How is your 3rd gen holding up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rosshoss, Aug 24, 2019.
  1. Aug 27, 2019 at 4:58 PM
    #101
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    More burgers is your answer.
  2. Aug 27, 2019 at 5:01 PM
    #102
    Redtaco43
    Redtaco43 Active Member
    10,500 on a 2018 SR and I’ve had zero issues.
  3. Aug 27, 2019 at 5:39 PM
    #103
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    85,000 miles and some change on the clock. Had the differential howl that was fixed under warranty early on. Had to have a power steering pump replaced at around 80k for the shaft seal leaking (this leak is what most think is the front cover leaking). Other than that I have driven and worked the shit out of the truck. I have 30-40k miles of dirt roads and off-roading on the truck as I work out of it on my side job. I tow with it 2-4 days a week. Haul around a welding machine in the bed about half the time. Truck has been great. The more you use the transfer case and rear locker the faster they engage I’ve noticed by the way.
    AKGSD and Hemlocktherm78 like this.
  4. Aug 28, 2019 at 4:12 AM
    #104
    Mikefen1985
    Mikefen1985 Well-Known Member
    Western Mass
    2023 Toyota Tacoma Sport DCSB
    The pad slap/clicking is really Annoying :frusty:
  5. Aug 28, 2019 at 5:41 AM
    #105
    Tacoma1845
    Tacoma1845 Well-Known Member
    Anthony
    Central Virginia
    2018 Tacoma TRD Sport DCLB (Inferno- Premium/Tech)
    24,000 miles on my 2018 and no issues, except for the millimeter wave sensor which was covered under the warranty.
  6. Aug 28, 2019 at 6:44 AM
    #106
    Rapidfire1
    Rapidfire1 Well-Known Member
    Shaun
    York Pa
    2016 Black TRD Sport DCSB MT
    Agreed, safety and driveability items are very important but I'm also not gonna get bent out of shape over two plastic parts that rub together making a tiny squeak that I normally can't hear over my radio.
    jquest71[QUOTED] likes this.
  7. Aug 28, 2019 at 7:08 AM
    #107
    Roygpa
    Roygpa Member
    Roy
    Rugged Liner Hard Tonneau
    About 16,000 miles on my 2018 Sport and no issues so far. Love it.
  8. Aug 28, 2019 at 7:12 AM
    #108
    mbigpops
    mbigpops Well-Known Member
    2017 TRD Sport
    105K on my 2016 TRD Sport. Just routine maintenance so far (oil changes and tires). I put the frame plugs in to solve the whistling and I hate how the auto trans shifts. Had a high temp issue and found the reservior empty and filled it so it is fine now.
    Getting a leftover 2019 or new 2020 soon.
    Mark
  9. Aug 28, 2019 at 8:16 AM
    #109
    TBLTravy
    TBLTravy Well-Known Member
    2019 SR5 4X4 Sement , 2016 DCSB *sold*
    Oh ok. My truck was in not too long ago for this exact issue. They stated the front rotors were warped. Resurfaced them and it seemed to correct the problem about 80%. It still seems to be there but not nearly as noticeable. Ill give the e-brake method a shot and see what I find. Thanks.
  10. Aug 28, 2019 at 9:01 AM
    #110
    SEMO
    SEMO Member
    2019 Tacoma Limited
    2019 Limited. Just turned 800 miles. Had to have rear axles replaced right out of the gate. I don't see much difference. Still a vibration while braking. Has a slight shimmy at higher speeds also. I drive in S4 in town now, and S6 on the highway. D is too damn frustrating with the constant shifting. Only averaging about 18 mpg so far.
    I love the look of the truck and all the options of the Limited package (entune sucks). However, I hate driving it. I know it is a truck and isn't going to ride like a Caddy. But, it is rough. My Dakota I had for 11 years rode like a dream compared to this truck. Hopefully, things smooth out. My first Tacoma.
    Lawfarin likes this.
  11. Aug 28, 2019 at 10:58 AM
    #111
    AverageGuy
    AverageGuy Well-Known Member
    Jeff
    Kansas City
    Former Tacoma Owner. Currently Own a Lexus GX470
    43k miles in my 2017. I have the grey cloth seats and they are already discolored from rain, mud, snow and anything else that has made their way onto them while being in the outdoors. I'll likely snag some black seat OEM covers eventually
    StayinStock likes this.
