How important is it to change gear oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Dec 5, 2021.
  1. Dec 5, 2021 at 7:30 AM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    How important is it to change differential and transfer case oil, and how often should it realistically be done?
    I’m at 115k now and it’s never been done.
    I’m willing to bet that there are a *lot* of vehicles on the road with 2x the miles I have that are still on the factory gear oil, but figured I’d ask.
    Also, the 75W-85 that the manual calls for is a bit of an oddball weight. Redline is all I can find. Is it a good oil?
    Thanks.
  2. Dec 5, 2021 at 7:34 AM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Other morons not taking care of their cars is not an excuse for you to not take care of yours.
    Any oil is fine, people on here will tell you Amsoil, or this or that is essential, but really what is the most essential is actually changing your gear oil.
    Oreo Cat, Gen2Tacoma, wi_taco and 7 others like this.
  3. Dec 5, 2021 at 7:36 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    :( every 30K miles for the rear diff. Front diff and transfer case you can probably get away with more if you don’t use it much. Here’s a great guide you should reference
  4. Dec 5, 2021 at 7:36 AM
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    nuff said......
  5. Dec 5, 2021 at 7:37 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
  6. Dec 5, 2021 at 7:46 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    In truth. You don't have to change any oil in any car or truck.
    The downside to not changing or stretching intervals is increasing the chance of a failure.
    When will the failure happen? Roll the dice.......
    Yes, for 2nd Gens the OCI for diffs and xfer case is 30 kmiles. Check your Owner's Manual for the service schedule.
    Valvoline 75w90 Synthetic gear oil is acceptable.
    blu92in99 and Dm93 like this.
  7. Dec 5, 2021 at 8:09 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    my advise would be to have a shop do it this time around... at 115,000 miles those plugs might be a pita to get off... especially the hex heads.
    SWPA Tacoma likes this.
  8. Dec 5, 2021 at 10:23 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Do you have a link to this quick guide?
  9. Dec 5, 2021 at 10:50 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It's in the stickied threads at the top of this forum.
  10. Dec 5, 2021 at 6:00 PM
    Plasmech
    Guess I’ll change it.
    Any harm in switching to synthetic after all this time?
  11. Dec 5, 2021 at 6:10 PM
    Boco10
    Boco10 Well-Known Member
    ADK
    No. Just change a regular intervals.
  12. Dec 5, 2021 at 10:40 PM
    TacoTuesday1
    SD CA
    yes the average person who neglects their vehicle and doesn't know what a forum or 55w light bulb is.
    What I don't get is why Toyota recommends it so frequently, possibly more than other vehicles
    Sharpish and Marc70 like this.
  13. Dec 6, 2021 at 6:21 AM
    Stack08
    Stack08 Well-Known Member
    Southeast Ga
    2008 white standard cab Tacoma
    Tint, JL Audio system
    Yeah and you don't actually have to eat either.
    What you said has got to be one of the dumbest things I've seen on here
  14. Dec 6, 2021 at 6:22 AM
    Knute
    Thank you.
    I'm happy that I have your stamp of approval.
    I'd like tell you how much your approval means to me.
  15. Dec 6, 2021 at 6:26 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    When at 30k the service advisor at the dealer told me not to change my diff oil until “like 80k”. Think i’ll add it to my to do list (at 40k).
  16. Dec 6, 2021 at 6:47 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just change it, these trucks are worth the extra attention. It may cost money in the short term but in the long run it will only add value to the vehicle.
    Think about it. If you were shopping for a used Tacoma, would you rather have the one with a thick folder of maintenence records or the one without?
    There's worse vehicles to sink money into.. at least these trucks hold their value
    usmc2msu and Dm93 like this.
  17. Dec 6, 2021 at 7:05 AM
    Stack08
    Southeast Ga
    Glad I could help. Sometimes things sound a lot smarter in our heads don't they?
  18. Dec 6, 2021 at 7:07 AM
    Knute
    The forum really needs a SARCASM font.
    Rick's 2012, YF_Ryan and b_r_o like this.
  19. Dec 6, 2021 at 7:10 AM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    I first changed my gear oil at around 100k+ and have been doing it every 30-40K since then. Now I'm around 177K and no problems. If you drive easy, don't plow and tow then doing that many miles on that oil probably didn't do any serous damage. That being said you (and I) shouldn't have let it go for that long.
    When I changed my Front, Rear and Transfer after 30K the oil in the Rear came out pretty dark, the oil in the Front and Transfer looked almost new. So you can probably run those two a little longer if you want to.
    Word of advice, look up the tutorial about removing the Front diff drain and fill plugs before you start. Most likely you will have a hard time after never been touched that many miles. Also look up the lexus plig (
    90341-24016), worth the $15.
    And always remove the fill (top) first. If you drain but cant fill you will have a bad day.
  20. Dec 6, 2021 at 1:49 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    It’s so easy I change the diff and xfer case annually. I usually do the front diff every other year. 6 quarts of gear oil does all three.
    winkel likes this.
