How is the mileage stored on Gen 1 Tacomas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brosneeks, Aug 16, 2023.
  1. Aug 16, 2023 at 10:00 AM
    Brosneeks
    Brosneeks [OP] Member
    1999 Tacoma
    stock
    I recently had my ECM meltdown and it took out the speedo, tech and odometer on the instrument housing. I found a replacement instrument housing, but have not been able to confirm if the mileage is stored from the ECM, the instrument housing or somewhere else in the truck. Some of the instrument housings I see online, list the mileage shown on the odometer prior to being removed from the vehicle and if I'm hoping to not have to have a drastic mileage increase from what my truck showed prior to the original ECM going down.
    I have a 1999 3.4 v6 4x4 w/ a manual transmission if that makes a difference in how the mileage is stored.
  2. Aug 16, 2023 at 10:38 AM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
    It's just stored on the odometer.
  3. Aug 16, 2023 at 10:59 AM
    Brosneeks
    1999 Tacoma
    stock
    Any idea if I can get the odometer reprogrammed to show the correct mileage?
  4. Aug 16, 2023 at 1:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @mechanicjon does this sometimes for folks
    mechanicjon likes this.
  5. Aug 16, 2023 at 2:57 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The mileage is stored on an EPROM chip on the odometer module on the instrument cluster. To remove it, it’s two screws and a ribbon cable - that’s all it is. If you’re confused which one is the Odometer module, it is the actual screen on the cluster. Just follow where it is and you can remove it easily.
  6. Aug 16, 2023 at 5:45 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    On it. I PM 'd him.
    Fatal_Paradox likes this.
  7. Mar 12, 2024 at 7:48 AM
    dwood293
    dwood293 New Member
    2004 Tacoma PreRunner Standard Cab 2.7L 2WD
    @mechanicjon can you do this for me as well?
  8. Mar 13, 2024 at 10:48 AM
    Dustem
    Dustem Well-Known Member
    Marc
    No. California
    1999 Reg cab 2.4 manual Trsns
    Lowered 3” front/back, 2006 Mustang alloy 16x7 with 225/55-16 tires. KYB Gas-a-just shocks.
    I’ve got a ‘99 2wd MT 2.4, originally with a non-tach cluster at 214k, now with a ‘99 tach cluster with 126k.
    While I love the tach, I’d also like to keep the mileage history clean.
    Can the EPROM be swapped between the two? The original cluster had a “mechanical” odometer readout, but no cable drive. The tach-equipped cluster is all electronic, and installed with no problems.
  9. Mar 14, 2024 at 1:47 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    yes
    dwood293[QUOTED] and Cloud99 like this.
  10. Mar 14, 2024 at 1:47 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    it can be swapped or reprogrammed.
  11. Mar 14, 2024 at 6:57 AM
    Dustem
    Marc
    No. California
    Well, that’s good news!
    I’d seen videos and articles describing a reprogramming process that involved unsoldering a chip from the cluster, building a socket interface for a laptop and using octal code to correct the mileage. Looked fairly complicated, and a local speedo shop quoted hundreds of dollars, weeks of time and no warranty on the work.
    on the other hand, if a simple component swap is possible between two functioning clusters, is there a write up or tutorial on how to do it? Or a service shop who can do the work reasonably, time and expense wise?
