How imperative are new UCA's with this lift...?
Discussion in 'Suspension' started by pivey14, Jan 7, 2013.
  1. Jan 7, 2013 at 5:11 PM
    pivey14
    pivey14 [OP] Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    I'm looking to get the Bilstein Adjustable Lift Kit with 5100 shocks and Eibach coils with a top plate spacer. It will bring me to 3" of lift with the Toytec 2" AAL. So my question is: "Will it hurt my truck if I run stock UCA's with this lift?"
    :cheers: Thanks for the info. If I don't absolutely NEED them, than I don't necessarily want to spend $500 extra.
  2. Jan 7, 2013 at 5:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It wont "hurt" your truck, but your alignment will be off. Ask yourself this.....Did you take price into much consideration when buying your truck? The Tacoma is the most expensive mid size truck out. Why skimp on doing the lift?
  3. Jan 7, 2013 at 5:20 PM
    RedneckSailor
    RedneckSailor Well-Known Member
    Brian
    San Diego, CA
    2011 Quad-Cab 4x4 TRD Offroad
    I was actually in a Off Road store today talking about this exact lift kit. I was at 4 Wheel Parts in El Cajon, CA. They said that they can get the alignment spot on without replacing the UCA's. I was told that as long as I don't go above 3" of lift, the stock UCA's will be fine. But, I know everyone has a different answer on this one.
  4. Jan 7, 2013 at 5:26 PM
    Day Cowboy
    Day Cowboy Well-Known Member
    Day Cowboy
    MS
    2011 Tacoma TX TRD 4x4
    AFE Pro Dry Air Filter, Toytec Ultimate 3' Lift, LR UCAs, WeatherTech Floorliners, Wet Okole Seat Covers
    I have read in several forums that if you don't get new UCAs, then you might rub. I would ask myself..."Do I really want to screw up new tires?" (That is if you are going to a bigger style tire).
    Plus, the LR UCAs are adjustable. So this will eliminate rubbing.
    Oh and commend you for still using the MSU symbol in your profile. Hope my Rebels didn't hurt ya'lls feeling too bad!
  5. Jan 7, 2013 at 5:30 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    You're a prerunner, get spindles and leave your front shocks and coils alone. For the rear do the 2" AAL and bilstiens and call it done.
    Why make your truck ride like crap preloading the coils and pushing it on the alignment when spindles are now super affordable?
  6. Jan 7, 2013 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive had 4wheel parts tell me that a magnet placed in the fuse box would give me better MPG, and hp. If they tell you something, its best to belive the opposite.
  7. Jan 7, 2013 at 5:35 PM
    Mr Salty
    Hermmy
    Lots of chrome
    I second that!
    A 3" lift using stock UCA and alignment is perfect, yeah right!
  8. Jan 7, 2013 at 5:50 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    ive been running a 3" lift 33's and stock upper control arms for 5 years now to the day. the alignment will slowly work its way out. luckily i know an alignment guy and it doesnt cost me anything.
    that being said tires will wear out unevenly. they will be my next purchase.
  9. Jan 7, 2013 at 6:54 PM
    pivey14
    Austin, TX
    Thanks for the information guys. I want to level out my truck, but also give it a couple of inches to fit some bigger tires. My budget is about $800 for suspension. I really would like to fit some BFG KM2's. My brother "Voodoo" is running this exact lift but without the top plate spacer. I really wanted the tps to reach 3" lifts and put the KM2's on.
  10. Jan 7, 2013 at 7:03 PM
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    Ive got a similar lift(OME) and BFG ATs with stock UCAs. Im 16 and broke so new UCAs aren't really in my near future. My alignment is fine without em(for me), but it definitely isnt perfect.
  11. Jan 7, 2013 at 7:19 PM
    pivey14
    Austin, TX
    Appreciate the input. If I'm not mistaken, the OME kit achieves the same lift, but with better shocks and coils, correct? May look into getting them instead.
  12. Jan 7, 2013 at 7:21 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Yeah the coils lift it, rather than the coils and shocks. Its a great kit. Although I would suggest putting it on yourself. I have yet to find a shop I can trust.
  13. Jan 7, 2013 at 7:28 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    I have eibach coils and bilstein set at .85 no problems with alignment or rubbing. I think the spacer is just the taco lean spacer because I only see 1 in the photo.
  14. Jan 7, 2013 at 7:34 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I just went and got LR UCA's right off the bat when I got my lift to avoid future issues.
  15. Jan 7, 2013 at 7:36 PM
    pivey14
    Austin, TX
    The top plate spacer is an option that brings the lift to a COMPLETE 3" in the package.
  16. Jan 7, 2013 at 8:57 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Personnally I would do without the spacer I'm very happy with my lift and it rides good on and off the road. I also have removed my sway bar.
  17. Jan 7, 2013 at 8:59 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    We installed this lift on my buddies 2006 DCLB a few months ago and he didnt get new UCA's but his alignment isnt perfect. I'd say save up and get some aftermarket UCA's.
  18. Jan 7, 2013 at 10:41 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    I put the toytech lift on mine without the UCLA's with the stock tires. I had the truck aligned right after, but they couldn't quite get the camber perfect. This caused the stock tires to wear out prematurely :D so I could justify buying total chaos uca's. If your going to invest in new larger tires for 1200+ I would recommend buying new uca's otherwise your new tires will wear faster than you want.
  19. Jan 8, 2013 at 6:41 AM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Without UCA's the ride quality will suffer and most likely, at least in my experience. The front suspension woildn't fully articulate. Proper alignment was imposible.
  20. Jan 16, 2013 at 7:18 PM
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    So I have a 2013 DBL cab TRD OR and I want to go with either 255/80/17 or 255/85/16 KM2's depending on which after market wheel I go with. Right now I'm really liking that TRD bead lock 17in forged wheel in dark grey.
    Soooooo, since the tires I'm going to use are 33's but are a very narrow 33 can I get away with 2.5 lift or do I need to go 3in. ???
    I've looked at Icons lifts and their UCA's and they look quality and seem to have a pretty good rep.
    Also looked at FabTech 3in lifts and theirs cost more but they come with UCA'S with their kit so price is a wash but FabTech doesn't appear to be very popular around here. Why??? I've known guys that used FabTech on their domestic trucks with good success but there seems to be no love here for them.
