How long between oil changes? Is Amsoil good oil to use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gasturbine, Jul 28, 2015.
  1. Jul 28, 2015 at 7:51 AM
    Gasturbine
    Gasturbine [OP] Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    I plan on running Amsoil Signature 0w-20 full synthetic in my 4WD 2.7l. I never go off-road or treat the truck hard, in fact, I have never had her over 3000 RPMs.
    My daily commute is about 30 miles round trip, half of it on 55 MPH country roads, and the other half on the freeway (65-70 MPH).
    But I own another car, and 2 motorcycles, so my Taco will prolly accumulate less than 10k miles a year.
    Amsoil claims their life for their signature series to be 25k miles, but most certainly would not go that long.
    How long do you full-synthetic guys go between oil changes? And I presume Amsoil is good stuff?
    Thanks!
  2. Jul 28, 2015 at 8:48 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I run Mobil 1 full synthetic and change every 5k miles w/filter but I'm supercharged. You should be able to get 10k with that setup. On all my forced induction engines I change every 5k and on all my naturally aspirated engines I change every 10k. I check all of them at every fuel fill up for color & level and I highly suggest getting into that habit if you don't already. You're more likely to experience a catastrophic engine failure due to level than you are quality so making sure you have an idea of the level and rough estimate on quality every few hundred miles is the least we should all be doing. Having said all of that, I advise sending some oil at various intervals off for analysis to see when your truck needs the oil changed to be safe. Bob is the Oil Guy is a great resource as well.
  3. Jul 28, 2015 at 8:58 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I would NEVER run any oil that does not meet API specs...does your AMSOIL?
  4. Jul 28, 2015 at 9:01 AM
    Gasturbine
    Central Ohio
    Absolutely.
  5. Jul 28, 2015 at 3:51 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I have nothing against Amsoil products.
    However, I do believe, based on years of personal experience that your truck/car/whatever will last just as long using non-boutique products that are readily available at Walmart.
    Pick a color, any color, as long as the specs match what's in your owners manual.
    Joe D, Crom and Arailt like this.
  6. Jul 28, 2015 at 3:58 PM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Well said!
  7. Jul 28, 2015 at 4:06 PM
    Firsttaco
    Firsttaco Well-Known Member
    alberta
    2009 Tacoma TRD Sport
    Bilstein 5100 all around, front set at 0 with OME 887. Light racing UCA. Dakar full pack in back. aluminum running boards. Scangauge II. Painted flat black rims. Raider canopy.
    I run amsoil in my truck and have about 100,000kms since I changed over. Everything is good so far. But read the box the oil comes in, the 25000 guaranty is for normal service this is from the site, and the oil I use.
    Normal Service – Up to 25,000 miles, 700 hours of operation or one year, whichever comes first, in personal vehicles not operating under Severe Service
    • Severe Service – Up to 15,000 miles, 700 hours of operation or one year, whichever comes first.
    Severe Service: Primarily short trips (less than 10 miles [16 km]); turbo/supercharged engines; commercial or fleet vehicles; excessive idling; first-time use of AMSOIL motor oil in a vehicle with more than 100,000 miles; frequent towing, hauling, plowing or driving in dusty conditions.
    • Modified engines (non-stock) and those using E85 fuel are excluded from extended drain recommendations.
    • Change at the vehicle manufacturer’s recommended drain interval outside U.S. and Canada.
    • AMSOIL Ea® Full-Flow Oil Filters are designed for extended change intervals. With other brands, do not exceed six months or 10,000 miles unless longer intervals are recommended by the vehicle manufacturer.
    • Check oil regularly to maintain proper fill levels.
    I have always changed mine at 8000kms and only recently found that ethanol part.
  8. Jul 28, 2015 at 4:34 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    I use Mobil 1 Full Synthetic as well, and also like Ostrichsak, I change the oil and filter every 5k miles. That's what Toyota recommends, and I know that full synthetic oils can go longer than that, but I plan on keeping my Tacoma till at LEAST the 300,000 mile mark.
