How is my alignment after lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Outlaw, May 5, 2010.
  1. May 5, 2010 at 6:56 AM
    Outlaw
    Outlaw [OP] Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    can you guys let me know if these numbers look ok?
    Installed 884 coils and OME shocks and rear AAL with Billstein 51s on the rear.[​IMG]
  2. May 5, 2010 at 6:58 AM
    weiser5150
    weiser5150 Stickers and new floormats arent Mods
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Bilsteins all around,Front set at 2.5",Toytec AAL,LR UCAs,18x9 ATX Thugs,275/70R18 Toyo MT's,Relentless Fab Sliders,Satoshi Grill with TRD emblem and Hella Black Magic's converted to HID behind it.
    i dont see anything
  3. May 5, 2010 at 7:03 AM
    Outlaw
    Iowa City, Iowa
    Outlaw Tacoma 072.jpgDamn,
    i think i messed up a setting so no one on here can see my pix.
    Not sure how to change setting.
    thanks for letting me know.
    Any help to get pic views restored?
  4. May 5, 2010 at 7:30 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I can see it now!
  5. May 5, 2010 at 10:20 AM
    Outlaw
    Iowa City, Iowa
    Hey Chris,
    i was having trouble with the pictures for ahwile.
    can you check this out?
  6. May 5, 2010 at 1:26 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Looks fine, in fact it says right at the bottom "All angles are within manufacturer's specifications".
  7. May 5, 2010 at 1:54 PM
    Outlaw
    Iowa City, Iowa
    yeah but within specs doesnt mean a whole lot. It needs to be ideal... and wondered if one of the experts on this site could chime in.
  8. May 5, 2010 at 2:00 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    yes please im goin to get aligned tomorrow want to know if within factory specs is correct or do we need to go more?
  9. May 5, 2010 at 2:08 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    How's it drive? From what I've read here having the toe and camber at close to 0 and the caster at around 2.9 is ideal after a lift. Problem is you can't get close to that caster with the stock upper control arms. Does your truck track straight now?
  10. May 5, 2010 at 2:23 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    numbers look not to good toe should be 0 camber should be 0 and caster should be 2.3 - 2.8
    do you have stock u.c.a.'s?
  11. May 5, 2010 at 2:24 PM
    Outlaw
    Iowa City, Iowa
    It tracks fine...maybe a little to the right? but they couldnt get close to the caster that would be ideal..
    I stayed with the shortest lift possible to avoid getting UCAs, but looks like that just isnt possible.
  12. May 5, 2010 at 2:26 PM
    Outlaw
    Iowa City, Iowa
    Yep Stock UCAs.
  13. May 5, 2010 at 2:27 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea thats probulary the best they could do....
    try l.r. uca
  14. May 5, 2010 at 2:30 PM
    Outlaw
    Iowa City, Iowa
    I guess what I really want to know is,
    are these numbers or as good as it can be with the stock UCA's?
  15. May 5, 2010 at 2:33 PM
    Outlaw
    Iowa City, Iowa
    Thanks. You answered my question exactly. i just thought that I wouldnt need them if I stayed under 3". or about 2". Thats not the case I guess...
    I would have lifted it a little more if i knew i was gonna need UCAs.
    thanks guys!
  16. May 5, 2010 at 2:33 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea i would guess so.... does the truck drive straight or have any bump steering, or feel squirley at high speeds???
    the toe being off is what will wear out your tires faster though
  17. May 5, 2010 at 2:35 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    ill tell you something thought if you did get the l.r. uca's make sure someone in your area is capleble to adjust them or you will be in the same boat......
    it took me like 4 shops before i found someone who knew how to adjust them to get mine in shape
  18. May 5, 2010 at 2:39 PM
    Outlaw
    Iowa City, Iowa
    Not really. It was super windy yesterday when i had it on the freeway so I couldnt tell if it was the wind or the truck.
    what is bump steering?
  19. May 5, 2010 at 2:41 PM
    Outlaw
    Iowa City, Iowa
    Good advice! thanks.
    Im not looking into UCAs quite yet. Maybe in a couple months.
    But what does it take to adjust the UCA's.
    How do you know if they can adjust the UCAs?
  20. May 5, 2010 at 3:17 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    on a stock truck the only adjustments are the cams from the factory....but they can only do so much......
    on the light racing uca's the ball joint is adjustable in like 8 positions to give you + or - 2* of caster and the top has a groove to adjust the camber
    but see how it drives first
    oh and to adjust the l.r. uca is very very easy it is just many many people are to stupid or in to much of a rush to take the extra few mins to adjust them......
