how is my alignment?
Discussion in 'Wheels & Tires' started by maxpower29, Jul 28, 2014.
  1. Jul 28, 2014 at 6:45 AM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Running 5100s set at. 85 with eibach coils and 1/2"+ 1/4" spacers
  2. Jul 28, 2014 at 6:48 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    caster looks great, camber and toe, based on the general consensus here @TW, should be set to 0*...
  3. Jul 28, 2014 at 6:50 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya i did that last time too. But most people around here gave the reason of the roads to set it a bit off and at 0 it made my tires wear a little off over time so I'm trying the factory spec this time (or whatever he suggested)
  4. Jul 28, 2014 at 7:15 AM
    BamaToy1997
    Bill
    Navarre, FL
    All the specs are good to me. I like to see a small amount of positive camber (around .5) to help with road crown and road wander. The slight positive toe is so minimal that you wouldn't see any tire wear, and again, I like positive toe by a tiny amount like you see there because again, it helps with "wander" due to road conditions and road crown.
    Now personally, if I were to do that alignment in an area with little or no road crown I would have had a slightly higher caster on the left than the right. Vehicles pull towards high camber, and low caster. So TECHNICALLY if you were on a perfectly flat road (which doesn't exist anywhere) your truck, if you let go of the steering wheel, would slowly creep left, into the opposing traffic lanes. I like to have them set to a slight right direction. Why? If you fall asleep at the wheel, or are not paying attention, the truck will tend to head to the right, AWAY from oncoming traffic.
    That being said, your difference in caster is so minimal that you would not have any trouble at all with a good, straight traveling truck with those numbers.
  5. Jul 28, 2014 at 10:17 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    thanks guys, feels pretty good driving it so far
