How is your 3rd gen holding up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rosshoss, Aug 24, 2019.
  1. Aug 24, 2019 at 5:00 PM
    Rosshoss
    Rosshoss [OP] Well-Known Member
    2016 Tacoma TRD OR
    I 've got a 16 trd OR with just under 24K no problems just regular maintenance. How many miles have you guys put on your 3rd Gens so far? Any repairs?
    StayinStock and offthewallsurfer like this.
  2. Aug 24, 2019 at 5:07 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    No major issues, just the usual clutch creaking (dealer changed out assembly last year, and rear diff weeping (dealer changed gasket and torqued down correctly). Both addressed and fine now. But i only have 24k on mine as well on my 2017
    Junkhead, StayinStock and shakerhood like this.
  3. Aug 24, 2019 at 5:19 PM
    offthewallsurfer
    offthewallsurfer Well-Known Member
    I've got a 2017, just hit 60K, no regrets and no problems. I love this truck!!!!!! Just basic maintenance that is all!
  4. Aug 24, 2019 at 5:23 PM
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    2017, only 17k kilometers so far (so like 10500 miles). Some minor warranty claims like drivers door armest squeaking, howling diff TSB, ECU tune TSBs and soon getting my squeaky leaf springs TSB'd.
    A bit too much service for my tastes but it's all been really minor stuff so far.
    Junkhead and camillethetoy like this.
  5. Aug 24, 2019 at 5:26 PM
    JimTheLegend
    JimTheLegend Member
    Jim
    2016 TRD Off-Road 4x4 DCSB
    2016 TRD OR and just hit 65,000 miles. No issues and no regrets. I had the dealer do a couple of the transmission TSB's as a precautionary but I feel like one of the lucky ones when I read all the other threads. The transmission hunts around sometimes but it's not a deal breaker.
    Not really an "issue" but I did get a MAJOR drop in mileage when I went up a tire size.
    FarmerJB likes this.
  6. Aug 24, 2019 at 5:46 PM
    Rosshoss
    2016 Tacoma TRD OR
    Did they fix the howling diff? Took mine in once already for that & it still does it.
  7. Aug 24, 2019 at 5:55 PM
    Sclarpepplar
    Sclarpepplar Your raptor lights look like braces.
    Corey
    2016 TRD sport
    BFG KO2's Fuel rims SPC uca's Arb OME lift Arb on board air Prinsu designs roof rack
    I have 75,000 miles on my 2016.
    Front brakes, fluids, driveline greasing.
    That's all I've needed to do, everything is perfect except a slight blower fan tick at lower levels able to be heard in the interior, and the back right door panel definitely has something loose in it. When window is all the way down and you close the door, it's quite a metal rattle. I accept these issues. Truck has been a great purchase.
    GillyLink and Junkhead like this.
  8. Aug 24, 2019 at 5:58 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Neighbor down the road has 2 2016 V6s, 1 has 185k and the other just over 160k. He does handyman work, pest control and safety inspections/mitigation in remote parts of western AZ and in NV, and is gone pretty often. He’s had zero issues with both of them except for a replaced wheel bearing and usually tows or hauls his contracting supplies on a daily basis. Similar to me, he does almost all of his maintenance himself, using the cheapest quality fluids he can find. More often than not, that means he ends up running Supertech 0w-20 and Supertech in his diffs as well. I’ve since switch to it as well and had no issues in both my Toyotas. As for me, I have 30k on my 17 like a little weenie, but it holds up great and does everything I need it to. Perfect Broverland, SAR response, backcountry vehicle that’s still comfortable enough to also be my DD.
    Beemaster, genghis71, cshrum and 16 others like this.
  9. Aug 24, 2019 at 6:22 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Nice, another member on here has over 200,000 miles with no issues.
  10. Aug 24, 2019 at 7:00 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    50k and only issue was a battery replacement about 2 years in. Otherwise zero items, and zero trips to the dealer.
  11. Aug 24, 2019 at 7:10 PM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i’ve got 45k on mine. the biggest problem i had was staying on this site!!! if i wouldn’t have looked on here, i wouldn’t have searched out problems hahaha that weren’t a big deal ha!
    but seriously- did the tranny tsb and that’s it.
  12. Aug 24, 2019 at 7:13 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Little over 3k now on my 2019. Runs just fine overall and actually drives a ton better when I hauled my 20’ car hauler trailer loaded down with stuff across couple states then back home with empty trailer. Obviously has to downshift and upshift quite a bit but the shifts were all smooth and never found the truck hunting for the right gear as it does every time I drive it with just me in it and hauling nothing but me and truck.
  13. Aug 24, 2019 at 7:25 PM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    2016 with 47,000km, 39k being my own. Regular maintenance and I got the TSB for the ECU reflash. Had a blown rear left shock January 2019 but that was replaced under warranty after a long wait for the new shock and it didn't cause a ton of issues other than the obvious excessive bouncing on pot holed highways (sketchy).
    I purchased it originally knowing it would last me years even as a consumer and now that I'm going back to trades school for automotive service I'm still always going to be happy with my choice of vehicle
    Junkhead likes this.
  14. Aug 24, 2019 at 7:28 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    9500. I've put gas in it.
  15. Aug 24, 2019 at 7:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    25k on mine, only dealer visit was to get tires and wheels mounted and a front end alignment.
  16. Aug 24, 2019 at 7:41 PM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    They don't actually fix it, they install a sound deadening kit at the back of the cab to muffle it out somewhat. Toyota claims it's a harmonics issue and not an actual mechanical failure.
    AKGSD likes this.
  17. Aug 24, 2019 at 7:47 PM
    Redferdaze
    Redferdaze Member
    Trevor
    2016 TRD OR DCSB MT
    2016 with 63k, had the shifter boot, transmission and clutch pedal assy replaced under warranty in the first year. Since then just regular maintenance but have always had the diff howl and the clutch creaking just came back.
    Still like it a lot....I plan on running it until I need a full size
  18. Aug 24, 2019 at 7:53 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    No issues here with my 2018 bought last oct, besides very very light rust on the spot welds behind the rubber flappy-folds near where the bed and cab meet like a few others here. Going to bring it up on my next trip to the dealer to pick up fluids/filters.
  19. Aug 24, 2019 at 7:54 PM
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    This validates my purchase. I have a 2016 that has close to 40K miles. While I don't get much opportunity to drive mine as much as I like to, it's been good to me with no issues so far (Except that rear diff leak issue when I first bought it which everyone had back then which they replaced). Just did my first brake pad and rotor change about a month back. All I do is regular maintenance, oil changes, inspection etc.
  20. Aug 24, 2019 at 8:02 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    12,000 miles and no issues. Very happy so far.
