How is the 4 Cylinder Built Better?
Discussion in '4 Cylinder' started by Early B., Jan 23, 2018.
  1. Feb 1, 2018 at 4:14 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I agree with nearly everything you say here. A few points of information:
    -- Not sure if the vertical cylinder position allows less wear on its own. Lots of boxer engines and v-engines with hundreds of thousands of miles. I suspect the cylinder pressures and crank/rod rotational forces are creating far more stress.
    -- "Transverse" is a term describing the mounting position of the engine, it means the cylinders are aligned left-right relative to the vehicle (as in most front-drive sedans). The mounting of our engines is longitudinal, meaning the cylinders are aligned fore-aft relative to the vehicle.
    -- cast iron blocks do have cylinder liners, they are made of steel.
    Otherwise great post, thanks :D
    dirtdigginjoe likes this.
  2. Feb 2, 2018 at 5:41 AM
    Clear7
    Clear7 Well-Known Member
    Ontario
    2017 SR5 2.7L - tried tested & proven
    Thank you. Not sure where my head was at. Yes, iron needs liners.
    Also, if my post made it sound like the 2.7L is a transverse mount, that wasn't the intent. I'm aware of the difference between the two setups. I have a bad habit of referring to a longitudinal engine simply as inline.
    I'll clarify my original post.
