How Long Can I Go Without Alignment
Discussion in 'Suspension' started by Nukewater, Apr 3, 2012.
  1. Apr 3, 2012 at 1:05 PM
    Nukewater
    Nukewater [OP] Well-Known Member
    Adam
    Saskatchewan
    Was planning on putting my lift on on Thursday, April 5, but as everything seems to be closed for Easter, I am unable to do a wheel alignment. If i put it on then wait till monday, ill have driven 250km on highways. Question is, how bad will the mis-alignment be and how much damage/wear would it do.
    3" OME lift + LR UCA
  2. Apr 3, 2012 at 1:07 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    It won't be the end of the world. You will probably have pulling issues as well as severe wandering on the highway. Your tires won't suffer too bad though.
  3. Apr 3, 2012 at 1:07 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    the damage will be to your tires, so if you plan to get new ones I wouldnt worry too much about it. The truck will probably handle like shit too
  4. Apr 3, 2012 at 1:09 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Depends on how long your tires last
  5. Apr 3, 2012 at 1:13 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    IMO, I would not risk it.
  6. Apr 3, 2012 at 1:16 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Will probably wear your tires a bit excessively. Shouldn't pull though, since both sides are lifted and changed out of alignment equally. Maybe wander but tire wear would be the biggest issue.
  7. Apr 3, 2012 at 1:20 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    my steering wheel was slightly off center after my 2" lift.
  8. Apr 3, 2012 at 1:23 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Just do an eye ball alignment yourself after the install then when you can, take it to a shop and get it done.