    As far as Amsoil goes, it's been around long enough (in my opinion) to have proven it's not crap. What's important is to change your oil regularly, with a good filter and decent oil. That's what really counts.
  9. Jul 28, 2015 at 4:41 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Another Mobil 1 user.
    When the oil maint light stays on I change it.
    Easy
    Jeffvt0508 likes this.
  10. Jul 28, 2015 at 4:49 PM
    TacomaZL
    Illinois
    Mobil 1 users UNITE!
  11. Jul 28, 2015 at 5:01 PM
    nine2nine
    nine2nine Well-Known Member
    Greensboro N.C.
    06 TRD Tocoma Sport 4wd
    Mobil 1 at Walmart $25 for a 5 quart jug, but you still have to buy another quart because you need 5.5 quarts.5,000 mile oil changes.
    Teemu Taylor and QChawks like this.
  12. Jul 28, 2015 at 5:15 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Been using Mobile 1 since new in 2007. I change the oil @ 10,000 miles with a new filter at 5,000. 152,000 trouble free miles so far and I fully expect to double that.
  13. Jul 28, 2015 at 6:41 PM
    VermontTaco
    VermontTaco Well-Known Member
    Vermont
    2015 DCSB TRD Sport Silver
    Weather Techs Mats front and rear, Wet Okole seat covers, BakFlip Fibermax tonneau cover, Power Pop N' Lock, Flyzeye interior lights, Scangauge 2, IMMRYO Rearview mirror bracket, upgraded Homelink, temperature gauge, and compass rear view mirror, Matt Geko bed lights, OEM bed mat, Beerad's Antidark engine lights, interior LED lights, TRD SEMA 17" Wheels in gunmetal gray, LT265/70/17 BFG KO2 Load Range C, and center console/glove compartment organizers.
    Another Mobil 1 user here. I wait for a sale at Costco and buy 6 quarts for $27.
    Seabass likes this.
  14. Jul 28, 2015 at 6:50 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Damn I paid $45 for a 5qt jug and a quart of mobile 1 at advanced auto today, and that was with a $5 coupon....might return it and go to walmart
  15. Jul 28, 2015 at 7:08 PM
    TacomaZL
    Illinois
    Yeah I would definitely return, that's completely outrageous...
    BassMaster06[QUOTED] likes this.
  16. Jul 28, 2015 at 7:22 PM
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    Agreed. Walmart or Sams always have around $30 sometimes on sale for $23 in my area.
    Autozone or Napa don't carry in my town.
    Everywhere else sells it for $40 jug
    TacomaZL[QUOTED] likes this.
  17. Jul 28, 2015 at 8:22 PM
    TacomaZL
    Illinois
    Where I live for that price I could get Royal Purple for my truck....I just don't do that because I can't financially support a $50 oil change every 5,000 miles (I drive alot)
  18. Jul 28, 2015 at 8:25 PM
    vtdog
    vtdog Well-Known Member
    NH
    Personally, I am not that particular on brand. As long as it meets specs (weight and API) it seems ok to me. I buy the 5 gal jug at wally world of whatever brand is cheaper. About 6 months ago they had Penzoil full synthetic for $ 22 with a $ 10 rebate. So for $ 12 I got a name brand synthetic. I have not seen the rebate again, but keep looking.
  19. Jul 29, 2015 at 2:42 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    5K miles. Always. Very few factors influence that. If anything you want to change it more if you drive it less, but don't consider changing it less often. Not worth the risk. Oil changes are cheap and arguably the most important maintinence.
    I also agree with nit necessarily feeling the need to go with expensive oil. What is most important is that it is regularly changed.
  20. Jul 29, 2015 at 4:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Apparently 5k is the new 3k oil change rule?
    With the better built engines and high quality oils in production today, 10k is an easy number (under normal driving conditions) for a healthy motor.
    Send a sample of your oil, from your engine, and have it tested. Or just keep believing the old tales.
    OP. Nothing really wrong with Amsoil. It's a regular base with a unique boutique additive package. And a more-expensive-than-it-should-be marketing plan. Mobil 1 and a couple of other OTC oils are just fine, easier to find and available at sale prices.
