how is your winch wired?
Discussion in '2nd Gen. Builds (2005-2015)' started by johnw, Sep 20, 2011.
  1. Sep 20, 2011 at 3:40 PM
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    im about to install the wiring for my winch and im wanting to put an inline fuse or a breaker between it and the battery. im not sure on what size though the instruction manual doesnt say anything about that. so if you could help please it would be appreciated and if you cant help i will have your post's deleted.
    thanks john
  2. Sep 20, 2011 at 3:48 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    I really don't think you need a need a in line fuse for your winch. If there was going to be a problem then they would have that pre wired already from the manufacturer. Just wire it up direct and your good bro.
    this won't help and delete away if you feel neccesary. link to my install
    http://www.tacomaworld.com/forum/2nd-gen-builds/176522-warn-m8000-install-cbi-moab-front-bumper.html
    i have used this already a few times, with no inline fuse. direct hook up and only engages when you hook up the control to control box.
  3. Sep 20, 2011 at 3:49 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    What is the amperage draw of your winch? If not known you can convert HP as well so if you know the horsepower but not the amp draw it can still be figured out.
  4. Sep 20, 2011 at 3:49 PM
    johnw
    john
    orlando florida
    hmm this is very true. so it doesnt draw any power unless the controller is hooked up?
  5. Sep 20, 2011 at 3:50 PM
    johnw
    john
    orlando florida
    its a 5.5 hp motor
  6. Sep 20, 2011 at 4:43 PM
    johnw
    john
    orlando florida
  7. Sep 20, 2011 at 4:58 PM
    907taco
    Bobby
    Alaska
    that is correct, no power drawn until you hook up control switch.
  8. Sep 20, 2011 at 5:07 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    obviously not the same purpose as the fuse, but my friend with the land rover installed one of these. he installed it out of reach under the hood and leaves it in the off position unless he's wheeling, or it's snowing, etc. a lot of dicks up north (near the city), and a couple of the guys he knows through another forum have had their winches messed with since the solenoid box was exposed.
