How is the AC in the 2024?
Discussion in '4th Gen. Tacomas (2024+)' started by CrispyTacoLover, Apr 27, 2024.
Thread Status:
Not open for further replies.
  1. Jun 28, 2024 at 6:38 AM
    #101
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
    It's a truck, low-end torque is important offroad, pulling a trailer, hauling a heavy load. I welcome the low-end torque, pairs well with the 6MT. My AC works fine, it was 35C the other day, 42 C with humidex and the AC kept us cool.
  2. Jun 28, 2024 at 6:54 AM
    #102
    CrispyTacoLover
    CrispyTacoLover [OP] Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    The THI here yesterday was 115 F. It’s slightly cooler today so it’s only supposed to get to 113.
  3. Jun 28, 2024 at 6:57 AM
    #103
    Want-a-taco
    That's hot.
  4. Jun 28, 2024 at 8:02 AM
    #104
    CrispyTacoLover
    Yes, it is. We’re just getting started. Now you know why I asked owners in hot climates how the new gen is doing. It’s a pretty important feature around here.
    Want-a-taco[QUOTED] likes this.
  5. Jun 28, 2024 at 10:15 AM
    #105
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I like some low end torque. With EV and turbo being more popular, are people asking for more torque? Are the manufactures following CAFE standards, and the torque is byproduct? Then they tell people that they want and like more low end torque?
    What got me thinking about this. There is a Dodge Hornet commercial and it mentions the vehicle produces more low end torque.
  6. Jun 28, 2024 at 10:40 AM
    #106
    Want-a-taco
    Probably a biproduct, but welcome on a truck.
    batacoma[QUOTED] likes this.
  7. Jun 28, 2024 at 6:05 PM
    #107
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    Do some of these new trucks have the windshield humidity sensor thing / something that could trigger AC to come on outside of the climate control settings?
    Lt. Dangle likes this.
  8. Jul 3, 2024 at 1:17 PM
    #108
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I was about to ask if the truck measured humidity and was running the AC to reach a target percentage regardless of the temp setting.
    CrispyTacoLover[OP] likes this.
  9. Jul 3, 2024 at 1:46 PM
    #109
    lakerman
    lakerman Well-Known Member
    1stgen taco
    Got a 2011 rav 4 limited with auto climate option, thing does the samething when in its -40c outside, never have figured out to stop that nonsense.
  10. Jul 5, 2024 at 5:17 AM
    #110
    GoldenJoe
    GoldenJoe Member
    My Taco seems to be blowing cold air in the upper vents, when A/C off, fan off, setting to direct air to feet. I tried cycling all vent functions, even recycling inside air and it still occurs. Will be calling for an appointment to have dealer check.
  11. Jul 6, 2024 at 11:49 AM
    #111
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    Mine is doing the same -- blowing cold air with the a/c off. Checked the compressor and sure enough, on. Also increased the cab temp to 66, 67, 75 and all it did was cycle the compressor on/off on all settings. One more item to bring up with the dealer. The dealer is going to have an up hill battle since the owner's manual says otherwise.
  12. Jul 6, 2024 at 12:44 PM
    #112
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    One of the more serious side effects of this issue not mentioned in the thread: your compressor is not going to last as long as it would if it was not running all of the time. I have had vehicles with automatic climate control (some dual zone) and every one had a button or choice on the screen, usually a "snow flake" symbol, which allowed you to turn off just the a/c compressor. It would still be on "auto", just no A/C compressor assist. The rest of the system is completely active. I did this all of the time in the spring and fall when temps were cooler. One side affect of doing this in the warmer months would sometimes be a gradual increase of the fan speed as the system tries to hold the set temp. Auto fan speed and vent selection would still be completely active and adjust themselves as required including the the sun angle angle sensor. The electric cooling fan would not run constantly either.
    Hope they figure this out for you guys! Running the compressor occasionally is good for the system...all or most of the time is not good for the wallet or the compressor.
    Has anyone tried disconnecting the negative battery cable to see if the issue goes away or corrects itself? Might be worth a try.
  13. Jul 6, 2024 at 3:20 PM
    #113
    CrispyTacoLover
    We don’t have a choice in the south.
    Williston[QUOTED] likes this.
  14. Jul 6, 2024 at 4:09 PM
    #114
    Williston
    Understand completely. :thumbsup: Just some input that on trucks with this issue, the compressor never gets a rest, even when it may not need to be running and that's going to reduce its service life: Maybe substantially; and they are an expensive part to R&R. Mine doesn't run at temps below +- 40 degrees and never when the A/C button isn't lit up unless I select defrost or hi/low.
  15. Jul 7, 2024 at 5:00 AM
    #115
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Is it just affecting the models with automatic climate control? I have Manuel version and mine doesn’t do this. Turn the a/c off and it stays off.
  16. Jul 7, 2024 at 6:18 AM
    #116
    Gfenza89
    Where did slater go? He hasn’t updated anyone on his paint issue or a/c problems.
  17. Jul 7, 2024 at 6:21 AM
    #117
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Mine will definitely cool if I forget to press the AC button :notsure:
    Gfenza89[QUOTED] likes this.
  18. Jul 7, 2024 at 6:22 AM
    #118
    Gfenza89
    Do you have the automatic climate control? Mines just the base model, I don’t have auto .
    Delta09[QUOTED] likes this.
  19. Jul 7, 2024 at 6:25 AM
    #119
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hmm, you made me go out into the garage and look :laugh:
    It has the auto button, so I'm guessing yes. Never used it though, just set it on a temp and varied the fan speed myself.
  20. Jul 7, 2024 at 6:27 AM
    #120
    Gfenza89
    Hmm that’s interesting . I’m sure Toyota will come out with a bulletin to fix this if it’s a issues
Thread Status:
