How long can I run this speaker with just my truck battery via the bed outlet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaMike37, Feb 27, 2015.
  1. Feb 27, 2015 at 5:21 AM
    TacomaMike37
    TacomaMike37 [OP] Well-Known Member
    13' DCLB MGM
    Going out in a few weekends with some buds.
    I wanted to use this speaker and the bed outlet to power it ( wanted to keep truck off and just use the battery).
    Here are the specs:
    SPEAKER
    Power Supply AC/DC Adaptor: . . . . . . . . . . . . . . . Input: AC 100 – 240V,
    50/60Hz
    Output: DC 9V, 2000mA
    Number of Channels: . . . . . . . . . . . . . . . . . . . . . . . . 3
    Frequency Level: . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50Hz – 20kHz
    Speaker Unit: . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5" Woofer & 1" Tweeter
    Dimension: . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.2" x 8.4" x 16.8"
    Are you able to figure out how much juice this thing pulls off the specs above?
    Thanks for the help,
  2. Feb 27, 2015 at 5:48 AM
    Blze001
    Blze001 Breaks things.
    Virginia
    2013 TRD Sport DCSB
    Hmmm... not sure, but I'd assume you can run it until the battery dies.
    The actual answer is incredibly complex.
    It kinda depends on your battery's amp/hour rating. Let's say it's 30AH, which means they can run a 12v, 3amp device for 10 hours. Your adapter says it's 2000ma which is 2 amps... and it's 9v, so it's pulling much less. I'd guesstimate 12 hours before the battery is dead. Mind you, this is ideal conditions. Batteries loose efficiency rapidly as they get drained and there are a bajillion other factors that can change the actual results. Also remember that a car battery isn't designed to be a pure discharge device, like what you'd find in a cellphone or laptop. It's meant to provide a bunch of power for the starter, then get recharged and serve as a pass-through for the alternator's power generating.
    Now if you want to know how long you can run it and still start the truck afterwards in the real world, the number is much less since the starter motor takes quite a bit of juice to get things moving, temperatures are going to be different, the battery won't be pristine, etc, etc. My advice would be start the truck for 10 min or so every 3 or 4 hours to play it safe.
  3. Feb 27, 2015 at 5:53 AM
    oldstick
    oldstick Medicare Member
    GA
    Not 100% sure on this, because I haven't used mine much yet. But I don't think the 110V bed outlet works without the truck idling does it?
  4. Feb 27, 2015 at 8:04 AM
    TacomaMike37
    13' DCLB MGM
    This is a great response. THx
    I think you can use it with the ignition in the on position ( though it puts out less), not positive yet as I haven't tried it though.
  5. Feb 27, 2015 at 8:05 AM
    Large
    Large Red
    I wouldn't run the inverter without the truck running for over 10 minutes IMO.
  6. Feb 27, 2015 at 8:32 AM
    TacomaMike37
    13' DCLB MGM
    I guess I should just get one of those wireless bluetooth speakers vs running the car to listen to some toons at the end of the day.
  7. Feb 27, 2015 at 8:37 AM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
  8. Feb 27, 2015 at 9:45 AM
    TacomaMike37
    13' DCLB MGM
  9. Feb 27, 2015 at 9:46 AM
    TacomaMike37
    13' DCLB MGM
    That's what she said.
  10. Feb 28, 2015 at 6:58 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    x2 It typically takes 13 amps @ 12 VDC to make one amp @ 120 VAC using an inverter. A DC to DC converter is much more efficient. Deep cycling a starting battery can prematurely shorten it's life. Starting batteries are designed for a shallow discharge <5% and a high current >300 amps and a full recharge before the next cycle. Temperature also has a huge effect on the CCA performance and amp hour capacity of any lead-acid battery.
    For additional information, please see the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  11. Feb 28, 2015 at 8:09 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  12. Mar 6, 2015 at 4:46 PM
    oldstick
    GA
    I have 35+ years experience but haven't worked up to 35 seconds yet.
    :D:D:D:D
  13. Mar 6, 2015 at 5:00 PM
    DouginNC
    DouginNC Well-Known Member
    Doug
    North Carolina
    2014 Double Cab TRD Sport
    I think you are right. I've only used the outlets in the truck bed with the engine running, believe the manual says to run the engine when using the outlets. The outlet only delivers 400 watts. Not sure what the speakers draw.
  14. Mar 6, 2015 at 9:07 PM
    utahskierdave
    utahskierdave Well-Known Member
    salt lake
    08 tacoma dbl cab
