How is your fuel millage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karambae, Dec 15, 2019.
  1. Dec 17, 2019 at 10:15 AM
    #61
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    19-21 on 93 with 10% ethanol
    22-23 on 90 with NO ethanol
    They are the same price
    davidstacoma and David K like this.
  2. Dec 17, 2019 at 10:17 AM
    #62
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    I've been getting 16-18mpg. that's combined city and freeway... some flat, some hills, sometimes 70+mph, and 87 and 89 octane. it pings on the hills with 87 and not with 89. (maybe depending on which gas station, too). i tried babying it to try to get that magical (mystical?) 20mpg. haven't succeeded yet..
  3. Dec 17, 2019 at 10:24 AM
    #63
    TacomaWilly
    TacomaWilly Well-Known Member
    87 Octane at both places. I don't put the premium in my truck.
  4. Dec 17, 2019 at 10:26 AM
    #64
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I did several comparisons between 87 and 91 octane and found no advantage buying more expensive premium gasoline. Ethanol, however, is a terrible product added to gasoline. In Mexico (no ethanol), my mpg always is better by 1-2 mpg.
    revtune and davidstacoma like this.
  5. Dec 17, 2019 at 10:29 AM
    #65
    Nachomama2001
    South Carolina
    Mine knocks on 87 even post TSB flash.
    Higher rpm not the 45mph 1200 rpm stuff
  6. Dec 17, 2019 at 10:34 AM
    #66
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    Terrible. I'm getting the same MPGs as I did in my Tundra with the 5.7, 14 MPG. I also have a front level and 33x12.2" tires though.
  7. Dec 17, 2019 at 3:26 PM
    #67
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I can believe 24.5 mpg in Kansas for sure!!
  8. Dec 17, 2019 at 3:30 PM
    #68
    davidstacoma
    David
    NC
    The main advantage in most premiums is the higher engine cleaning additives. I run mid grade to get some of that. Ethanol for sure lowers mileage as you say, since it has lower energy than gasoline.
  9. Dec 17, 2019 at 3:40 PM
    #69
    David K
    I run a bottle of Techron or other gas treatment every so often... I never experienced any mileage boost after doing so... I can only hope that is why I am not having injector issues.
    The 87 octane gas I buy has the same cleaning agents as 89 or 91 octane... by law, for air quality, etc. Is that only in California? Am I mistaken?
  10. Dec 17, 2019 at 3:46 PM
    #70
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    12-14 mpg with a 4 inch lift, 33 inch tires and a heavy foot.
    cleats50 likes this.
  11. Dec 17, 2019 at 3:50 PM
    #71
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Wives tale.... if its a top tier qualified gas station additive packages are the same regardless of fuel octane.
    TacomaMike37 and Tripod1404 like this.
  12. Dec 17, 2019 at 4:01 PM
    #72
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    I've broken 30 mpg once, going 65 from Indiana to Pennsylvania, but normally I get 28 on that run. I did do a lot of maintenance before that trip, and may have had weather on my side.
    I chalk it up to my 5 lug weighing 3300 lbs empty, and 3550 with my stuff. In the winter I cannot break 24, winter gas is a killer. I get 22 around town. The 4 bangers are awesome at mpgs, but the problem is that they do terrible at high speed. Designed primarily for foreign markets. On a short 100 mile run doing 45 following a trailer I got what I consider unverifiable 35mpg, but overall if you do work the v6 power is always worth it. Unless you want cheap and super easy maintenance.
  13. Dec 17, 2019 at 4:12 PM
    #73
    davidstacoma
    David
    NC
    Top Tier just means they meet the minimum requirements, not all are the same. Shell, which I tend to use, all grades are Top Tier, however their premium V-Power Nitro+ has additional engine cleaning additives:
    https://www.shell.us/motorist/shell-fuels/shell-v-power-nitro-plus-premium-gasoline.html
    From the Top Tier website FAQ:
    Do some brands have higher detergent levels?
    Formulations are proprietary to each company, however, each formulation is screened for compliance to the TOP TIER™ requirements.
    You might be talking to the wrong wives ;)
  14. Dec 17, 2019 at 5:02 PM
    #74
    Nachomama2001
    South Carolina
    X2 on Techron
  15. Dec 17, 2019 at 5:15 PM
    #75
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Cold weather starts, winter treads, lots of idling and lots of daily 4 wd use. I don’t bother checking the mileage in the winter.
    davidstacoma likes this.
  16. Dec 18, 2019 at 5:12 PM
    #76
    Lthompson
    Lthompson Well-Known Member
    average 16-18 all the time. v6 dclb 4x4
  17. Dec 18, 2019 at 5:33 PM
    #77
    Dizzel
    Dizzel Member
    Eric
    Eastern Ontario
    06 DCLB Silver
    I’m coming to grips to the poorer mileage these trucks get. I’ve just recently purchased mine. Enjoying the functionality, and actually using it as a truck in awkward places pulling trailers etc makes the mileage irrelevant to a high degree. Overall I’m really happy with the truck
    Coming from a 2000 dodge diesel 4x4 extended cab. 530,000 kms. Body rusted out.
  18. Dec 19, 2019 at 7:31 AM
    #78
    Drake Hall
    Drake Hall Member
    2010 taco double cab TRD sport 4.0L
    Cold air intake k&n, pull bar, remover mud flaps, looking for more recommendations for mods on bumpers and bed racks
    Yup I thought is was a fluke but just filled up after being a lead foot and got 23.7 average! I don't know how this is happening now! 2010 4.0L TRD Sport only thing is cold air intake and bed cover which is getting ready to be removed.
    davidstacoma[QUOTED] likes this.
  19. Dec 19, 2019 at 7:38 AM
    #79
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Funny thing....I got improvements of up to 8% just by putting a tonneau cover on my Taco...
  20. Dec 19, 2019 at 7:42 AM
    #80
    David K
    That is good to know! Does the 8% savings pay the cost of the cover in a year or is more valuable as an anti-theft feature?
