How is the AC in the 2024?
Discussion in '4th Gen. Tacomas (2024+)' started by CrispyTacoLover, Apr 27, 2024.
Thread Status:
Not open for further replies.
  1. Jul 7, 2024 at 6:29 AM
    #121
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Doesn't bother me too much, I frequently forget to hit the AC button. The Camry always keeps it where you last set it, but the truck does not. Weird.
    Gfenza89[QUOTED] likes this.
  2. Jul 7, 2024 at 6:33 AM
    #122
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    My 3rd gen would still blow cold air in my face even with a/c off, that had auto climate control too. I think by switching to recirculate it stops air flow from going to the blower motor and reduces the air blowing in the cab. When driving with fresh air mode the air flowing goes to the fan and spins it. I don’t know it’s hard to know exactly what people are talking about over texting lol.
    Delta09[QUOTED] likes this.
  3. Jul 7, 2024 at 6:42 AM
    #123
    SheauxTyme
    SheauxTyme Member
    Long-time lurker, first-time poster…auto climate control should monitor humidity in the vehicle and turn the compressor on when it needs to lower humidity. If the humidity level is acceptable, compressor should turn off, but the a/c should continue to blow cold air. At least this is how my f150 works.
    Gfenza89 likes this.
  4. Jul 7, 2024 at 6:53 AM
    #124
    Gfenza89
    I think what these guys are saying though is the a/c compressor is cycling on and off while the system is completely turned off which doesn’t make sense to me
  5. Jul 7, 2024 at 9:00 AM
    #125
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    Correct, and to clarify the A/C switch is off and the fan on...
  6. Jul 7, 2024 at 10:21 AM
    #126
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    CrispyTacoLover[OP] likes this.
  7. Jul 7, 2024 at 10:22 AM
    #127
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    It does if you consider the idea that the humidity is controlling the compressor, not the temp or switch position.
    Mudc4t and Gfenza89[QUOTED] like this.
  8. Jul 7, 2024 at 10:34 AM
    #128
    Lt. Dangle
    Ohio
    A wiring schematic of the HVAC system electrical would be very beneficial to this conversation. If no humidity controller/sensor is present, it's clearly something else. If there is a controller/sensor in the circuit, it could be the answer.
    Mudc4t and Gfenza89 like this.
  9. Jul 7, 2024 at 10:35 AM
    #129
    Gfenza89
    Good point. Seems really wasteful to run the compressor to eliminate humidity if these people are driving with their windows down
    Lt. Dangle[QUOTED] likes this.
  10. Jul 7, 2024 at 10:41 AM
    #130
    Lt. Dangle
    Ohio
    I have no idea how such a setup would be optimized in a vehicle. Does seem wasteful yeah.
  11. Jul 7, 2024 at 10:48 AM
    #131
    CrispyTacoLover
    CrispyTacoLover [OP] Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
  12. Jul 7, 2024 at 10:44 PM
    #132
    dalton92
    dalton92 Active Member
    I didn't read the whole thread, but in my 2018 hilux when the AC's in auto it senses and controls humidity, with ac in regular "on" position, it just runs by set point.
  13. Jul 9, 2024 at 7:34 AM
    #133
    Tacowrench
    Northern California
    Update - returned from the dealer. They said it is working the way it should - ac button off/fan on/blowing cold air (compressor cycling on/off), even with manual temperature adjustments. The system is adjusting to the cab temp. Jeez.....
  14. Jul 9, 2024 at 7:41 AM
    #134
    661
    661 Well-Known Member
    SoCal
  15. Jul 9, 2024 at 8:02 AM
    #135
    Tacowrench
    Northern California
    Beerhydrate... :)
  16. Jul 15, 2024 at 5:23 PM
    #136
    vermontmike
    vermontmike Member
    just curious if this is a lemon law issue? I did the lemon law on a 2017 4runner because of the front end vibration and won. i just bought a 2024 sport and I took it to the dealer already for this issue. STart it up first thing in the morning to go to work and it is blowing cold air, no ac on. all i want is the friggen fan to blow air. pretty simple but I am going to go the 4 visit criteria for the next stage. I am really curious if anyone has gone that route?
  17. Jul 15, 2024 at 5:40 PM
    #137
    CrispyTacoLover
    I am not clear on your issue. Is the AC cooling the air?
  18. Jul 15, 2024 at 5:47 PM
    #138
    vermontmike
    vermontmike Member
    yes the AC cools the air except when I don't actually want cold air and the AC switch is in off mode it still blows cold air. I don't want cold air.
  19. Jul 15, 2024 at 8:28 PM
    #139
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    That's exactly it. It's never really off. The AC switch will show green and AC will be on. If you toggle the AC button and the light is off, the AC remains on. I can't stand this and found that "AC on in Auto" setting and disabled that. I think it finally actually works as it should.
  20. Jul 15, 2024 at 8:35 PM
    #140
    Digitalwiz5
    Digitalwiz5 Well-Known Member
    Well…it is the middle of summer…
Thread Status:
