 2 weeks before I realized it was causing vibrations so I took it off.
  6. Aug 5, 2009 at 8:17 AM
    nad
    Jordan
    Canada
    very good to know thank you
  7. Aug 5, 2009 at 8:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    The reason behind the diff drop is to bring the CV angle back (closer) to stock from the lift. Some people have experienced the CV boots ripping form the angle. Although I am not certain if it is more of a first gen vs. second gen issue. I think that is the main reason behind it though.
  8. Aug 5, 2009 at 8:47 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    lol an inch. Not even really. I still use my factory skid plate no problem what so ever.
  9. Aug 5, 2009 at 10:32 AM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    I have what sounds like the exact same setup on its way to me as we speak. Dan at Wheelers mentioned the diff drop but did not stress it much. He did bring up uca's if I set the front to 2.5 (as I plan to do). He said the truck should align within spec but caster will be close. If the truck wanders at freeway speeds then uca's? Seems logical to me.
  10. Aug 5, 2009 at 12:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah....You may not get back within factpry specs for caster and UCAs provide the extra angle to get there. You may or may not have issues with alignment/wandering or with vibrations from the diff angles.
  11. Aug 5, 2009 at 12:45 PM
    AFRaptor22
    AFRaptor22 Member
    South Jersey
    09 Silver D-Cab TRD
    Nothing
    I know this doesn't answer the original question....but shocks won't raise the back of your truck. Only an AAL that re-curves the springs or blocks will raise the back. The new shocks (5125 I believe) for the rear will help your ride and are longer so they won't get damaged at full suspension travel.
