How important is the rear locker?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbandt, Aug 12, 2015.
  1. Nov 15, 2015 at 7:14 PM
    #41
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    Not true, I want the locker so I can drift and do donuts. :burnrubber:
  2. Nov 15, 2015 at 7:30 PM
    #42
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    In slippery conditions the limited slip wont "slip" and will spin both tires at the same speed, same as a locker.
    I have a powertrax no-slip in my truck by the way. I prefer it over a selectable locker actually.
  3. Nov 15, 2015 at 8:40 PM
    #43
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Ok. I guess I'm a fool. :notsure:
  4. Nov 16, 2015 at 2:10 AM
    #44
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    No problem, I was just cranky yesterday. BTW, I am a fool, just ask my wife...o_O
  5. Nov 16, 2015 at 7:14 AM
    #45
    LocknLoad
    LocknLoad Well-Known Member
    near the Cherohala Skyway, TN
    2015 DC Off-Road 4x4
    Contact Sandman on this board - he put a TruLoc rear locker in his and last I heard really likes it. Basically a torsen rear end, no switches, it engages automatically when the other wheel slips. Ironically, my Miata has one, my truck does not :)
  6. Nov 16, 2015 at 9:56 AM
    #46
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    The Eaton/TRD is a clutch type LSD. If you have a lot of traction (street) and turn, the force between the two tires exceeds the 200ft-lb clutch point and the LSD slips allowing you to turn easily. If you are in the dirt/sand the difference between the two tires won't exceed 200ft-lb and your axle is effectively locked. No snow where I live, but I go to the desert often and it works great. You use a special diff fluid additive when you change the fluid. I have had mine for five years and it works just as well now as when new.
  7. Nov 16, 2015 at 10:03 AM
    #47
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Thanks very much for all the Info ! Do they List one for my '02 Tacoma 4x4 -8.4 rg -30 Spline ?? Thanks again
  8. Nov 16, 2015 at 10:14 AM
    #48
    mtucker
    Escondido, CA.
    03 Prerunner DC
    I believe 8.4" is stock. Is the 30 spline non stock? If your setup is stock and a 96-2004 V6 2WD or 4WD without an electronic locker, it should work.
    I misquoted the torque slip point. It is 400ft-lb and not 200ft-lb.
  9. Nov 16, 2015 at 2:28 PM
    #49
    Wulf
    rock raisin
    spool :D
    but really, in the snow I'd want open diff (or unlocked selectable) or a spool. I have had a jeep with both a spool and a detroit and the automatic locker can be unpredictable.
  10. Nov 16, 2015 at 2:29 PM
    #50
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I file the TRD locker under 'extremely nice to have,' especially since a comparable aftermarket one (i.e. selectable) is pretty spendy. Keep in mind though that they're not without problems and should be tested regularly. I had my motor seize up so the locker would not engage. I took it apart and found salt residue inside. A good cleaning and some grease restored full function.
