How Important Are Mud Flaps?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by quadcrazy, Jun 15, 2020.
  1. Jun 15, 2020 at 11:37 AM
    quadcrazy
    quadcrazy [OP] Well-Known Member
    I've got a 2018 OR that did not come with mud flaps and I never really thought about putting any on. I do typical weekend warrior type stuff, often involving dirt/gravel roads and some minor rock stuff. I don't care about some mud getting thrown onto the body as I'm usually good about washing it, but is it bad for my undercarriage to not have them?
    Junkhead likes this.
  2. Jun 15, 2020 at 11:43 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Mud flaps will save your lower body panels on dirt/gravel roads. Very possible to tear them off in the rocks. As to mud, if you leave it you will eventually have a higher corrosion rate on stuff under the truck.
    Taco16LB, tonered and quadcrazy[OP] like this.
  3. Jun 15, 2020 at 11:45 AM
    Technical Ted
    Technical Ted Well-Known Member
    Ted
    Western NY - Finger Lakes
    2020 Tacoma Limited Barcelona Red
    I like them even for driving on the highway too... They keep your tires from throwing up stones and debris on the poor fella behind you. I hate it when the driver in front of me kicks up stones, etc. and they hit my vehicle and/or wind shield. I don't want to do it to any body else either.
    Ted
  4. Jun 15, 2020 at 11:45 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I don’t have any installed. I won’t go out and install some. I’m not worried about the damage (rock chips), I just keep it waxed and protected. I haven’t found anything that I would call damage. Get dirty AF, then clean it.
  5. Jun 15, 2020 at 12:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The Toyota ones are not that great. They are molded, hard plastic that are likely to rip off while offroad. I removed mine, but heard too many loud hits from stuff bouncing off the rockers. I installed some cheap universals that flex and only hear something once in a while.
    Save yourself at least $100 and go with the nicer, cheap ones.
    MJTH and disconnected like this.
  6. Jun 15, 2020 at 12:07 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    That's what she said....
    OneGiraffe, Tacospike and tonered like this.
  7. Jun 15, 2020 at 12:09 PM
    Grindstone
    Grindstone Requires Adult Supervision
    One could argue that a coating of mud protects from rock chip damage...
    My '13 ripped its mud flaps off in short order. My '20 didn't come with any and I'm not missing them.
    mchertel and tonered like this.
  8. Jun 15, 2020 at 12:10 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I live in MN, winter time mud flaps are a gift from God. But they also protect my body from rocks getting kicked up by my tires.
    DAS Taco and tonered like this.
  9. Jun 15, 2020 at 12:42 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    if you like stone chips, followed by rust, by all means, dont install flaps. the more aggressive tires, the more chips. if you drive dirt roads and no flaps, you may even encounter "sandblassted lower finish look", that you CANNOT FIX BY POLISHING, OR WAXING. Your results may vary. Ski
    MJTH, P-Dawg, Junkhead and 1 other person like this.
  10. Jun 15, 2020 at 1:09 PM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    I splattered my boat big time last summer with dirt so put on some Rekgens this spring. A must, IMO.
    quadcrazy[OP] likes this.
  11. Jun 15, 2020 at 1:10 PM
    quadcrazy
    How flexible are they? Are they just going to rip off if they hit a rock?
  12. Jun 15, 2020 at 1:12 PM
    Chunk
    2016 DCSB OR
    Baby Ruth
    Potentially yes! They will. You can get a more flexible option! RAD Rubber makes some and a few other options!
  13. Jun 15, 2020 at 1:18 PM
    bbq4133
    bbq4133 Well-Known Member
    Dylan
    Leesburg, VA
    2020 JLU Rubicon 6MT
    I have the "stock" hard flaps and figured they'd get ripped off on a trail. Any suggestions for a cheaper, more flexible option?
  14. Jun 15, 2020 at 1:24 PM
    5nahalf
    Erik
    Minnesota
    https://www.homedepot.com/b/Building-Materials-Glass-Plastic-Sheets-Rubber-Sheets/N-5yc1vZcj87
    Buy some sheet rubber, trace your stock flaps onto it and cut it out. They will be floppy, and with all the rubber you get from a roll you can make a bunch of extras. If you need to make them less floppy you can add some metal coat hanger wire and zip ties.
    tonered likes this.
  15. Jun 15, 2020 at 1:33 PM
    Carhanu
    Carhanu Well-Known Member
    Michael
    2020 Red Tacoma TRD Off-Road
    Mud flaps defeat the whole purpose of having high ground clearance. They will break easily if you do any serious off-roading. I had mud flaps on my 2015 Tacoma and they would hit the ground every time I went over a speed bump! It was very annoying to have to worry about speed bumps in a truck!
  16. Jun 15, 2020 at 1:34 PM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    i have these pretty cool slider/steps that let me remove my front flaps and the rocks hit them instead.
    I dont know if they were stock or not.
    Grindstone and quadcrazy[OP] like this.
  17. Jun 15, 2020 at 1:46 PM
    quadcrazy
    What steps are those? Are they just steps or actual rock sliders? Nice looking truck!
  18. Jun 15, 2020 at 1:47 PM
    fiftyxp
    I am not sure I bought it used and never looked into it.
    But with these sliders/steps(idk if they are just a step or a slider) theres no way for a rock to hit the outside of the truck. I can hear rocks hit them all the time.
    another user might be able to chime in as to which they are.
  19. Jun 15, 2020 at 1:49 PM
    fiftyxp
    quadcrazy[QUOTED][OP] likes this.
  20. Jun 15, 2020 at 1:53 PM
    quadcrazy
