How important are catalytic converters?
Discussion in '1st Gen. Tacomas (1995-2004)' started by totoyotata, Nov 17, 2023.
  1. Nov 20, 2023 at 5:46 PM
    #41
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    When the stars align....these can produce a lot water....
    if the mid pipe is hard welded to the front of the muffler...you'll have water buildup....
    should only be tack welded in couple spots on the slip fit to the muffler...
  2. Nov 21, 2023 at 3:57 AM
    #42
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    That’s right. I forgot basic chem 101.
  3. Nov 21, 2023 at 7:44 AM
    #43
    Morden
    Morden Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    They're important enough to support a profitable theft ring, obviously.
    totoyotata[OP] and Nano909 like this.
  4. Nov 24, 2023 at 9:20 AM
    #44
    Running Board Man
    Running Board Man Well-Known Member
    You can simply get away with o2 sensor spacers if you want to get rid of the cel for as little as possible