  12. Aug 28, 2019 at 11:05 AM
    #112
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    40k and my diff is still howling away back there. The fluid was clean with no metal in it at 37k when I dumped it out so maybe they are right when they say "it's a characteristic of the vehicle".
    AKGSD likes this.
  13. Aug 28, 2019 at 11:19 AM
    #113
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
    Id say BS
  14. Aug 28, 2019 at 11:24 AM
    #114
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Get some Katskinz
  15. Aug 28, 2019 at 11:58 AM
    #115
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    2019, 17k
    Diff howl (screams) - told normal by engineer
    Hood glue failure - fixed
    Rear upper door seal glue failure -fixed
    Rear drums warped from factory- fixed
    Intermittent long crank/flood (not solved)
    Tailgate bushing fell out
    Battery leaked - replaced
    Clutch stick when cold - not solved
    Engine stumbles/ ruh ruh ruh below 2k - told normal (gotta get me that OVtune)
    A/C drain hose somehow fell into the cab and pissed on my floor - fixed
    Wheel well cover pushpins fell out - fixed
    Headlights & entire front end loose - told normal
    Wind noise from every door - told normal
    A/C started to stink first month i used it - told by engineer to never use recirc - though i had 240k on my gmc with no issues.... their chemical didnt fix the smell - going to try some bleach soon
    damn thing always pulls right - told normal
    And most recently, shocks did not hold up to Mojave Road
    Basically — i’m gonna have to play engineer and fix a bunch of stuff myself that should have been put together better from factory.
    My brother-in-law is an engineer, and upon seeing all the loose stuff in the front end/ under the hood, especially for an off-road vehicle that will suffer vibrations - he wondered if the interns designed it
    Of note, i was previously a mechanic, so, literally trained to notice problems
    jquest71 and Lawfarin like this.
  16. Aug 28, 2019 at 1:54 PM
    #116
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    We take the truck everywhere. She has a new Maxima we take on longer trips. I'm 45 miles round-trip to work. The last thing I'm worried about is a powertrain warranty on a Toyota.
    BlazinBlueTaco likes this.
  17. Aug 28, 2019 at 3:01 PM
    #117
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Its 90 degrees out, you know what that means. For those that want to downplay it, this is while driving so there's some road noise as well to drown it out some. Recorded from the cup holder but it's just as loud anywhere in the cab. Just greased it in June, time for another.
    https://youtu.be/EL9ax_H0sCs
  18. Aug 28, 2019 at 4:04 PM
    #118
    behls
    behls Well-Known Member
    Dave
    Lehigh Valley, PA
    2017 SR5 DCSB Quicksand
    17 SR5 has 40k on her. No issues. I drive it fairly hard but detail it monthly pretty thoroughly. Looks new yet and it's paid off. I do have an itch to into a full size though.
  19. Aug 29, 2019 at 7:25 AM
    #119
    GSDLVR123
    GSDLVR123 Well-Known Member
    Randall
    2023 TRD Pro (Solar Octane)
    2019 - purchased new in Jan this year...29K miles (approx 8-10K off road).
    Other than normal 5K maint here is what is on my receipts:
    11K : Update PCS Software and apply sealer (repair A) KOB Recall (not even sure what that is).
    20K: punctured rear tire ...we own a horse farm on a river - and I ran over something by the river that cut the tire (probably sharp rocks).
    I've had no major complaints - and would say on a scale of 1-10, this truck is a 9 1/2 for MY lifestyle. The interior color is my only real dislike and it is not a big deal (I hate the color black/grey). I'm looking at buying some of the tan Carhart seat covers, but have not decided yet - I need rugged and the brand is not what it use to be. I hear the "howl" in the rear but honestly would not have noticed it had I not seen it on this forum...I hope it does not cause me trouble but I did ask the dealership and made them aware of it. I do not expect/demand a lot other than 1. Decent comfortability back and forth to my office (120 miles round trip) , 2. Overall dependability and 3. Off road capabilities (around our farm/river) ....on those 3 points - so far - this truck is awesome! I have a ton of scratches and dings on my truck from driving along our trails, and THAT is a HUGE reason I like this vehicle. The size of this truck is wonderful! We have UTVs/ATVs and this truck goes most places they do (assuming you don't mind scratching the paint).
    AKGSD likes this.
  20. Aug 29, 2019 at 9:10 AM
    #120
    Desolate
    Desolate Well-Known Member
    Still hear mine after TSB done as well.
