How important is hub-centric? Hub bore is 106.1? Tolerance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rzgkane, Mar 11, 2019.
  1. Mar 12, 2019 at 9:59 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    08BajaBoy likes this.
  2. Mar 12, 2019 at 12:20 PM
    rzgkane
    rzgkane [OP] Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Method emailed me and said their wheels are 106.25 and come with rings to fit the 106.1 of the Toyota. Can that be right? A ring that fills a .15mm gap? That would be a ring with a thickness of .075mm? That's paper thin.
  3. Mar 12, 2019 at 12:22 PM
    commbubba19
    '23 TRD PRO
    I think they typo’d that response. I’d ask for clarification.
  4. Mar 12, 2019 at 5:55 PM
    JimmySport
    JimmySport Well-Known Member
    if the ring is made out of aluminum it would be fine, but I am not sure I have ever seen a hub ring that thin? I too would ask for clarification. Before I bought my 4 Runner Pro wheels I inquired about a set of KMC XD Wheels and they told me the hub bore was 106.25 and that they would be "fine". obviously I passed on them. 106.1 is hub centric, any deviance from that and well, it isn't. plain and simple.
  5. Mar 12, 2019 at 6:04 PM
    nsg44
    nsg44 Well-Known Member
    2019 TRD OR 4X4 DCSB
    I recently put on wheels with a 112.1mm bore size on the Tacoma. I asked the tire-shop if I'd need rings, and they said they'd let me know.
    After installation, they said everything went smooth and the "wheels took without needing rings". I'm assuming if they passed up a chance to sell me rings, then they're telling the truth. I don't know if this helps or not.
  6. Mar 12, 2019 at 6:10 PM
    JimmySport
    this "can" be true in some cases. perhaps the shop you used got very lucky? perhaps the wheels you chose took a shank style lug like the factory? but with a standard acorn style lug I would have insisted on the rings. here's why: say the shop who installed the wheels/tires got lucky and you have no vibrations whatsoever. take your truck in for service to get your tires rotated and well, they don't get as lucky as shop #1. then you are going to have vibrations.
    some people will swear they never use hub rings, but I personally will not install any wheels that aren't hub centric without them.
    nsg44[QUOTED] likes this.
  7. Mar 12, 2019 at 8:18 PM
    LongDistanceTaco
    LongDistanceTaco Well-Known Member
    Geoff
    California
    Plastic hubcentric rings cost what.. 20-30 dollars. For the peace of mind knowing that your wheel is centered, I think it's worth it. But when I used them on my Subaru, the rings got stuck onto the hub. I could never get them off...
  8. Mar 12, 2019 at 10:44 PM
    nsg44
    Thanks for the info. I've been purchasing tires at this tireshop for almost a decade now, so most of my work will be done there in the future. I'll ask about hub rings again when I go in there for my first rotation
    LongDistanceTaco likes this.
  9. Jun 11, 2020 at 9:44 PM
    BankrupTaco
    BankrupTaco Well-Known Member
    2021 Tundra SR5 4x4
    Any update on this? I’m looking at wheels with the same hub bore for my Taco.
  10. Jun 11, 2020 at 9:48 PM
    BankrupTaco
    2021 Tundra SR5 4x4
    What hub centric ring and lugs would you run with a wheel that has a 112.1 hub bore for the Tacoma’s 106.1 hub bore?
  11. Jun 11, 2020 at 11:22 PM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    There is not a single car on the planet where the weight of the vehicle is supported by the tiny flange on the wheel hub. The lug studs also do not bear the weight of the car.
    The clamping force of the lugnuts affixes the wheel to the hub face, joining them. The hub face, not the tiny centering flange, supports the weight of the car.
    All modern vehicles are lug-centric, so you don’t have to stress about the center bore on the wheel so long as it’s as large or larger than the hub center flange. Having the center bore and flange diameter match makes installing the wheel a little easier, that’s all. There are some older, specialized vehicles with hub-centric wheels. The only one that comes to mind is the Pinzgauer, but I would love to hear of some other examples.
  12. Jun 11, 2020 at 11:36 PM
    Tacocop74
    Tacocop74 Member
    Paul
    2019 Tacoma TRD Sport 4x4
    Vanguard Roll bar
    I am running Method Vex 311's. bore is as you said 106.25 to the 106.1 of the OEM, I feel not shake/shimmey.
  13. Jun 12, 2020 at 5:30 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Uh, I think you have things reversed. All modern vehicles are hub centric with very few exceptions. The last ones I remember were a 70s era beetle -
    oconnor and rdpoe like this.
  14. Oct 29, 2020 at 8:32 AM
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    Most BMWs and other vehicles that take wheel bolts (instead of studs) are always hub centric because getting the wheel on the car would be pretty hard without that... trying to balance the wheel so that everything lines up while also threading the bolt in there would be a chore.
  15. Oct 9, 2021 at 1:36 PM
    #35
    Retro338
    Retro338 Member
    I've recently purchased some wheels requiring 106.1-112.1 hub centric rings. Only after purchasing did I really get into the weeds on learning about all of this stuff. Seems to me that hub rings primarily serve to assist with proper centering on installation (especially when tightening the lug nuts). I think BearWithMe was pretty spot on about how the load is supported.
    My further research was also very enlightening, if you wish to read up on the topic, these links below had some good information. If anyone has more information on the mechanics/physics or where to find top quality hub rings in the size above, I'm all ears. Cheers.
    1. https://link.springer.com/article/1...of securing the,its mating component, and the
    2. https://www.maximummotorsports.com/tech_wheels_spacers.aspx
    3. https://physics.stackexchange.com/q...-the-load-handled-between-a-car-and-its-wheel
  16. Jan 31, 2023 at 11:45 AM
    #36
    dippitydoo69
    dippitydoo69 Member
    Hey man this is super late lol, but do you have the tpms and lugs you use? I was looking at getting these
