How high does your dipstick read when you read it after parking overnight?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maxmk8, Jul 12, 2023.
  1. Jul 12, 2023 at 12:26 PM
    maxmk8
    maxmk8 [OP] Well-Known Member
    2022 Electric Lime M/T Taco
    I am having a peculiar "issue" and seeking some input for peace of mind. This is for the V6 engine.
    If I follow the proper directions:
    • Warm up truck to operating temp
    • On level ground
    • Shut off
    • Wait for 5 min
    • Take reading...
    My oil level is correct...
    however first thing in the morning... when I check my oil it is like 1"+ higher than the upper mark no matter how many times I measure.
    Can anyone chime in and let me know how your truck reads in the morning when standing for a while ?
    I am not new to car ownership... probably had 30+ cars and I have never witnessed such weird oil dipstick behavior ... and I can't stand how hard it is to read either.
  2. Jul 12, 2023 at 1:11 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    The added amount of oil has been sent up for lube. It is normal. If is low at cold. It is low
  3. Jul 12, 2023 at 4:57 PM
    maxmk8
    Interesting I did a search or two and some say their cold level shows at normal
  4. Jul 12, 2023 at 4:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Normal, the entire engine will drain down. 2GR's have massive differences in levels if checked over time.
    Just run it, check it after it settles and call it good.
    Manual says 5 minutes not 10 hours.
    RustyGreen likes this.
  5. Jul 12, 2023 at 5:04 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    mine reads the same just easier to see in the AM before starting.
  6. Jul 12, 2023 at 5:08 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Can’t attest to cold engine oil level, but check around here for dipstick scuffing posts for your legibility issues. I just used a scouring pad from the kitchen.
    The tip of my stick was extremely jagged/sharp and it was tough to insert. After taping off and scuffing up the oil read area between the dots, I also sanded down and smoothed out the tip. Couldn’t be happier with the results
  7. Jul 12, 2023 at 5:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    I have always done routine oil checks on a cold, level-ish engine. Ensures drainback has long been completed.
    I check the trans warm. But I have a trans dipstick.
    #savethedipsticks
    #dipsticksmatter
    SR-71A, LexTech2018 and fathomblue like this.
  8. Jul 12, 2023 at 6:01 PM
    maxmk8
    V6?
  9. Jul 12, 2023 at 6:03 PM
    maxmk8
    Do you have 3.5 v6 or you talking about your 2 gen ?
  10. Jul 12, 2023 at 6:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Oil is on any vehicle.
    Trans is my 2nd gen 2.7 and older vehicles. Even the 3rd gen 2.7 lost their dipsticks. :(
  11. Jul 12, 2023 at 6:31 PM
    maxmk8
    My ev doesn’t have oil. Thanks for that gem of input. That said I’m specifically asking about the 3.5 it seems to have notoriously difficult oil readings
  12. Jul 12, 2023 at 7:20 PM
    David2431
    David2431 Well-Known Member
    Took delivery of my 2023 Silver SR5 V6 5' bed yesterday. Yippee!! Love it! After putting a whopping 40 miles on it I parked it on level ground and checked the oil. It was at the same level as in the OP's photo. I'm not a bit concerned about it since I'm used to seeing the same level on our RAV4 when I add a few extra ounces at oil change time.
  13. Jul 12, 2023 at 7:41 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Lightly scuffing the "oil area" of the dipstick with fine sand paper/Scotch-Brite/steel wool/etc makes it much easier to read.
    No need to go crazy, just dull the surface down a bit is all that is needed.
  14. Jul 13, 2023 at 5:33 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I finally got around to checking my oil level the other day...it's still between the marks on the dipstick where it was last fall. This was checked cold first thing in the morning.
    maxmk8[OP] likes this.
  15. Jul 13, 2023 at 9:35 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    yes
  16. Jul 13, 2023 at 10:38 AM
    maxmk8
    Cold
    Hot (white background)
  17. Jul 13, 2023 at 10:43 AM
    zoo truck
    None
    When it's hot it would read less...some of your oil hasn't completely drained down into the pan yet. If anything your overfilled by at least 1/2 qt.
  18. Jul 13, 2023 at 11:12 AM
    maxmk8
    According to the manual I am not… but I’m just not fully understanding why the dipstick situation in this truck is so over complicated
