How is the AccuTuned Tacoma built & why?
Discussion in 'AccuTune Offroad' started by AccuTune Offroad, Aug 23, 2022.
  1. Aug 23, 2022 at 10:55 AM
    AccuTune Offroad
    AccuTune Offroad [OP] Well-Known Member Vendor
    El Cajon, CA
    We've installed & tested a ton of different suspension parts on our 2020 Tacoma. Over the past few years this experience has allowed us to offer the best suspension packages possible and dial in our shock tuning skills. If you're curious to see what we've done with our Tacoma, watch the video below!
    If you have any questions about our Tacoma feel free to ask below or shoot us a message.
  2. Jul 5, 2023 at 7:35 PM
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    Hi, I’m looking at getting the Stage 3A with the Fox Performance Elite Series for my ‘21 TRD Pro.
    The note on the mid travel suspension kits page says “Toyota Tacoma TRD Pro models come from factory with a 1″ lift. Fox and King Coilover lift heights are referencing standard model Tacoma, with no lift.”
    If I’m replacing the front coil over assemblies wouldn’t that essentially be like a standard model Tacoma? My thought is that the Pro 1” lift is from the stock Fox suspension, which is being replaced.
    Also, I was wondering are the stock 1/2” blocks from the Pro lift in the rear removed when installing the Icon mini packs?
  3. Jul 6, 2023 at 7:00 AM
    AccuTune Offroad
    El Cajon, CA
    Standard model Tacoma would not come from Factory with that 1" lift, the TRD Pro does. This means you will not get as much lift on a TRD pro as you would with a standard model that does not have the 1" factory lift. Both models have restrictions on lift height.
    Keeping or removing 1/2" blocks in the rear is up to you, it's not a requirement as long as the shocks are long enough for the total lift height.
  4. Aug 4, 2023 at 6:27 PM
    BadDriver11
    BadDriver11 Active Member
    Ron
    Awesome build I need the update!
    AccuTune Offroad[OP] likes this.
  5. Aug 7, 2023 at 8:18 AM
    AccuTune Offroad
    El Cajon, CA
    What update are you referring to?
  6. Aug 8, 2023 at 7:10 PM
    BadDriver11
    Ron
    As mentioned in the video! I was just interested in the other upgrades y’all were planning on that truck, if they happened.
  7. Aug 9, 2023 at 6:55 AM
    AccuTune Offroad
    El Cajon, CA
    I see. Nothing drastically new at the moment. Some of those things have been on hold for other projects with a higher priority.
    BadDriver11[QUOTED] likes this.
